Reading: How to Backup and Restore from Simatic Prosave HMI?
Inst Tools > Blog > PLC Tutorials > How to Backup and Restore from Simatic Prosave HMI?
In this article, we will learn how to backup and restore from the Simatic Prosave HMI panel. (Siemens HMI Image and Project Files)
Last updated: October 17, 2023 1:56 pm
3 Min Read
How to Backup from Simatic Prosave HMI?How to Restore the Siemens HMI Backup?
HMI image backup: Non-editable & Non-programmable. Only for the restoration of the same HMI model.
Open Simaticprosave application by double-clicking on the PROSAVE icon
Simatic Prosave HMI
PROSAVE window opens as given below
How to Take Backup from Simatic Prosave Project file
In GENRAL tab, select the HMI type (ex.TP270 10” panel or TP177B panel) in the device type.
Select the connection type either MPI/DP or Ethernet
back up project from a Comfort HMI Panel
Enter the MPI/DP address of the HMI panel which needs to be taken from the HMI control panel in transfer settings MPI/DP advanced settings.
Or
Enter the TCP/IP address of the HMI panel which needs to be taken from the HMI control panel in transfer settings ETHERNET advanced settings
Go to the BACKUP tab, select the backup type as a complete backup.
Select the file name in the required folder in the Save as Tab.
If the communication cable between the HMI panel & Laptop is ok, then put the HMI panel in Transfer mode during rebooting of HMI.
Press the START Backup button to start the HMI image backup.
Siemens HMI image backup
The backup image will be saved in .PSB format in the selected folder.
Open prosave application
Simatic Prosave HMI
In GENERAL tab, select the HMI type (ex.TP270 10” panel) in the device type.
Select the connection type either MPI/DP or Ethernet as per the connecting cable between HMI & the laptop.
Or
Enter the TCP/IP address of the HMI panel which needs to be taken from the HMI control panel in transfer settings ETHERNET advanced settings.
Go to the RESTORE tab, select the filename in the
How to Restore the HMI Backup
Once the communication between the HMI panel & laptop is OK, then press the Start restore button.
Restoration of HMI backup in the new panel will start
Please note that for restore the backup and HMI device should be of the same type.
Credits: PLQP Instrumentation Team
  • Integral Controller Principle
  • What is Resources Tab in the Siemens PLC?
  • How to take Backup from Siemens S7-300 PLC?
  • Allen Bradley SLC 500 PLC Programming
  • Create an Application in HMI using Tia Portal
Automate Batch Mixing with Repeated Cycles in Omron PLC
Siemens S7-300 CPU Suffix Explanation
PLC, DCS, and ESD Marshalling Cabinet Checks
PLC Timer Application in Security Camera Recording
What is Fail-safe in Siemens PLC?
PLC Programming Course Online Free
PLC Logic Functions
PID with Practical Example
Problem on PLC, HMI, VFD, and Motor Circuit
Omron PLC Logic for Washing Machine Automation
PLC Program for Star Delta Starter using Functional Block Diagram
FactoryTalk View Studio – Import and Export Tutorial
Examples of PLC Programming using Boolean Functions
PLC Logic - Control Spray Nozzle, Fans, and Puncher
Communication between Factory IO and Siemens Tia Portal
Difference between Compact PLC and Modular PLC
Control Methods in Servo Motor Drives
Various Control Methods in Servo Motor Drives
PLC Raw Count Calculation formula for Pressure Transmitter
PLC Raw Count Calculation for Pressure Transmitter
Reading Clock data in PLC
Real-Time Clock in Omron PLC? – CX Programmer
relay-safety-in-plc
How to Reduce Relay Noise in PLC Systems?
Example of PID Control Instruction
How to Configure PID in Siemens PLC?
Electronic Meters Questions & Answers
Micro 870 Rockwell PLC
Rockwell Automation Allen Bradley PLC for Smaller and Medium Projects
Flame Cables
Difference Between Flame Resistant and Flame Retardant Cables
What is Eddy Current and Eddy Current Loss
What is Eddy Current and Eddy Current Loss?
Pressure Gauge Datasheet
How to Fill up Instrument Datasheet? – Pressure Gauge Specifications & Standards
Turbine Bypass System
Foundation Fieldbus
Foundation Fieldbus – Advantages, Limitations, Architecture
Submersible Pressure Transmitter
What is a Submersible Pressure Transmitter? Principle, Advantages
