Reading: How do You Select a Pressure sensor?
Inst Tools > Blog > Instrumentation Design > How do You Select a Pressure sensor?
Last updated: March 20, 2019 2:38 pm
2 Min Read
Deciding which pressure sensor to purchase is not an everyday task, and is one that can be confusing. However, the decision is an important one as it will have an impact on the performance, production cost, calibration and service of the entire system.
Selecting the correct sensor for any given application, regardless of whether it is a pressure sensor, temperature sensor or load cell, requires answers to a number of questions.
In case of a pressure sensor, these questions are:
  1. What is the pressure medium?
  2. What pressure will the sensor measure?
  3. How will the sensor interface mechanically?
  4. What is the temperature range (operating/storage)?
  5. How accurate does the sensor need to be?
  6. Does the sensor need to be temperature compensated?
  7. Is stability over time a critical factor?
  8. Do sensors need to be interchangeable from unit to unit?
  9. Does the operating environment demand extra ruggedness?
  10. Is size (for fitting purposes) an issue?
  11. What are the excitation voltage and current applicable?
  12. Is the signal output appropriate for the application?
  13. What electrical connections are required?
  14. Are pressure spikes and/or overload situations possible?
  15. Do you require any approvals?
Cost considerations
Clearly, any sensor chosen that answers all these questions will be technically suitable for the application. However, this “perfect match” could potentially be very expensive. Therefore you may have to widen some of the specifications in order to achieve a target price.
One further very important point is to choose a sensor manufacturer that can manufacture sensors consistently to agreed specifications and in the quantities you require.
Furthermore, if units are required for testing make sure they are from a production batch – not a sensor specifically made as a one-off (unless this has been agreed).
Pressure Control Valves vs Pressure Regulators
Difference between Axial and Radial Diaphragm Seal Connection?
What is a Control Loop ?
Instrumentation and Control (I&C) Design
Solenoid Operated Valves and Latching Valves
Pneumatic Valves and Cylinders Sizing – Part 2
How to Select an Actuator for Valve
Basic Requirements of Control Valves Sizing
Facts on Thermowell Insulation Thickness
How to Select a Inductive Proximity Sensor
Instrument Air Compressor Control Philosophy
How to Fill up Instrument Datasheet? – Pressure Gauge Specifications & Standards
Instrument Air Sizing
Instrumentation and Process Control Project Inputs
Instrumentation and Process Teams Interactions in Design Engineering Companies
Selection Criteria of PH Analyzer
Lube Oil Console
Immersion Heaters in Lube Oil Consoles
Testing of Pneumatic Systems
Conductivity Meter
How to Select a Conductivity Meter
Vendor Selection in Procurement Service Cycle (For Industrial Projects)
Compliance Table Application (for Procurement Service Cycle)
Basics of Thermistors, Thermocouples and RTD's
Basics of Thermistors, Thermocouples and RTD’s
3 to 8 Line Decoder Circuit Diagram
3 to 8 Line Decoder PLC Ladder Diagram
Optoisolator Working Principle
Conductivity measurement
Conductivity Measurement
Series Air Fuel Combustion Control
Combustion Control – Series and Parallel Air-Fuel Ratio Control
Calculate Power in Parallel RL Circuit
Difference Between PLC and CNC Machine
LVR Motor Controller Operation
Low Voltage Protection (LVP) and Low Voltage Release (LVR)
CODESYS open source PLC software
What is CODESYS? Why Do You Need to Learn it?
