Reading: Principle of Flow Switch
Inst Tools > Blog > Flow Measurement > Principle of Flow Switch
Principle of Flow Switch - It uses “paddles” as a flow-sensing element which actuates switch contacts to identify the required flow rate.
Last updated: October 31, 2023 10:47 am
Flow Measurement Switches
2 Min Read
A flow switch is one that detects the flow of some fluid through a pipe. Flow switches often use “paddles” as the flow-sensing element, the motion of which actuates one or more switch contacts.
Flow SwitchPrinciple
Flow Switch
The “normal” status of a switch is the resting condition of no stimulation. A flow switch will be in its “normal” status when it senses minimum flow (i.e. no fluid moving through the pipe).
For a flow switch, “normal” status is any fluid flow rate below the trip threshold of the switch.
Flow Switch Symbol
Principle
A simple paddle placed in the midst of a fluid stream generates a mechanical force that may be used to actuate a switch mechanism, as shown in the following photograph:
Flow Switch Principle
Like all other process switches, flow switches exhibit deadbands (also called differential ) in their switching action. A flow switch that trips at 15 GPM rising, for example, will not re-set at 15 GPM falling.
That switch would more likely reset at some lower flow rate such as 14 GPM. With the “trip” and “reset” points being different, the switch avoids unnecessary cycling if the process flow rate hovers near one critical value.
  • Basics of Limit switches
  • Temperature Switch Principle
  • Inductive Proximity Switch
  • Zero Speed Switch Principle
  • What is Contact bounce?
Difference between Fixed Area & Variable Area FlowMeters
Normally-open and Normally-closed Switch Contacts
Turbine Flow Meter – Principle, Advantages, Disadvantages
Factors Affecting the Performance of Ultrasonic Flow Meters
Differential Pressure Switch Working Principle
What is a Vortex Flow Meter?
Flow Transmitters Questions and Answers – Instruments Test
What is a Weigh Feeder?
What is a Variable Area Flow Meter?
Orifice Plate Questions and Answers
Pull Cord Switch Working Principle
Troubleshooting Magnetic Flow Meters Common Problems
Vortex Flow Meter Animation
hall-effect-sensor
Hall Effect Sensor Working Principle Animation
Impeller Flow Sensor
Impeller Flow Sensor Working Principle and Animation
Magnetic Float Level Switch Working Animation
Flow Meters Troubleshooting
Turbine Flow Meters Troubleshooting
Annubar flow principle
Different Types of Flow Elements
Limit Switch Schematic
DP-Flow-Transmitter-Re-Ranging-calculation
DP Flow Transmitter Re-Ranging Calculation
Differential Pressure Sensor Calibration
Differential Pressure Sensors Calibration Procedure
Calculate Temperature of Three Wire RTD
Determine the Temperature of 3 Wire RTD
PLC FBD Example for Tank Liquid Heating Control by Steam Flow
Magnitude Comparator Objective Questions
Retro-Reflective Sensor
Electromechanical_Relays Circuit
Relay Loop Back Circuit
Diodes Voltage Tripler
How to do calibration checks of vibration Probe, extension cable and vibration monitor
