Reading: How Measurement Span of Pressure Gauge Could be Changed?
Inst Tools > Blog > Pressure Measurement > How Measurement Span of Pressure Gauge Could be Changed?
Last updated: June 3, 2020 12:24 pm
Pressure Measurement Practical Questions
2 Min Read
Shown here is a diagram of a standard pressure gauge, based on the pressure-sensing action of a hollow, C-shaped metal tube called a bourdon tube:
Pressure gauge mechanism
Using arrows, trace the motions of all moving components in this mechanism as an increasing pressure is applied to the fitting at the bottom of the bourdon tube.
Also, describe how the measurement span of this pressure gauge could be changed. In other words, what would have to be moved, adjusted, or altered in this mechanism in order to change the proportionality of applied pressure to pointer movement?
Answer:
The parts in this gauge mechanism would move as such:
motions of all moving components in pressure gauge
Possible things to change to make this pressure-measuring mechanism more sensitive:
  • Decrease the spring rate (“stiffness”) of the bourdon tube
  • Shorted the arm of the sector gear (the portion to the right of the pivot, joining with the link)
  • Increase the sector gear radius
  • Decrease the pinion gear radius
More Questions for you:
1. What sort of device(s) would you suggest using to apply a precisely known pressure to a gauge for calibration purposes?
2. Suppose a pressure gauge is intended for service in a process measuring liquid pressure. Is it okay to calibrate this gauge on a test bench using compressed air instead of the liquid it will be exposed to in the field? Why or why not?
  • DeadWeight Tester Questions
  • DP Level Measurement Problem
  • Valve Questions and Answers
  • Pneumatic Load Cell Principle
  • What is a Four-wire RTD?
Credits: Tony R. Kuphaldt
Pressure Transmitter Re-Range Questions
Pressure Switch Questions
PLC Pump Permissive Interlocks
Liquid Level Measurement using Pressure Transmitter Questions
Inferential Measurement based on Pressure
Capillary Tubing Pressure Sensor Temperature & Elevation Problems
  • b demudu says:
    June 29, 2020 at 6:45 pm
    pressure gauge calibrated with air and oil(dead weight tester) with air
    instrumentation air to connect through the air regulator to insincere the pressure then same pressure to indicate the test (calibrated) gauge this type of test method is good and no deviation maximum
    the bourdon tube mainly affected by temperature and also a constant pressure is maintained line for a long time this case also gauges are not responding correctly
Moving Pressure Sensing Level Transmitter from Top to Bottom
PLC Program to Control a Water Pump
All About Instrumentation Impulse Lines
Programmable Logic Controller (PLC) Questions and Answers – 2
Well Manometer Principle
Fisher model 546 I/P transducer
How to Connect Proximity Switch (Sink Type) to Make LED ON ?
Elastic Diaphragm Gauge Principle
water filter level control system
Practical Process Control System Questions & Answers – 6
Siemens S7-200 PLC
Programmable Logic Controller (PLC) Questions and Answers – 13
Pressure Sensor Specifications
Inductive proximity switches
How to Connect Proximity Switch (Source Type) to Make LED ON ?
Capacitive Pressure Transducer
Capacitive Type Pressure Transducers Principle
Is it Possible to Measure liquid-liquid Level Interface using Float
Is it Possible to Measure Liquid-Liquid Level Interface using Float?
Motor ladder Logic
Practical Control Systems Questions & Answers
Practical Process Control System Questions & Answers – 1
How to Protect Pumps from Cavitation
How to Protect Pumps from Cavitation? – Reasons, Solutions
circuit-breaker-interview-questions-answers
Circuit Breaker Interview Questions & Answers
Wet Contacts and Dry Contacts in PLC Systems
Induction Motor Rotor EMF, Current and Power
Top 100 Power Systems Projects
Top 100 Power Systems Projects – Electrical Engineering
Multi-mode optical fiber
Multi-mode and Single-mode Optical Fibers
FPGA vs. CPLD - What are the differences between them
FPGA vs. CPLD – What are the differences between them
Load Cell Design
Load Cell Design
