Reading: Determine the Problems with Level Transmitter and Gauge
Inst Tools > Blog > Practical Questions > Determine the Problems with Level Transmitter and Gauge
The level transmitter and level gauge indicates different readings. Determine the problems and find out the correct measurement.
Last updated: December 14, 2020 10:14 pm
Practical Questions
2 Min Read
In this biogas generation system, cow manure is used as a feedstock to produce methane gas (CH4), which is then used to fuel an engine to turn a generator and make electricity.
The waste heat from the engine is used to maintain the cascaded digesters (“reactors” R-101 and R-102) at optimal temperatures for anaerobic bacteria to digest the manure and produce biogas (approximately 105oF):
Determine the Problems with the Level Transmitter and Gauge
LIC-56 registers a manure level of 3 feet 10 inches, while the operator’s manual gauge reading is only 3 feet 7 inches. The calibrated range of LT-56 is 0 to 4 feet. Your first step is to measure current in the cable connecting LT-56 and LIC-56, and there your digital multimeter (DMM) registers 19.33 mA.
Based on this information, determine at least two potential problems in this system. Also, determine whether or not a hydrostatic (DP) level transmitter would be suitable for measuring manure level in R-102.
Answer:
The current value agrees with the indication at LIC-56, and so the problem is not with LIC-56. This leaves the transmitter (mis-calibrated, plugged impulse line), a change in process density (assuming a hydrostatic DP transmitter) or the operator’s manual measurement of manure level.
Hydrostatic (DP-based) level measurement is appropriate for R-102, assuming either remote seal(s) or purging. Otherwise, solids in the manure will surely plug up the transmitter’s impulse line(s) over time.
  • Instrument Hook Up Diagram
  • Instrumentation and Control MCQ
  • Pressure Gauge Datasheet
  • Temperature Controller Problem
  • Pressure Measurement MCQ
Credits: Tony R. Kuphaldt
10 Questions on Reforming Furnace Control System
Guided-wave Radar Asset Management Parameters
Calculate Total Hydrostatic Pressure at Bottom of Vessel
Displacer Level Transmitter Questions
Electronic Force Balance Pressure Transmitter
Questions on Radar LT Loop Diagram
What Affect the Pressure Measurement Accuracy of a Manometer?
Smart DP Transmitter Flow Meter Calculations
Programmable Logic Controller (PLC) Questions and Answers – 1
Differential Pressure Measurement across Baghouse
What is the Purpose of Bourdon Tube Gauge Spiral Spring?
Air Pressure Inside the Tank
Differential Pressure Sensor with Pair of Strain Gauges
Simple High Level Indicator Circuit
reactor vessel
Fisher model 546 I to P transducer
Fisher model 546 I/P transducer
High Level Alarm of Distillation Process
Investigate High Level Alarm of Distillation Process
Identify the Pressure Gauge Error
Current-to-Pressure Transducer Calibration Table
Liquid Level Measurement using Pressure Transmitter
Liquid Level Measurement using Pressure Transmitter Questions
Flapper nozzle system
Flapper Nozzle Questions
safety control system
Safety Instrumented Burner Management System
PLC Latched Circuit Example
PLC Latching Function
Fieldbus Flow Transmitter Calibration
Car Cooling System Automotive Radiator
What is an Automotive Radiator?
RTD installed after the Orifice Plate
Why RTD installed after the Orifice Plate ?
Facts of Control Valves
Facts About Control Valves
Field Instruments
#11 PLC Best Practices – Instrument for Plausibility Checks
FMCW Radar level transmitter Working Principle
FMCW Radar Level Transmitter Working Principle
