Reading: What is a Ground Rod?
Inst Tools > Blog > Basics > What is a Ground Rod?
Ground Rod is used for grounding purposes to prevent the electrical devices from lighting current and static electricity.
Last updated: April 18, 2023 10:10 am
Basics Electrical Basics
2 Comments
6 Min Read
We all know that grounding is required in an electrical system, to pass the leakage current to the earth and prevent the equipment and personnel from damage.
What is a Ground Rod?What are Ground Rods made of?
Without proper earthing, there is always a chance of the equipment and devices getting damaged, if there is any overcurrent or high surge. So, it is necessary to connect ground wires from the equipment to the earth.
When it comes to grounding, there is one type of leakage current which is very damaging when not controlled; it is lighting current and static electricity. To deal with them, a device is installed with the earth system. It is called a ground rod. In this article, we will learn the concept of a ground rod.
As the name implies, it is a rod which is used for grounding purposes. The ground rod special purpose use is to prevent the electrical devices from lighting current and static electricity (it is an imbalance of electric charges within or on the surface of a material or between materials.
Ground Rod
The charge remains until it is able to move away by means of an electric current or electrical discharge). What happens is that when some high voltage surge like lightning strikes the electrical equipment, the very high spark or surge can damage the body or cause shock to the person touching it. To prevent this, a wire from equipment (ground point) is connected to the ground rod. The rod is buried inside the ground. It is placed near the equipment.
When the lighting strikes, the high leakage current will flow from the ground point in the device to the ground rod. As the rod has a very high impedance or resistance, it will not flow inside the ground from that rod to some another nearby rod. If the resistance was low, then the current will find it’s path from one ground rod to another; and if that other ground rod was connected to some device, then the return current will damage that equipment. So, the ground rod is made such that is has a very high resistivity to the current.
When one thinks that if the wire is anyhow connected to the ground rod, then why is the need to worry about the current flowing through some other rod? The answer is that electricity tries to get back to its source. It doesn’t just go into the Earth. And as there is a ground Rod at the transformer (mostly ground rod is connected to the neutral of a transformer), then there is a potential path for the electricity to get back to the source. So, the resistance of the ground rod must always be considered before installing it.
Ground rods are made of mostly three materials – copper, stainless steel and galvanized steel. The most famous one is that of a copper. Copper ground rods are said to have a very long life, but is equally expensive. If you want some cheaper type, then look for a stainless steel type. It is known to be especially corrosion-resistant, making it the preferred option in, especially salty environments; though having life smaller than a copper one. Galvanized ones are the least used, due to shorter life and more prone to corrosion; but they are the cheapest ones available.
Ground rods must be properly installed inside the soil. If the rod is somewhat placed above the soil (not fully, but only a small top part), it reduces the effectiveness of the ground. Ground rods that are bent over, have disconnected wires or are severely corroded must be replaced. If soil conditions change due to drainage or other factors that affect soil moisture, a ground rod that was acceptable at the time of installation may no longer meet approved requirements.
So, maintaining ground rod is equally necessary. Mostly, ground rods are installed vertically, it is practically very difficult to install it horizontally.
We don’t have any precise specifications as to where exactly a ground rod should be installed in a location. The best option is to install at least two feet away from a building structure to avoid causing any potential interferences. It is recommended to install it somewhat close to your electrical panel. You will also want to make sure that the ground rod is installed in a space that is accessible and easy to work in.
  • What is a Buchholz Relay?
  • Importance of Neutral Wire
  • Induction Motor Problems
  • Cables between VFD & Motor
  • What is a Current Transformer?
Polarization Index (PI) Test and DA Test
What is Floating Neutral? – Electrical Engineering Basics
What is Arc Protective Clothing? – Importance, Features, Materials
How does an Electric Motor Operate? – AC Motor Fundamentals
What is the Difference Between Sensor and Transducer?
2 Comments
  • Ismael says:
    April 4, 2023 at 1:16 pm
    Greetings. I am an electrical engineer. I am very impressed with the publication. I wish you progress and prosperity
  • Balajee Balajee says:
    March 24, 2024 at 12:11 am
    any update send me on email
Why is HV Testing important in Electrical Panels?
Difference Between Open Circuit and Close Circuit
What is Variable Air Volume Controller in HVAC?
Motor Control Timer Circuit – Automatic Motor START and STOP
Difference Between Short Circuit and Ground Fault
Instrumentation Abbreviations
Difference between Current Transformer and Potential Transformer
Difference Between AIS and GIS Panels
How do AC drives work
How do AC Drives Work? – Variable Frequency Drive (VFD)
Acceptable Earth Resistance Values
Types of Circuit Breakers
Types of Circuit Breakers, Advantages, Disadvantages
Variable Frequency Drive - Converter
Variable Frequency Drive (VFD) Working Principle
Shutdown Manager
What are Pre-Shutdown, Shutdown, and Post-Shutdown?
Motor Slip Calculation
Electrical Motor Terms and Concepts
Humming Sound in Transformer
Why is the Humming Sound Produced in Transformer?
Analytical Instrumentation Engineering Projects
Top 100 Analytical Instrumentation Engineering Projects
Loop Power Indicator Principle
Basics of Loop Powered Devices
Ladder Logic Programming Examples
UDT in the PLC Programming
Implement UDT in PLC Programming: User-Defined Data Type
How PLC controls a ON-OFF Valve
PLC Valve Control Ladder Logic Programming
Open Loop and Closed Loop System Questions
LRV and URV of PT for Extreme Limits of Empty and Full
