Reading: How Nuclear Radiation is used to Measure Coke Dust Level?
Inst Tools > Blog > Practical Questions > How Nuclear Radiation is used to Measure Coke Dust Level?
The level of coke dust inside the bin is measured by a gamma radiation nuclear instrument and how it works?
Last updated: January 18, 2021 7:46 pm
Practical Questions
1 Min Read
A coke calcining operation (where petroleum coke is burned to decrease its hydrogen content) uses a large bin to collect coke dust that forms around its hooded conveyor systems.
The level of coke dust inside this bin is measured by a gamma-radiation instrument:
Gamma Radiation Level Instrument
1. Explain how this system uses nuclear radiation to measure coke dust level?
2. Why does this system use multiple radioactive sources? Why do you suppose one is not sufficient?
3. Suppose some radioactive material accidently entered the storage bin along with coke dust. Would this shift the level instrument’s zero, the span, or both?
4. Identify some alternative technologies which we could use to measure the coke dust level.
5. What function does a cyclone separator perform, based on an analysis of this simple process flow diagram?
Note: cyclone separators are commonly used in sawmill operations, to handle wood chips in a moving air stream.
  • Transmitter 5 Way Manifold
  • Distillation Tower Level
  • Tank Pressure Transmitter
  • Level Measurement Lab
  • Level Sensor Specifications
Credits: Tony R. Kuphaldt
LRV and URV of PT for Extreme Limits of Empty and Full
Analytical Process Control Question
PLC connected to Three Pushbutton Switches
Pressure Transmitter Re-Range Questions
Questions on Pressure Transmitter Calibration Setup
Programmable Logic Controller (PLC) Questions and Answers – 6
Resistance Temperature Detector (RTD) Questions – 2
Three-valve Manifold on Remote Seal DP Transmitter
10 Questions on Reforming Furnace Control System
Diagnosing Electric Motor Circuit
Determine Effect of Each Fault for Pneumatic Force-balance System
Calculate the Thermocouple Output millivolts
Calculate the Voltage across Voltmeters of Thermocouple
Questions on Radar LT Loop Diagram
Determine Resistance value of Resistors
Vehicle Electrical Batteries upgrade
Upgrading the Electrical System in an Automobile
Programmable Logic Controller (PLC) Questions and Answers – 7
Foxboro model 13 DP transmitter
Re-calibrate the Foxboro DP Pneumatic Transmitter
pH Monitoring System Triggers an Alarm
Heat Exchanger Differential Pressure Transmitter
Double Block and Bleed Valves Opening or Closing Sequence
process conditions, Find out the Circuit Components Status
As per Process Conditions, Find out the Circuit Components Status ?
What is Ladder Diagram Programming ?
Draw the Symbols for Liquid Level Measuring Instruments
PLC Program for Washing Machine
Profibus Listener Principle
Profibus Listener
PID parameters
PID in Siemens TIA Portal
Shorted Parallel Circuit
Parallel Short Circuit Faults
Does Really a Safety Barrier is Important
Does Really a Safety Barrier is Important? – PLC DCS Systems
FF JB Termination
Foundation Fieldbus Installation and Best Practices
