Reading: Lower Explosive Limit (LEL)
Inst Tools > Blog > Fire & Gas System > Lower Explosive Limit (LEL)
Last updated: May 31, 2019 5:20 pm
Fire & Gas System
The minimum concentration of a flammable gas in air capable of igniting is called the Lower Explosive Limit, or LEL.
This limit varies with the type of gas and with the oxygen concentration of the air in which the flammable gas is mixed.
Sensors designed to detect the dangerous presence of combustible gases are therefore called “LEL sensors.”
LEL monitors are used whenever there is a high probability of explosive gases present in the air.
These areas are referred to as classified areas in industry, and are precisely defined for safety engineering purposes.
Classified areas harboring explosive gases or vapors are deemed Class I areas, with different “Group” categories delineating the specific gas or vapor types involved.
Gases and vapors are not the only substances with the potential to explode in sufficient concentration.
Certain dusts (such as grain) and fibers (such as cotton) may also present explosion hazards if present in sufficient quantity.
Unfortunately, the majority of analytical technologies used to monitor lower explosive limits for safety purposes only function with gases and vapors (Class I), not dusts or fibers (Class II and Class III, respectively).
Popular sensor technologies used to detect the presence of combustibles in air include the following:
  • Catalytic bead
  • Infrared
  • Flame ionization
  • Thermocouple
Catalytic bead and thermocouple sensors both function on the principle of heat generated during combustion.
Air potentially containing a concentration of flammable gases or vapors passes near a heated element, and any combustion occurring at that point will cause the local temperature to immediately rise.
These sensors must be designed in such a way they will not initiate an explosion, but merely combust the sample in a safe and measurable manner.
Like micro fuel cell oxygen sensors, these sensors may be manufactured in sufficiently small and rugged packages to enable their use as portable LEL sensors.
Infrared analyzers exploit the phenomenon of infrared (IR) light absorption by certain types of flammable gases and vapors.
A beam of infrared light passed across a sample of air will diminish in intensity if significant concentrations of the combustible substance exist in that sample.
Measuring this attenuation provides an indirect measurement of explosive potential.
A major disadvantage of this technique is that many non-flammable gases and vapors also absorb IR light, including carbon dioxide and water vapor.
In order to successfully reject these non-flammable substances, the analyzer must use very specific wavelengths of IR light, tuned to the specific substances of interest (and/or wavelengths tuned specifically to the substances of non-interest, as a compensating reference signal for the wavelengths captured by both the substances of interest and the substances of non-interest).
Flame ionization sensors work on the same principle as FIDs for chromatographs: a non-ionizing flame (usually fueled by hydrogen gas) will generate detectable ions only in the presence of air samples containing an ionizing fuel (such as a hydrocarbon gas). Of course, this form of LEL sensor is useless to detect hydrogen gas.
Also Read : Importance of LEL in F&G
Rate Compensated Heat Detectors Working Principle
Why we use End of Line (EOL) Resistor in Fire and Gas System ?
Fire Extinguishers Mock Test
Gas Detection System Abbreviations
Calibration of Gas Detectors
Catalytic Gas Detectors Principle
Gas Detectors Working Principle
Basics of Foam Fire Fighting System
Why Negative Readings in Gas Detectors ?
Flame Detectors Working Principle
Rate of Rise Thermal Detectors Working Principle
Which One is Best – Conventional or Addressable Fire Alarm System?
Gas Detectors Practical Problems and Troubleshooting
Which Gases Can a Multi-Gas Detector Detect?
Overview of Fire Detectors
Overview of Fire/Smoke/Flame/Heat/Gas Detectors
Sprinkler System
Basics of Sprinkler System
Carbon Monoxide Gas Detector
Carbon Monoxide Gas Sensor Principle
Linear Heat Detector Working Principle
What are Linear Heat Detectors?
Industrial Flame Detectors
Difference Between Passive and Active Fire Protection
Active and Passive Fire Protection
Fire and Gas (F&G) Mapping: Methodology, Performance Targets, Acceptance Criteria
Argonite Fire Suppression System Animation
Argonite Fire Suppression System Working Principle
3-way globe valve
What is Mixing or Diverting Valve ?
What is Electrical Busbar
What is Electrical Busbar? Types, Advantages, Disadvantages
C-Bourdon Tube
C-Bourdon Tube Pressure Gauge Theory
Differential Pressure Sensor Calibration
Differential Pressure Sensors Calibration Procedure
Control Valves Questions and Answers
Control Valve Questions and Answers
Electrical Equipment Selection in Hazardous Area
Delete Siemens CPU Memory
Modbus Network Motor Control
Motor Control using Modbus Communication and Hardwired Signals
