Reading: Non-Dispersive Analyzers
Inst Tools > Blog > Analyzers > Non-Dispersive Analyzers
Last updated: September 13, 2018 11:21 am
Analyzers
Non-dispersive analysis, while newer in discovery than dispersive analysis (Isaac Newton’s 17th century prism), has actually seen far earlier application as continuous process analyzers. The basic design was developed during the years 1937-1938 by Dr. Luft and Dr. Lehrer in the laboratories of the German chemical company I.G. Farbenindustrie. By the end of World War II, over four hundred of these innovative instruments were in service in German chemical plants. Unlike most industrial analyzer technologies which are nothing more than adaptations of laboratory tests previously used by chemists to take manual measurements of substances, the invention of the first non-dispersive process gas analyzer embodied a wholly new analytical technique.
Industrial non-dispersive analyzers typically use either infrared or ultraviolet light sources, because most substances of interest absorb wavelengths in those regions rather than in the visible light spectrum. Non-dispersive spectroscopy using infrared light is usually abbreviated NDIR, while non-dispersive spectroscopy using ultraviolet light is abbreviated NDUV and non-dispersive spectroscopy using visible light is abbreviated NDVIS. Historically, NDIR is the more prevalent of the three technologies. Also, gas analysis is the more common application of non-dispersive spectroscopy in industry, as opposed to liquid analysis, which is why all the examples in this portion of the book assume the analysis of a process gas.
A partial listing of NDIR gas analysis applications at the I.G. Farben synthetic rubber facility in H¨uls, Germany at the conclusion of World War II is shown here. Note the impressive diversity of ranges and gases of interest measured by NDIR analyzers at this time in history, less than ten years following the invention of the technique:
NDIR gas analysis
At a different I.G. Farben facility (in Uerdingen, Germany), an NDIR instrument was used as a safety gas detector for carbon monoxide (0 to 0.1% concentration) in open air. This was in a process area where high concentrations of carbon monoxide gas existed in the lines, and where a leak in a process line or valve posed a considerable safety hazard to personnel.
The challenge of any analytical measurement technology is how to achieve selectivity, where the analyzing instrument responds to the concentration of just one substance (one “species”) and to no other substance(s) in the mixture. If the substance of interest exhibits some unique physical property we can readily measure with sensors, the selectivity problem is easy to solve: just measure that one property exclusively, and no other substance will interfere.
In the case of absorption spectrometers such as non-dispersive analyzers, the challenge is to selectively measure the concentration of certain light-absorbing substances amidst the presence of other substances also absorbing certain wavelengths of light. If the substance of interest is the only substance present in the mixture capable of absorbing light, selectivity is guaranteed. However, most applications in industry are not this easy, with the mixture containing other light-absorbing substances besides the one of interest. Some of these substances may absorb completely different wavelengths of light, while others may have absorption bands overlapping the absorption bands of the substance of interest (i.e. the interfering substances absorb some of the same wavelengths of light absorbed by the substance of interest, in addition to absorbing some unique wavelengths of their own).
Dispersive spectrographs achieve selectivity by “disassembling” the spectrum into individual wavelengths and measuring them one by one, but a non-dispersive analyzer must somehow distinguish different spectral responses without this “disassembly” of wavelengths. The bulk of this section is devoted to a discussion of exactly how selectivity is accomplished using the NDIR technique.
How to Calibrate Oxygen Analyzer? – O2 Sensor Testing Procedure
Gas chromatograph Working Animation
What is Gas Chromatography?
Analyzer Sample Systems
Dissolved Oxygen Analyzer Interview Questions & Answers
TOC Analyzer Working Principle
pH Analyzer Do’s and Don’ts
Oxygen (O2) Measurement in Flue Gas
Luft detector Principle
What is Gas Metering System?
Total Organic Carbon Analyzer Principle
Humidity Sensor Working Principle
Falling Ball Viscometer Principle
Silica Analyzer Problems and Troubleshooting Tips
NDIR GAS ANALYSER WORKING PRINCIPLE ANIMATION
NDIR Gas Analyser Working Principle
pH Analyzer Calibration and Troubleshooting
Troubleshooting pH Analyzer Common Problems
absorption-type optical analyzer
Absorption Type Optical Analyzer
Various Types of Sensors Used in Water Treatment Plant
Various Types of Sensors used in Water Treatment Plant
sulfur dioxide analyzer
Fluorescence
toroidal conductivity probe principle
Electrodeless Conductivity Probes Principle
Ambient Air Quality Monitoring System Principle
Hydrazine analyzer Working Principle
Hydrazine Analyzer Working Principle
Comparison of Temperature Sensors - Industrial Process Control
Difference Between RTD, Thermocuples and Thermistors
Difference Between RTD, Thermocouple and Thermistor
Capacitive Pressure Transducer
Capacitive Type Pressure Transducers Principle
Omron PLC painting program
Product Painting PLC Program using Omron CX-Programmer
Coriolis flow meters
What is a Coriolis Flow Meter?
Telemetry Systems Objective Questions
two chemical streams are mixed together
Mass Spectrometer Questions & Answers
