Reading: How to Troubleshoot Siemens PLC Programs?
Inst Tools > Blog > PLC Tutorials > How to Troubleshoot Siemens PLC Programs?
Last updated: March 4, 2021 12:41 pm
This article is about the PLC programming troubleshooting method. In industrial PLCs where thousands of inputs and outputs are used, and we know how lengthy PLC programs are, depends on the application or plant usage.
Troubleshoot Siemens PLC ProgramsCross ReferenceCall StructureAssignment ListDependency Structure
Some times, People may change the logic parameters unknowingly and it may lead to a fault. Even some faults are created during the logic design stage due to the complexity of the design. The siemens plc software has different handy tools available in it to troubleshoot the faults generated in the programs.
Faults can be like overlapping of addressing, multiple same output instances, memory bit address overlapping,  many times a single program is used to work over and over, etc.
To find out such problems, there are four types of windows available in the siemens software which will help us to troubleshoot the issues.
They are:
  1. Cross Reference
  2. Call Structure
  3. Assignment List
  4. Dependency Structure
Let discuss how to use them in our program for troubleshooting and where to find them in the software.
Cross Reference
Cross-reference is used to find all the digital & analog inputs and outputs used in the logics. It will help us to know about the number of times the I/O’s are used in the program and also take users directly to the specific location of the I/O’s in the logic pages.
Here is an example of one of the programs, in which you can see how the cross-reference table looks like. It contains all the information like addressing, the language of the program, used inputs and outputs, etc.
Cross Reference in Siemens PLC
Call Structure
When you want to know which block is used in programming then call structure is used.
This is a reversal of cross-reference function in which we get to know that how many times SFC, FB block are used in OB (Organization Block) and here we get to know that how many times OB used in SFC and FBs.
Call Structure in Siemens PLC
Assignment List
The assignment list is a very useful feature when it comes to knowing that how many inputs, outputs, timers and counters used in our application and how many of them are still remaining, so we can use them in future logics.
Assignment List in Siemens PLC
Dependency structure is used to show where each and every block used within the programming.
But in step 7 it won’t take you directly on location however in TIA PORTAL it will take you to the location where the program is written.
Dependency Structure in Siemens PLC
NOTE:
To open these windows in step 7, use the info as shown in Drawing. After clicking on display you have the options.
Step 7 Reference Data
In TIA PORTAL, follow the below step shown in the drawing.
TIA Portal Options
Author: Suhel Patel
  • Shift and Rotate Instructions
  • Pumps Control using PLC
  • Edge Detection in PLC
  • Siemens PLC Backup
  • Tiffin Box Filling Station
PLC Memory Mapping and I/O addressing
Difference Between Microcontroller and PLC
Principle of Operation of PLC
How to Program a Star-Delta System using 1 Button in PLC?
What is Relay Logic ?
  • Anandh says:
    November 19, 2020 at 8:53 pm
    Realy good thanks
Top 100+ SCADA Questions
Produced Tags and Consumed Tags in Studio 5000
PLC Emergency Stop Example Program
HMI Screen Design for Hazardous Applications
Use of Isolators and Barriers in Electrical Panel
PLC program pushbutton switches
PLC Programming for Automated Curtain Control
Automatic Curtain Control – PLC Programming Solution
HMI screen for operator
Auto Tiffin Box Filling Station
DCS Marshalling Cabinet
Create Ladder Diagram from Boolean Logic
Compare Servo Motor and Stepper Motor
Programming in Omron PLC
Difference Between Remote IO and Distributed IO Systems
UL 489 Circuit Breaker
Difference Between UL489 and UL1077
Type E Chopper Objective Questions
GC sample loop
Chromatograph Sample Valves
Hydrocarbons Questions & Answers
Safety Instrumented Systems Tutorials
High Reliability of Safety Instrumented Systems
Single Line Diagram
Single Line Diagram
Battery Hazard
Battery Hazards
