Reading: History of 3-15 psi, 10-50 mA, and 4-20 mA signals
Inst Tools > Blog > Instrumentation Design > History of 3-15 psi, 10-50 mA, and 4-20 mA signals
Study about the history of 4-20 mA signals used in the industrial instrumentation. Other signals are 3-15 psi, and 10-50 mA
Last updated: September 19, 2020 5:37 pm
2 Min Read
Before 4-20 mA the signals were 3-15 psi and 10-50 mA. These signals all have a ā€œlive zeroā€ (3 psi, 10 mA, and 4 mA) rather than a ā€œdead zeroā€ (0 psi, 0 mA) which can be used to detect a severed pneumatic tube or signal wire.
3-15 psi Pneumatic Signal10-50 mA Analog Electronic Signal4-20 mA Analog Electronic Signal
The live zero can also be used to power a 2-wire loop-powered device. 3-15 psi, 10- 50 mA, and 4-20 mA etc. all have a ratio of 1:5 (20% bias).
Nobody remembers the exact reason why the signal ranges 3-15 psi, 10-50 mA, and 4-20 mA were selected and there appears to be no definite source documenting this decision such as minutes of meeting from a standards committee.
Some research has uncovered the following technical reasons why these signal ranges were chosen.
Pneumatic instruments operate on the flapper-nozzle (baffle-nozzle) principle. It appears 3-15 psi with the 1:5 ratio was chosen because it the most linear portion on the curve for the movement of the flapper (baffle) and the backpressure resulting in the nozzle.
Early analog electronic instruments used magnetic amplifiers. 10 mA live zero was chosen as it is the lowest at which instrument based on magnetic amplifiers could operate. Maintaining the 1:5 ratio the signal was chosen 10-50 mA.
With the introduction of the transistor, it became possible to make devices operating on 4 mA. Thus the signal was chosen 4-20 mA maintaining the 1:5 ratio. With the introduction of microprocessors in instrumentation and digital communication, the HART protocol was introduced superimposed over the 4-20 mA signal.
The HART commands supported by the device, how device information is displayed, and the wizards to make tasks like calibration easy, etc.
Also, Click here to read the advantages of the 4-20mA signal.
Source: Eddl.Org
Package Control and Safety Systems Implementation Methods
How to Select a Rotameter? – Parameters and Applications
Orifice Sizing Guidelines and Thumb Rules with Flowchart
Pneumatic Valves and Cylinders Sizing – Part 1
Difference between DCS & PLC Systems
Pressure Control Valves vs Pressure Regulators
  • dan says:
    May 14, 2017 at 6:57 am
    Why we use a standard of 4-20 mA ?
    A 4-10mA corresponds to a 1-5V analog voltage across a 250 Ohm resistor, making it easy to adapt the 4-20mA current loop to a 1-5VDC analog input voltage (common on many controllers using TTL inputs) to by simply placing a 250 Ohm resistor across the analog input terminals of the controller.
    The industry specification for Compatibility of Analog Signal for Electronic Industrial Process Instruments is ISA 50.00.01-1975 (R2012). The pre-1972 version of this standard specified 10-50mA for analog current loops because the technology at the time used magnetic amplifiers which required a minimum of 10mA to operate.
    Since transistor circuits have become more stable and accurate, the 4-20mA analog current loop has become the standard, requiring less power and allowing greater distances.
    Of course, if you aren’t already aware, one of the main advantages of current loop over voltage driven analogue signals is that a current driven loop allows greater distances to be achieved – typically lengths up to 1000m are possible.
    Any signal sent over a long distance produces a voltage drop which is in proportion to the length of the cable (cable resistance), however when a 4-20mA signal is used to transmit the analog signal (as opposed to a 1-5VDC signal), the voltage drop is irrelevant, since the same current has to pass through the circuit loop (it has no where else to go!) provided the power supply can handle it. For example, for a 24VDC powered transmitters, 7-15VDC is typically used by the transmitter circuit, leaving a budget of at least 9VDC for the loop voltage drop.
    You may already be aware that having a non-zero current (4mA) for representing the “zero value” of the analog signal allows the controller to detect a broken wire (0mA) as well as allowing loop-powered transmitter design.
    Having the 20mA correspond to the ‘maximum value’ of the analog signal is practical for industrial process instruments, since having larger currents would result in larger voltage drop for the same size cabling, thereby limiting the cable length.
    Also, limiting the power of signals in the transmitter is better for ‘intrinsically safe design’ by limiting the energy available for igniting explosive dust or vapors in hazardous areas (as per ANSI/ISA-RP12.06.01-2003 Recommended Practice for Wiring Methods for Hazardous (Classified) Locations Instrumentation Part 1: Intrinsic Safety).
    Source : stackexchange
Pressure Gauge Problems
Safety Instrumented System Module Failure
What is SAMA Diagram?
Control Room Design Guidelines
System Architecture and Process Control Systems Philosophy
How to Calculate Heat Load in Electrical/Electronic Panel Enclosure
Cable Tray Routing
Cable Routing
Relay Circuit for Hooter with Reset Button
Relay Latching Circuit using Push Button
Remote Seals Transmitters Temperature Error
Remote Seal Transmitters Temperature Error
Fail Safe Switch Circuit
Basics of Fail-safe Circuits
pressure switch control two lamps wiring
Draw Wiring of a Pressure Switch to control two lamps
Axial Diaphragm Seal Connection
Difference between Axial and Radial Diaphragm Seal Connection?
Failsafe interlock Design
Failsafe Wiring Practices
Instrumentation During the Detail Design Phase
Turbine Flow Meter (TFM) Field Calibration
Turbine Flow Meter (TFM) Field Calibration Uncommon Request
Water Vapor in Instrument Air Lines
How to Minimize Water Vapor in Instrument Air Lines?
Differential Pressure Sensor with pair of Strain Gauges
Differential Pressure Sensor with Pair of Strain Gauges
Strain Gauge Pressure Sensor Principle
TOC Analyzer Principle
Total Organic Carbon Analyzer Principle
Demister Pads Problem
Problems with Demister Pads – Root Cause Analysis (RCA)
Electromagnetic Flow Meters Working Principle
11 kV, 3.3 kV, and 400 V systems insulation resistance (IR) Problems
