Reading: Foundation Fieldbus Signal Conversion Formula
Inst Tools > Blog > Communication > Foundation Fieldbus Signal Conversion Formula
Last updated: January 6, 2019 8:53 am
Communication
2 Min Read
Every foundation fieldbus transmitters have mainly two types of scales or ranges. one is XD scale & second one is OUT Scale.
Transducer scaling (XD_SCALE) is applied to the value from the channel (sensor measurement) to produce the FIELD_VAL in percent.
The OUT_SCALE is normally the same as the transducer, but if L_TYPE is set to Indirect or Ind Sqr Root, OUT_SCALE determines the conversion from FIELD_VAL to the output. OUT_SCALE provides scaling for PV.
The PV is always the value that the block will place in OUT if the mode is Auto.
You can set the signal conversion type with the Linearization Type (L_TYPE) parameter.  You can view the converted signal (in percent of XD_SCALE) through the FIELD_VAL parameter.
You can choose from direct, indirect, or indirect square root signal conversion with the L_TYPE parameter
Direct
Direct signal conversion allows the signal to pass through the accessed channel input value (or the simulated value when simulation is enabled)
PV = Channel Value
Indirect
Indirect signal conversion converts the signal linearly to the accessed channel input value (or the simulated value when simulation is enabled) from its specified range (XD_SCALE) to the range and units of the PV and OUT parameters (OUT_SCALE).
Foundation Fieldbus Indirect Formula
Indirect Square Root
Indirect Square Root signal conversion takes the square root of the value computed with the indirect signal conversion and scales it to the range and units of the PV and OUT parameters.
Foundation Fieldbus Indirect Square Root Formula
All About Fieldbus Protocols
What is a Fieldbus Terminator and How Does it Work?
How Modbus Communication works
Difference Between LAN and WAN Networks
Actuator Sensor Interface (ASi) Protocol in PLC
Difference Between Subnet and VLAN
WirelessHART device Configuration
Difference between TCP/IP Model and OSI Model
History of OPC Protocol
Fiber Optic Cable Testing
Foundation Fieldbus Electrical Parameters
Top 10 Facts about HART Technology
Multi-mode optical fiber
Multi-mode and Single-mode Optical Fibers
WirelessHART Principle
Wireless HART Communication Protocol Overview
FF Function block Modes
foundation-fieldbus-vs-profibus
Comparison between Foundation Fieldbus and Profibus
Foundation Fieldbus Interview Questions and Answers
Compare Serial and Parallel Communication
Difference Between Serial and Parallel Communication
What is a Network
What is a Network ?
PID control block located in fieldbus transmitter
Foundation Fieldbus Device addressing
Instrument Technician Interview Questions
Instrument Technician Interview Questions and Answers
solenoid-valves-types-principle-animation
Solenoid Valves Types, Principle & Animation
Optical Pyrometer
Optical Pyrometer Working Principle
Loop Diagram
PT Loop Diagram Faults
HMI configuration for Delta VFD
Modbus Communication between Delta PLC with VFD
Why rating of Synchronous Generators and Alternators in MVA or KVA
P&ID arrangement for Pressure Safety Valves
P&ID Guidelines for Pressure Safety Valves
Pull Cord Switch Principle
Pull Cord Switch Working Principle
