Here in this article, we discussed the general testing or healthiness checking procedure of an Flame Detector which is used in the fire and gas systems.
Flame Detector Testing
Before starting the job, take the proper work permit and inform to all the respective departments. Then do force the respective logics or interlocks if any (like fire suppression systems activation etc)
- Prior to testing of Flame Detector we should check LED Visibility of the Flame Detector. It should be blinking green. This can be seen on the flame Detector.
- Check the + 24 Volts DC Supply of the Flame Detector between + and – terminal of the Flame Detector.
- Take UV / IR Testing Torch for testing of Flame Detector.
- Before applying UV / IR rays to the Flame Detector, clean the detectors display by cotton cloth. It should be always cleaned for detecting the UV / IR rays. Otherwise Fault LED indication appears.
- Apply the UV /IR rays from UV / IR torch to the Flame detector.
- Resolution can be adjusted for the torch for checking the detector from short and long distance.
- After 3 seconds alarm appears and hooter is activated.
- Flame detectors Red LED indication will be ON (steady Red).
- Acknowledge the Flame detector’s alarm & silence the hooter.
- Note down the alarm tag and descriptions from the HMI or workstation. The alarm details must match with the flame detector tag number and installed location.
- Confirm the flame detector activation status from the respective graphics page. You have to visually identify the color change signals of the respective flame detector on the graphics.
- Remove the UV / IR test torch.
- Reset the alarm of the Flame Detector. Now Red LED Indication is off.
- Now the Flame Detector is working OK and Green LED indication is blinking.
- Repeat the above procedure for all the remaining flame detectors.
- Normalize the forced interlocks or logics if any.
- Close the work permit.
Note: The mentioned voltages, terminals, LED colors may vary as per the vendor or model of the Flame Detector.
Author: V Hemanth
- Gas Suppression System
- Rate of Rise Thermal Detectors
- End of Line (EOL) Resistor
- Fire System Loop Check
- Fire Detection System
dear
send me flame detector testing graphs and UV/IR torch price.
BR
Muhammad Kaleem
Whether UV/IR torch can be used in Zone1 & Zone2 areas
Yes, Refer this Article – https://engineerscommunity.com/t/uv-ir-torch-in-zone1-zone2-areas/36479
The Det-Tronics manual video guides state that it will have a steady green LED light before testing or during normal operations contrary to what was stated in the text. Can we further verify this?
