Reading: Instrumentation Symbols Legend
Inst Tools > Blog > Basics > Instrumentation Symbols Legend
Last updated: April 2, 2019 6:29 pm
Basics
1 Min Read
Piping and Instrumentation Diagrams (P&IDs) use specific symbols to show the connectivity of equipment, sensors, and valves in a control system.
These symbols can represent actuators, sensors, and controllers and may be apparent in most, if not all, system diagrams.
P&IDs provide more detail than a process flow diagram with the exception of the parameters, i.e. temperature, pressure, and flow values. “Process equipment, valves, instruments and pipe lines are tagged with unique identification codes.
Common P&ID Symbols Legend
Piping and instrumentation diagrams, or P&IDs, are used to create important documentation for process industry facilities.
The shapes in this legend are representative of the functional relationship between piping, instrumentation, and system equipment units. We’ve broken them down into seven main groups: equipment, piping, vessels, heat exchangers, pumps, instruments, and valves.
Process and Instrumentation Diagrams use special shapes to represent different types of equipment’s, valves, instruments and pipelines.
Also Read : Basics of Instrumentation Engineering
Basics of Trips, Interlocks, Permissives & Sequences
Instrument Cable Voltage Drop
Basics of 4-20mA Current Loop
Smart Sensors in Industry – Components, Types, Advantages
Impulse Piping standards for Field instruments
What is Process Control?
  • Nyl says:
    August 7, 2015 at 11:39 pm
    Great sources. No doubt, you’re an authority in the industry.
Why 4-20 mA Current Signal is used instead of Voltage Signal?
What Every Instrument Engineer Should Know?
Performance Characteristics of Sensors and Transducers
Instrument Errors – Zero, Span, Linearity
How to Do Logic Checks During Plant Pre-Commissioning
What is Electrical Conduit? Types, Advantages, Disadvantages
Sink or source PNP or NPN Normally Open or Normally Closed Input v. output. output
Instrumentation Dictionary
Shutdown Manager
What are Pre-Shutdown, Shutdown, and Post-Shutdown?
Piping and Instrument Drawing
Difference between PFD and P&ID with Example
SMART Transmitter
What is a SMART Transmitter?
Instrument Percent of Span Error
Common Mistakes in Instrumentation
how-a-4-20ma-transmitter-works
How a 4-20mA Transmitter Works?
Yokogawa DCS Tutorials - Configuration of Analog Input (Transmitter)
Yokogawa DCS Tutorials – Configuration of Analog Input (Transmitter)
Dataloggers Objective Questions
Data Loggers Objective Questions
Helix Bimetallic Thermometer Principle
Modbus Network Motor Control
Motor Control using Modbus Communication and Hardwired Signals
Welding Machine Fail in Dusty and Corrosive Areas
SCADA Standards
SCADA for Substation Automation
DP Level Measurement Problems
transmitters shared for BPCS and SIS
SIS Instrument Sharing – Transmitters Shared for BPCS and SIS Example
