Reading: Heat Detector Testing Procedure
Inst Tools > Blog > Fire & Gas System > Heat Detector Testing Procedure
Study about the general testing, calibration, or healthiness checking procedure of a heat detector in the fire and alarm system.
Last updated: September 2, 2020 11:35 am
Fire & Gas System
3 Min Read
Here in this article, we discussed the general testing or healthiness checking procedure of a Heat Detector which is used in the fire and gas system.
Before starting the job, take the proper work permit and inform to all the respective departments. Then do force the respective logics or interlocks if any (like fire suppression systems activation etc)
  • Prior to testing of Heat detector see the LED status of the Heat Detector it should be blinking red.
  • Check the voltage of the Heat Detector, it should be + 30 Volts DC. This can be checked by the addressable base of the detector. (Digital type detector).
  • Now Heat Detector is healthy and it is ready for testing.
  • Clean the Heat Detector’s dust by cotton cloth and blower
  • Apply the heat to the Heat Detector by solo heat-detecting gun.
  • Keep applying heat for 10 seconds.
  • After 10 seconds LED status of the Heat detector is changing from steady blinking red to steady red and after that alarm appears and the hooter is activated on the fire alarm panel.
  • To silence the hooter press the acknowledge key to the Fire Alarm Panel.
  • After the alarm appears remove the heat-detecting test gun from Heat Detector.
  • Note down the alarm tag and descriptions from the HMI or workstation. The alarm details must match with the heat detector tag number and installed location.
  • Confirm the heat detector activation status from the respective graphics page. You have to visually identify the color change signals of the respective heat detector on the graphics.
  • Reset the alarm of the Heat detector from the Fire Alarm Panel.
  • The LED status is changing from steady red to blinking red.
  • Heat Detector is now working normally.
  • Repeat the above procedure for all the remaining Heat Detectors.
  • Normalize the forced interlocks or logics if any.
  • Close the work permit.
Note: The mentioned voltages, terminals, circuit module names may change as per the vendor or model of the Heat Detector.
Author: V Hemanth
  • Toxic Gas Detectors
  • Rate Compensated Heat Detector
  • Fixed Temperature Heat Detector
  • Active Fire Protection
  • Fire Detection System
Fire Extinguishers Mock Test
Gas Detection System Abbreviations
Infrared Open Path Gas Detectors Working Principle
Argonite Fire Suppression System Working Principle
Infrared Gas Detectors Working Principle
What are Linear Heat Detectors?
What is Bump Testing ?
Basics of Fire Detection and Alarm System
What is Manual Call Point (MCP) ?
Sensor Technologies in Gas Detectors
Rate of Rise Thermal Detectors Working Principle
Types of Fire and Gas Detectors
Gas Detectors Interview Questions & Answers
How to use Fire Fighting Hydrant
Fire and Safety
Sprinkler System
Basics of Sprinkler System
LEL vs Percent By Volume vs Parts Per Million vs Parts per Billion
Purpose of End of Line (EOL) Resistor in Fire & Gas System ?
Why we use End of Line (EOL) Resistor in Fire and Gas System ?
Smoke Detection System Questions
Interview Questions on Smoke Detection System
Carbon Monoxide Gas Hazards
Spot Type Fixed Temperature Heat Detector Principle
Fixed Temperature Heat Detector Working Principle
Flame Detector Testing Procedure
Induction Motor Interview Questions Answers
input-output-relationships-of-transmitters
Input-Output Relationships of Transmitters
What is a Magnetic Field
Difference Between Electric Field and Magnetic Field
Role of Flow Meters in a Laboratory
How a Level Switch Works
Cable Float Level Switch Principle
Cable Float Level Switch Working Principle
Phase Watcher Multiphase Flow Meter (MPFM) Procedure
