Reading: Things to Know When Measuring Current
Inst Tools > Blog > Electronic Basics > Things to Know When Measuring Current
Learn the important factors to consider when measuring current in electrical engineering. Discover the dos and don'ts of using a multimeter.
Last updated: February 22, 2025 9:29 am
Electronic Basics Electrical Basics
6 Min Read
It seems very easy when someone asks an engineer to measure current. But, there are many interesting facts and things which need to be considered before measuring it. Because in the technology of electrical engineering, current measurement is a very important aspect for all the basic foundation and troubleshooting. They obviously depend on a multimeter for measurement, but even in that, there are some important points to note down before starting measurement. In this post, we will see some things to know when measuring current.
Current is most preferred to be measured in seriesSet the meter in proper amperage ratings before connectingUse clamp meters for larger currentsUse of PPE when measuring larger currentsTransient currents are difficult to captureRegular calibration is a must
The measuring instruments like a multimeter or ammeter have a very low resistance. Unlike voltage which is measured in parallel (which means connecting the red probe to the positive terminal and connecting the black probe to the negative terminal), current should be measured in series due to this reason.
Refer to the below image. If you were measuring voltage, then you would have directly connected multimeter probes to any of the load or source points.
But when measuring current, you cannot do this thing. Because of the low resistance and normal fuse ratings used inside the meter, a very high current will flow through it and damage the meter. So, you need to break the circuit between the source and load and connect the multimeter in between.
The current from the source will flow through the meter as shown, and then reach the positive end of the load. The meter will directly measure the current in series, and show you the readings in ampere.
You know whether DC or AC current is flowing in the circuit. You also know the maximum current that the load will carry. Standard multimeters have a maximum rating of 10 A. So, set the meter in that reading before measuring the current.
Also, when measuring current, it is recommended to first power off the circuit, then connect your probes, then power on the circuit and check the values. Meters also have a provision of milliamperes reading. So it should not be like you are measuring a heavier load and putting the probe in this range. It will damage the meter.
So check the ratings and probe before putting the meter in a live circuit. If the current you know is within the range of the ratings, then it can be connected in parallel ( but this is mostly recommended for milliamperes).
Clamp Meter
Clamp Meter
The clamp meter is the easiest way to measure current (uses magnetic fields to determine current flow). Just put the round clamp around the wire (like a current transducer) and check the values in the meter. This is most preferred as there is no need to close the circuit like in a multimeter, and you can check it live.
Also, larger currents provide a chance of an electrical shock; so clamp meters are preferred for larger values of currents. It is best used for checking busbar currents or other heavier loads where touching the circuit is not possible. But, clamp it around a single wire. If it is clamped around two wires, the magnetic fields will cancel each other and you will get a proper reading.
Safety consideration is a must when measuring currents of large values. So, it is recommended for engineers to wear protective kits like gloves, safety glasses, or flame-resistant clothing. This will protect them from any potential hazard or accident.
You know that a particular circuit has been affected by noise and causing disturbances in the system. You cannot connect a meter and monitor it continuously. It is cumbersome and tiring, as you do not know when the peak or harmonic or transient current will come
So, instead of manually and visually waiting for the current to occur, use a digital oscilloscope of high speeds, which can detect rapid changes. As it shows values in a graphical form, you can detect when the last transient occurred seeing date and time, and also check how frequently it is occurring. This quickly aids the troubleshooting process for the engineers.
Measuring Multimeter
Multimeter
Meters are affected by accuracy too, when frequent usage can affect the circuits inside. So, meters must be regularly calibrated for accuracy and reliability.
Accuracy can be affected due to incorrect connections, external temperature effects, or electromagnetic interferences. So, it is recommended to maintain a schedule for calibrating the meters and replacing them if found faulty or way too inaccurate.
In this way, we saw some important things to know when measuring current.
  • Introduction to Protective Systems
  • Implement Motor Control Circuits
  • Ground fault trip of Circuit breaker
  • Interesting Multimeter Functions
  • Compare Clamp Meter and Multimeter
How to Identify Phase, Earth, and Neutral Wires?
Electrical Motor Terms and Concepts
What is ELCB? Principle, Advantages, Disadvantages, Applications
How to Connect a 3 Phase Motor in Star and Delta Connections?
Difference Between RCCB and MCCB
What is Electrical Panel Door Earth Bonding? Explained
Difference Between Circuit Breaker and Fuse
Difference between Stepper Motor and Servo Motor
What are Switchgear Interlocks?
Download Electrical Enclosure Book
What is a Magnetic Contactor? – Principle, Types, Advantages
Why Are Charcoal and Salt Added to an Earthing Pit?
What is Transformer Bushing? Working Principle
Bonding and Grounding Electrical Systems
Testing and Inspection of Bonding and Grounding Systems
Basics of Electricity Rates
Earth Fault
What are Ground Fault and Earth Fault?
Difference Between Overcurrent and Overload
ACSR (All Aluminium Conductor Steel Reinforced)
What is an Overhead Cable? Types of Overhead Conductors
Why do we need to Control the Motion using VFD drives
Why do we need to Control the Motion using VFD drives?
Seven Segment LED Display
Difference Between Common Cathode and Common Anode 7 Segment LED Display?
Purpose of an Electrical Substation
What is a Substation? Purpose of an Electrical Substation
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 2
National Pipe Thread Cross Sectional View
What is Tapered Thread Pipe Fittings ?
How to Download Rslogix Free
Download Allen Bradley RSLogix PLC Software
Pulse Width Modulation Inverters Questions
Calculate the Magnitude of Hydrostatic Pressure
Modbus Vs DNP3
Difference between Modbus and DNP3 Communication Protocols
Induced Draft Cooling Tower
Cooling Tower
Gas Turbine Troubleshooting Guide
Gas Turbine Troubleshooting Tips
