Reading: Liapunov’s Stability Criterion – Part II
Inst Tools > Blog > Multiple Choice Questions > Liapunov’s Stability Criterion – Part II
1. The systems with equation such as dx/dt =F (x) are called:
a) Stable systems
b) Control systems
c) Autonomous systems
d) Unstable control system
Answer: c
Explanation: Autonomous systems are represented by the differential equations as stated above and these systems are tested by liapunov’s stability criteria.
2. The points at which derivatives of all the state variables are zero are:
a) Singular points
b) Nonsingular points
c) Poles
d) Zeros
Answer: a
Explanation: Singular points are the points that are calculated by equating the denominator equal to zero and at which the derivatives of all the state variables are zero.
3. The system if kept in the singular points will continue to lie on these points undisturbed.
a) True
b) False
Answer: a
Explanation: The derivative of all the phase variables being zero, the system shall remain unchanged and the system if lying on these points will continue to lie on these points undisturbed.
4. A system is stable with zero input if:
a) The resulting trajectory tends towards the equilibrium state.
b) If for the bounded input output is also bounded
c) It is a free system
d) It is forced system
Answer: a
Explanation: A system with zero input is the system in which the input is zero and initial states are taken as the input and a free system but it is stable only if the resulting trajectory tends toward the equilibrium state.
5. A Forced system is stable if:
Answer: b
Explanation: For forced system input is given externally and response has two terms due to the initial states and input given and it is stable if output is bounded for bounded input.
6. In non-linear systems forced and free responses are:
a) Related
b) Not related
c) Contemporary
d) None of the mentioned
Answer: a
Explanation: Forced response is due to the external input and free response is due to the initial state and total response is sum of both the responses and in non-linear systems both are related.
7. The linear autonomous systems:
a) Have one equilibrium state
b) Their behavior determines the qualitative behavior of the s-plane
c) System behavior for small deviations about the equilibrium point may be different from the large deviation
d) Both a and b
Answer: d
Explanation: The linear autonomous systems having the differential terms with the linear relationship and have one equilibrium state and their behavior determines the qualitative behavior of the s-plane.
8. The non-linear system
d) Both a and b
Answer: c
Explanation: For the non-linear system where the input parameters or external input is having non-linear relationship with the output and behavior for small deviations about the equilibrium point may be different from the large deviation.
9. The system is stable at origin if for every initial state which is sufficiently close to the origin remains near the origin for all t then the system is :
a) Asymptotically stable
b) Asymptotically stable in the large
c) Stable
d) Unstable
Answer: c
Explanation: By definition, the system is stable at origin if for every initial state which is sufficiently close to the origin remains near the origin for all t then the system is stable.
10. If x (t) approaches near the origin as t tends to infinity then the system is :
c) Stable
d) Unstable
Answer: a
Explanation: By definition, if x (t) approaches near the origin as t tend to the infinity then the system is asymptotically stable.
Stability of Nonlinear System
Silica Analyzer Questions & Answers
Process Pressure Measurement Objective Questions
Direct Method & Constructing of Liapunov for the Linear & Non-Linear System
Stability Analysis by Describing Functions
Nitrogen Oxides Questions & Answers
Pneumatic Control Mechanisms Objective Questions
Transfer Functions Objective Questions
Sulphur Di-oxide Monitoring Questions & Answers
Surface Spectroscopic Techniques
Secondary Reference Electrodes Questions & Answers
Instrumentation for Electron Spectroscopy
Infrared Gas Analyzers Questions & Answers
Combination Electrode Questions & Answers
Detection System of Gas Chromatography Questions and Answers
Stability in Frequency Domain
Realization of Basic Compensators
State Variables & Linear Discrete Time Systems
Preliminary Considerations of Classical Design
Frequency Response MCQ
Bode Plots MCQ
Signal Flow Graphs Objective Questions
Fourier Transform NMR Spectroscopy Questions & Answers
Time Response Analysis
Performance Indices
PLC Program to Operate Stamping of Parts
PLC Application for Stamping Operation – Example Programming
Omron PLC washing machine automation
Omron PLC Logic for Washing Machine Automation
Modern Cement Kiln Drive
Cement kilns, Rotary Drum Driers Simplest Electrical Drive
Types of Sensors used in the Dairy Industry
Level Flow Cascade Control Pumping Station
Introduction to Wastewater Treatment Works and Pumping Station
Plant Air Storage Tank
Single Loop Control
Cascade Control Principle
Electrical Drives and Controls Interview Questions
