Root Cause Analysis (RCA): 8000 RPM, 8000 kW, Turbine Problem Threatened Yearlong Total Fertilizer Complex Outage.
S Raghava Chari
Question on Analytical Controller
The ratio between base flow and pigment flow in this paint-mixing control system is not fixed. Rather, it comes from the output of an “analytical” controller: Analytical Controller 1. Explain the rationale behind this ratio control system. Also, identify what the “other control system” might be that drives the base control valve. Answer: The purpose of this control system is…
Inhouse Moisture separator for Pneumatic Systems
Inhouse Moisture separator to remove moisture content for Pneumatic systems The  moisture content is a specific challenge for the pneumatic system.This needs to be countered  in very effective manner so as to avoid the malfunctioning/probable breakdown .The problem is very dominant in the winter season with humidity playing a big role. Localized drain pots /moisture separators can be a very useful The  challenge of moisture…
Editor's Pick
Flange Types and Definitions
The most used flange types according to ASME B16.5 are Welding Neck,…
Free PDF Downloads: Learn Instrumentation & Control Systems
Free PDF Downloads covering instrumentation basics, process control, and measurement techniques to…
Basics of Venturi Flow Meter
By measuring change in pressure, the flow rate can be determined, as…
IGBT Objective Questions
In this MCQ you can learn and practice IGBT objective quiz questions…
Electrical Static Grounding Techniques
Different types of application sketches showing a few of the electrical static…
Calculate Power in Series RC Circuit
An 80 Ω XC and a 60 Ω resistance are in series…
Electrical Engineering Documents – Engineers Questions
Learn the multiple choice questions for electrical engineering documents to test your…
Root Cause Analysis for Plant Trip Due to Work on Incorrect Tag
We will discuss about the root cause analysis of an incident in…
CO2 Stripper Collapsed Internals Revamp
Renewing the CO2 stripper collapsed internal trays was a recurring and expensive…
S Raghava Chari
What to Watch
View All
