Reading: Next-Generation Security Surveillance Systems – AI Technology
Inst Tools > Blog > Common > Next-Generation Security Surveillance Systems – AI Technology
In this article, we will learn about next-generation security surveillance systems using AI technology in videos and smart cameras.
Last updated: June 16, 2023 11:10 am
Common
Security is a very critical task in important applications and areas. If the security is weak, then anyone can hack your network / hamper your process and destroy the whole system. So, it is necessary to keep an eye on the systems for securing them properly. Be it automation or any normal area in building premises, many next-generation security surveillance systems have cropped up to secure the systems properly.
Smart Camera BoxAI Technology in Video SurveillanceNext-Generation Security Surveillance Systems
In this post, we will have a look at the various next-generation security surveillance systems.
Smart Camera Box
A smart camera box is a system which uses cameras along with speaker systems in it. Let us extend the use of a CCTV camera in an area prohibited from entry. CCTV cameras will just monitor your area and give you video footage continuously. But, in a smart camera box, apart from video recording, it will also trigger a speaker in case of a miscreant entry.
Basically, it is defined inside to sense a clear area. If in this area, it senses some object, then it will create an audio alarm through the speaker and give a loud alert or warning. It will threaten the miscreant to get ready for some strict action. This can make the miscreant run away with fear. This makes the smart camera box a very important tool for securing the environment.
Due to its strict security requirement, it must be connected to a strong network thus. For this reason, Ethernet or Optical fibre is used; as TCP/IP is a global standard and interfaces with cybersecurity features easily. Strong networking is therefore required for making a smart camera box run successfully.
Cameras nowadays are equipped with artificial intelligence in it. If you just see a high-end smartphone, you will find that almost all the colour filtering, enhancement and other features are done by artificial intelligence inside the processor.
This, when extended to high-end security devices taking videos and photos; provides a very highly secured surveillance system. There will not be any need to send large-size data to cloud computing for processing; instead, the AI tools will do the job locally inside the processor. This saves time and also increases efficiency.
Let us take this technology to the next level. AI technology can analyse human behaviour patterns moving around a critical area. When it sees any abnormal movement in this case, it can alert the operator and save it from any damage. This eliminates the need for any extra processing or coding inside the security system. It can also study this pattern by a heat wave or thermal wave radiation.
If a certain set of people are usually concentrated in an area, then its heat wave calculation from the personnel will be considered normal. But, if some extraordinary heat wave is found in some other area, then AI will detect that pattern and try to warn the operator about any threat looming around.
This AI technology, apart from human behaviour, can also study the patterns of vehicles roaming around. Any unexpected traffic or vehicle pattern in an area can make it alert the operator.
Also, nowadays due to advanced technology in messaging or mailing, instant data from the security systems can be transferred to the respective personnel. Due to this, an operator sitting at a very far location too can get intimated about any security threat in that area. Due to local processing, bandwidth and data usage are reduced to a great extent.
The reaction time from the security systems will be so quick that there will be little chance for the miscreant to do any mishap. Also, the quality of images and videos in such high-end systems are of such a high pixel, that the streaming and viewing become easier to troubleshoot and identify.
  • Introduction to Modbus
  • What is Data Acquisition?
  • Safety in Automation Systems
  • Introduction to Control System
  • Power Supply for Industrial Systems
What is VoIP and How Does it Work? Advantages & applications
Web Tension Measurement and Control Technologies
What is a Laser Sensor? Principle
Introduction to Wastewater Treatment Works and Pumping Station
Critical Factors to Consider for Engineering Students to Ensure a Smooth Path
Fiber Optic Cable vs Coaxial Cable
7 Marketing Strategies for Engineering Companies
Vision Camera Systems in Industrial Automation
HVAC Double Effect Absorption Chiller
Five Types of PCB Assembly that You Should Know
Cold Email Deliverability – Latest Comprehensive Guide
Career Scope in Electrical Engineering
Robotic Process Automation (RPA) in AI – Market Growth & Business Benefits
Bagging Machine Controller
Bagging Machine Controller – Principle, Operation Sequence
Comparison of Absorption Chillers and Electric (Compression) Chillers
Difference between HVAC Absorption Chillers and Electric Chillers
RJ45 Connector Pins
How to make RJ45 cable
FPGA vs. CPLD - What are the differences between them
FPGA vs. CPLD – What are the differences between them
Rotational Viscometer
What is a Viscometer? – Types, Applications, Advantages
Two Wire Transmitter Working Principle
Basics of Two, Three & Four Wire Transmitters
Tips to Maintain & Extend the Life of CNC Tools
Tips for Maintaining and Extending the Life of Your CNC Tools
Hydrogen Sulfide Accident
The Aghorn Hydrogen Sulfide Accident – H2S Gas
Parts of Steam Ejector
Working Principle of Steam Ejector
Construction of Root Loci
PRV
Control valve sizing
Relative Flow Capacity of a Valve
Batch Mixing with PLC Ladder Logic Program
D flip flop in PLC
D Flip Flop PLC Ladder Logic
Allen-Bradley PLC Circuit
Programmable Logic Controller (PLC) Questions and Answers – 12
Ultrasonic level measurement
Ultrasonic Level Measurement
