Reading: Instrument Percent of Span Error
Inst Tools > Blog > Basics > Instrument Percent of Span Error
Last updated: February 11, 2020 3:36 pm
Basics Formulas
2 Min Read
An important part of performing instrument calibration is determining the extent of an instrument’s error. Error is usually measured in percent of span.
Instrument Percent of Span ErrorPercent of Span Error Formula
Calculate the percent of span error for each of the following examples, and be sure to note the sign of the error (positive or negative):
Question 1:
Calculate the percent of span error for Pressure gauge as per the below details.
LRV = 0 PSI
URV = 100 PSI
Test pressure = 65 PSI
Instrument indication = 67 PSI
Question 2:
Calculate the percent of span error for weigh scale as per the below details.
LRV = 0 pounds
URV = 40,000 pounds
Test weight = 10,000 pounds
Instrument indication = 9,995 pounds
Question 3:
Calculate the percent of span error for thermometer as per the below details.
LRV = -40 o F
URV = 250 o F
Test temperature = 70 o F
Instrument indication = 68 o F
Question 4:
Calculate the percent of span error for Ph analyzer as per the below details.
LRV = 4 pH
URV = 10 pH
Test buffer solution = 7.04 pH
Instrument indication = 7.13 pH
Answer 1
Error = +2 % of span
Answer 2
Error = -0.0125 % of span
Answer 3
Error = -0.69 % of span
Answer 4
Error = +1.5 % of span
Credits: Tony R. Kuphaldt
  • Pressure Transmitter Calculations
  • Flow Meter Calculations
  • Calculate Current 4-20 mA
  • Temperature Transmitter Output
  • Smart Transmitter Formula
Remote Seal Transmitters Ranging Calculation
Calculate Temperature Coefficient of RTD
Calculate Flow Coefficient Kv of Solenoid Valve
Instrumentation Symbols Legend
Relay Operation, Types, Symbols & Characteristics
What is Process Control?
Formulas to calculate mA from PV, LRV and URV
Formula for Percentage to Process Variable Conversion
Calculate Process Variable from Transmitter Current
Linear to Square Root Extraction
How to Convert Current to Voltage using Resistor ?
Formula for Linear % to Square root % conversion
Calculate Control Valve Stem Position
Instrumentation Basics - Range Conversion Formula and Examples
Instrumentation Basics – Range Conversion Formula and Examples
GuideLines for Loop Checks
How to Do Loop Checks During Plant Pre-Commissioning
4-20mA to Process Variable conversion
Formula to Calculate Process Variable from 4-20mA
Formula for 4-20mA from 3-15PSI
Formula to Calculate 3-15psi from 4-20mA Current
4-20mA Transmitters Easy Calculations
4-20mA Transmitters Calculations
Scaling Sensor Output to Engineering Units
how-a-4-20ma-transmitter-works
How a 4-20mA Transmitter Works?
Why 4-20 mA Current Signal is used instead of Voltage Signal
Why 4-20 mA Current Signal is used instead of Voltage Signal?
Sharing data between two PLC systems
Distributed IO Sharing Between PLC Systems – Technical Insights
DC Machines Circuit Model Objective Questions
Valve Face to Face Dimension
Face to Face Dimension of Control Valve
Electronic Devices & Circuits Quiz – Set 2
RTD installed after the Orifice Plate
Why RTD installed after the Orifice Plate ?
BCD Adder Objective Questions
Instrumentation Project Engineers Interview Questions
Instrumentation Project Engineer Interview Questions
