Reading: Infrastructure Monitoring in Your Business Operations
Inst Tools > Blog > Common > Infrastructure Monitoring in Your Business Operations
In this post, we will learn the concept of infrastructure monitoring in your business operations using automation solutions.
Last updated: May 7, 2024 3:41 pm
Common
6 Min Read
In today’s time, when you work in a business sector, IT or information technology service is a very important part of it. All of your data is handled by IT service and you literally cannot survive without its proper working.
What is IT infrastructure?How does infrastructure monitoring work?Data CollectionNetwork AdministratorsCommunication MediaAdvantages of infrastructure monitoring
As a result, there arises a need to properly monitor your IT infrastructure in a business for reliable, safe, and long-lasting operations. Also, cyber-attacks are increasing nowadays and you need a robust infrastructure for protecting your data against it. So, the right solution to infrastructure monitoring is a must. In this post, we will see the concept of infrastructure monitoring in your business operations.
IT infrastructure stands for information technology infrastructure. It is the backbone of any digital solution used in a business. Simply said, suppose there are 10 employees in a company working for an employer. The employer sits in a remote location and has given them the required software for running their operations.
Data must be uploaded every day to the employer’s server by the employees for monitoring and handling the operations. The task and processes done to ensure that every software action goes smoothly as planned and is also safe from any cyber-attack is called an IT infrastructure. If it is good, then employees cannot cheat, data will be safe, clients will be happy and ultimately, your business will run well.
Coming to practical terms, companies first build an application, then build ways to protect it, then build ways to upload the data safely on their server, make data accessible to required persons easily, run third-party applications directly on the server, and ensure that it reaches every employee properly, and thus help in improving overall troubleshooting and maintenance activities. For this, the infrastructure will collect and record all the data, and provide a clear picture of that to the engineers.
Nowadays, due to the extended use of cloud computing, the infrastructure is heavily dependent on cloud providers too, like Amazon Web Service, Microsoft Azure, IBM, etc. for good performance. Mere local company infrastructure will not work in this case, because all of your bulk data is handled by them only.
The main components of IT infrastructure monitoring are:
Data Collection
These are data centers, servers and clients, network devices, operating systems, databases, and applications running on a PC. Their task is to collect and record data for sending it to cloud services or other advanced server systems.
This is a human-dependent task, but it is the most efficient. Their task is to provide privileges to users, handle critical data and not allow its access to anyone, control network structure, and convey issues of users and customers to the IT support team.
Communication Media
The most used protocol in network systems is Ethernet. And to communicate data over larger distances, optical fiber communication is a must. After optical fibers, once the data reaches local centers and where laying of cables becomes difficult, wireless communication and 5G technology (depending upon the most current version available in that country) must be adapted.
Now let us simplify how it’s working. First data is collected by sources (metrics, events, logs, and traces) and sent to the cloud for management. There, cloud computing looks after data and uses advanced tools of machine learning or artificial intelligence to study them.
If any issue occurs on the client side (means customer or employee PC), then troubleshooting tools are used by the server. Due to this, the infrastructure is continuously monitored and handled efficiently for utmost customer satisfaction and business management.
  1. Detects potential issues and troubleshoots them before they escalate. This helps in efficient bug-solving skills and helps to retain the business in case of a sudden downtime.
  2. It ensures constant availability and reliability of all services and applications by monitoring their health status in real-time. Due to this, even if a new employee has joined the company, he will quickly get the services, learn them through training tools, and implement them quickly.
  3. You can track precious information like CPU usage, memory speed, network traffic, network bandwidth, and other network resources for efficient management.
  4. As you get alerts on mobiles, you will be able to quickly reach out to the issue and try to solve it. This becomes possible only through a strong mobile network.
  5. Businesses can detect potential cyber security threats and ensure their infrastructure complies with relevant regulations and standards. This helps them to be prevented from any hacking or unauthorized access from attackers.
  6. As you save time in solving issues and managing data quickly, you ultimately save money and this brings a lot of profit to the company.
  • Overview of Industrial Control Systems
  • Security of Industrial Automation Systems
  • Remote Functions in Industrial Control System
  • Pneumatic Systems in the Automotive
  • Instrumentation Common Measurement
Instrumentation documents
What is Chemical Vapor Deposition? – The Ultimate Guide
Why is a Battery used in a Vehicle?
What is a Flange Gasket ?
Smart Transmitters Advanced Diagnostics
Standard Maintenance Procedure (SMP)
What is Linear Electric Motor?
What is an Instrument Skid? – Example of Metering Skid
What is Shielded Twisted Pair Cable? – Advantages, Disadvantages
What is Cloud Computing? Types of Cloud Services, Components
Single Block and Bleed Valve Manifold Operation
Use Dumps to Ace Certbolt Microsoft AZ-204 Exam
Top 10 Podcasts about Electronics
Optical Line Terminal
What is an Optical Line Terminal? – OLT Working Principle
Double-Acting Pneumatic Cylinder Circuit
Pneumatic Cylinder Movement Control with Timer Circuit
Principle of ultrasonic testing
Ultrasonic Testing (UT) : Principle, Advantages, Disadvantages
Difference between Standards and Codes
Difference between Standards, Codes, Specifications, Regulations
Benefits of Pursuing a Degree in Engineering
CNC Machine Tools Problems and Solutions
Common Problems With CNC Machine Tools & Their Solutions
Calculate the Magnitude of Hydrostatic Pressure
Orifice Flow Measurement Formula
Basics of Flow Measurement
siemens plc db addressing
FB Block in Siemens PLC Programming
Density-Measurement-using-DP-Transmitter-for-open-tank
Density Measurement for Open Tank with Constant Level Application
Modern Instrumentation and Control Systems
Instrumentation Engineering Documents
Instrumentation Engineering Documents Questions Answers
Identify Instruments in Piping and instrumentation Diagram
