Reading: Gamma Camera Questions & Answers
Inst Tools > Blog > Multiple Choice Questions > Gamma Camera Questions & Answers
1. The first gamma camera is also known by which of the following names?
a) Hal camera
b) Anger camera
c) Muller camera
d) West camera
Answer: b
Explanation: The first gamma camera is also known as Anger camera. It was developed by Hal Anger.
2. Which of the following is not a component of gamma camera?
a) Collimator
b) Detector crystal
c) Pre-amplifier
d) Position logic circuit
Answer: c
Explanation: Pre-amplifier is not a component of gamma camera. It is an imaging device commonly used in medical applications.
3. Which of the following is the first object that an emitted gamma photon encounters after exciting
the body?
a) Collimator
b) Detector crystal
c) Photo multiplier tubes
Answer: c
Explanation: Collimator is the first object that an emitted gamma photon encounters after exciting the body. In the conventional method, the collimator is placed over the detector crystal.
4. Which of the following is a pattern of holes through gamma ray absorbing material, usually lead or tungsten?
a) Collimator
b) Detector crystal
d) Position circuitry
Answer: a
Explanation: Collimator is a pattern of holes through gamma ray absorbing material, usually lead or tungsten. In the conventional method, the collimator is placed over the detector crystal.
5. When energy of an absorbed gamma photon is released, a flash of light is produced. This is similar to which of the following effects?
a) Photoelectric effect
b) Compton effect
c) Pair production
d) Collision effect
Answer: a
Explanation: The given effect is similar to photoelectric effect. It occurs in scintillation detector.
6. Which of the following components adds all the signals and determines where each scintillation event occurred in the detector?
a) Collimator
b) Detector crystal
Answer: d
Explanation: Position circuitry adds all the signals and determines where each scintillation event occurred in the detector. It is an electronic circuit and it receives all the signals from photo multiplier tube.
7. Gamma camera uses one scintillation detector. Is this statement true or false?
a) True
b) False
Answer: b
Explanation: Gamma camera uses multiple scintillation detectors. Hence, it is also known as scintillation camera.
8. Gamma camera uses which of these components to produce a position intensity picture of radioactive area?
a) Collimator
b) Scintillation detector
Answer: b
Explanation: Gamma camera uses scintillation detector to produce a position intensity picture of radioactive area. It is an imaging device commonly used in medical applications.
9. Which of the following is known as a scintillation counter?
a) Scintillator
b) Scintillator along with a photo multiplier tube
c) Scintillator along with the crystal
d) Scintillator along with position circuitry
Answer: b
Explanation: Scintillation detector along with a photo multiplier tube is known as scintillation counter.Scintillation is the process of turning radioactive energy into light using a scintillator.
10. Straight bore collimator is used for thyroid work in medical field. Is this statement true or false?
a) True
b) False
Answer: b
Explanation: Straight bore collimator is used for liver, brain, etc. Pinhole collimator is used for thyroid work.
Tuning of PID Controllers
Ionization of Gases Questions and Answers
Closed-Loop Frequency Response
Measurement and Instrumentation Objective Questions – Part 1
Ammonia and Fluoride Electrode Questions & Answers
Inductively Coupled Plasma Mass Spectrometer
Sodium Analyzer Questions & Answers
Fuzzy Logic Control
Parameter Optimization : Servomechanims
Concepts of State, State Variables & State Model
DC Circuits Multiple Choice Questions
Electron Probe Microanalyser Questions & Answers
Liapunov’s Stability Criterion – Part I
Feedback Control Questions & Answers
Feedback Control Loop Questions & Answers
Control of the Effects of Disturbance Signals by Use of Feedback
Nonlinear Control Systems
Constructing Phase-Trajectories
Sensivity Enhancement for NMR Spectroscopy Questions & Answers
X-Ray Spectroscopy Questions & Answers
Control Systems Stability and Algebraic Criteria
Concept of Stability in Control Systems
Advances in Control System
Neural Networks
Process Control Questions & Answers
Fuel Boiler
Boilers
Float Level Measurement
Types of Level Measurement
Electronic Devices & Circuits Quiz – Set 15
Advantages and Disadvantages of Network Topologies
Turbidity Sensor Calibration Procedure
vortex flow transmitter
What is a Vortex Flow Meter?
Ultrasonic Flow meters Working Animation
Ultrasonic Flow Meters Animation
