Reading: Instrument Document Quiz
Inst Tools > Blog > Instrumentation MCQ > Instrument Document Quiz
Take our instrument document quiz featuring questions and answers on control loops, and wiring diagrams to test your technical knowledge.
Last updated: July 26, 2024 10:02 am
Instrumentation MCQ
8 Min Read
Instrument Document QuizWhat document lists all the instruments and their tag numbers used in a project?Which document visually represents the control loops in a system?Where are the technical specifications and operational details of an instrument recorded?What document provides a graphical representation of the piping and instrumentation of a process system?Which document details the wiring and connection information for instruments?What document is used to standardize the design and layout of instrument installations?What information is typically found in GA Drawings?Which document lists all terminals and wiring in a junction box?What is the purpose of Logic Diagrams?What do Cause and Effect Diagrams represent?Which test verifies the functionality of equipment before delivery?What is the main goal of SAT?What is a primary difference between P&ID and Loop Diagram?Which document outlines routine checks and maintenance activities for instruments?What document provides calculations to determine the appropriate valve size for a process?Which documentation is essential for ensuring equipment is suitable for explosive environments?Which document describes the functional relationship between system components?What document includes the list of I/O signals for the control system?Which component is commonly found in a Loop Diagram?What component indicates the measurement point in a Loop Diagram?Which document is essential for troubleshooting instrument issues in a control system?What type of information is detailed in an Instrument Specification Sheet?What is the purpose of a Process Flow Diagram (PFD)?Which document is essential for verifying the proper functioning of an instrument after installation?What does a Control Narrative document describe in instrumentation?Which document would you use to verify the performance of a newly installed instrument?What is detailed in an Instrument Cable Schedule?What does an Alarm and Trip Settings Document specify?
The below video provides you with the explanations for the instrument document quiz.
Instrumentation Documentation
Question 1
A. P&ID
B. Instrument Index
C. Loop Diagram
D. Data Sheet
Show the Answer
Instrument Index
Question 2
A. Instrument Specification
B. Instrument Index
C. P&ID
D. Loop Diagram
Show the Answer
Loop Diagram
Question 3
A. Data Sheet
B. Hook-Up Diagram
C. Loop Diagram
D. Instrument Index
Show the Answer
Data Sheet
Question 4
A. Calibration Report
B. Data Sheet
C. Loop Diagram
D. P&ID
Show the Answer
P&ID
Question 5
A. Data Sheet
B. Loop Diagram
C. Instrument Index
D. Wiring Diagram
Show the Answer
Wiring Diagram
Question 6
A. Loop Diagram
B. Hook-Up Diagram
C. Data Sheet
D. Instrument Index
Show the Answer
Hook-Up Diagram
Question 7
A. Equipment layout and dimensions
B. Control loop connections
C. Spare parts list
D. Calibration procedures
Show the Answer
Question 8
A. Instrument Index
B. Junction Box Schedule
C. GA Drawings
D. Hook-Up Diagram
Show the Answer
Question 9
A. List spare parts
B. Illustrate control logic and sequences
C. Detail calibration steps
D. Show equipment layout
Show the Answer
Question 10
A. Process control trends
B. Validate system functionality
C. Instrument control characteristics
D. Safety interlocks and responses
Show the Answer
Question 11
A. SAT
B. FAT
C. Performance Test
D. Calibration Test
Show the Answer
FAT
Question 12
A. Verify field wiring
B. Test equipment at the manufacturing site
C. Schedule preventive maintenance
D. Validate system functionality on-site
Show the Answer
Question 13
A. P&ID focuses on calibration, Loop Diagram focuses on installation
B. P&ID shows wiring details, Loop Diagram shows process layout
C. P&ID details individual loops, Loop Diagram details system flow
D. P&ID shows system flow, Loop Diagram shows control loop connections
Show the Answer
Question 14
A. GA Drawings
B. Calibration Report
C. Data Sheet
D. Preventive Maintenance Schedule
Show the Answer
Question 15
A. Valve Sizing Calculations
C. GA Drawings
D. Valve Installations Document
Show the Answer
Question 16
A. Ex Equipment Documentation
C. Loop Diagram
D. Data Sheet
Show the Answer
Question 17
A. P&ID
B. Loop Diagram
C. Functional Specification
D. Data Sheet
Show the Answer
Question 18
A. Junction Box Schedule
B. Data Sheet
C. P&ID Document
D. I/O List
Show the Answer
I/O List
Question 19
A. Piping Isometrics
B. Control Valve
C. Process Flowline
D. Equipment Layout
Show the Answer
Control Valve
Question 20
A. Equipment Layout
B. Transmitter
C. Piping Isometrics
D. P&ID
Show the Answer
Transmitter
Question 21
A. P&ID
B. Instrument Index
C. Hook-Up Drawing
D. Loop Diagram
Show the Answer
Loop Diagram
Question 22
A. Installation procedures
B. Detailed instrument characteristics
C. Control system logic
D. Maintenance schedules
Show the Answer
Question 23
A. To display detailed wiring connections
B. To show the control system logic
C. To illustrate the main process flow
D. To list instrument specifications
Show the Answer
Question 24
A. Instrument Test Record
B. P&ID
C. Hook-Up Drawing
D. Calibration Procedure Document
Show the Answer
Question 25
A. Instrument maintenance schedules
B. Process control logic and operation
C. Instrument wiring connections
D. Instrument tubing document for valves
Show the Answer
Question 26
A. Calibration Certificate
B. Hook-Up Drawing
C. GA Diagram
D. Instrument Data Sheet
Show the Answer
Question 27
A. Instrument power cable consumptions
B. Instrument cable sizing calculations
C. Control system logic for the instrument cables
D. Cable types, lengths, and termination points
Show the Answer
Question 28
A. Logic for automatic generation of alarms
B. Control document for forcing the alarms
C. Conditions for triggering alarms and trips
D. Provides long term storage for alarms and trips
Show the Answer
  • Instrumentation Engineer Activities
  • Electrical and Instrumentation Documents
  • Measurements and Instrumentation MCQ
  • Measuring Instruments Questions and Answers
  • Instrumentation and Control Professionals Quiz
Safety Instrumented Systems Online Exam
Radio Telemetry Objective Questions
Multiplexers and Demultiplexers Objective Questions
111 Industrial Automation Acronyms Questions and Answers
Nuclear Power Plant Multiple Choice Questions
62 Proximity Switch Questions and Answers
Analog to Digital Converters Objective Questions
Gyroscope Objective Questions
Time Division Multiplexing Objective Questions
Magnetostrictive Transducers Objective Questions
Thermocouple Temperature Range Questions and Answers
Stepper Motor MCQ
Test and Electrical Measurement Objective Questions and Answers
100 Test and Electrical Measurement Objective Questions and Answers
Questions and Answers on Valves
Valve Quiz
Density Measurement Objective Questions
Pneumatic Control Mechanisms Objective Questions
Measurements & Instrumentation Quiz – Set 8
Chemical Sensors Objective Questions
Analog Demodulators Objective Questions
Frequency Measurement Objective Questions
AC Induction Motor Construction
Basics of AC Induction Motors
Skin Type Thermocouple
Comparison of Temperature Sensors - Industrial Process Control
de-energized-to-safe-mode
OSI Reference model
SCADA Communication and Protocols
Instrumentation Engineer’s Calibration Mistakes
Tagging Philosophy for Junction Box
Tagging Philosophy for Junction Box, Cable, and Cable Drum
