Reading: What are Fire Branches?
Inst Tools > Blog > Fire & Gas System > What are Fire Branches?
The selection of fire branches is a function of its end-use. The water flow rate will extinguish the fire in an industrial environment.
Last updated: September 28, 2022 2:37 pm
R Jagan Mohan Rao
Fire & Gas System
Fire fighting equipment is designed to extinguish fires or protect the user from fire. The user may be a trained firefighter, untrained users at the site of the fire.
Types of Fire Fighting NozzlesShort BranchFog NozzleHand Control Nozzle Triple Purpose NozzleDiffuser NozzleMulti-purpose Nozzle Curtain NozzleRevolving Nozzle
Fire fighting equipment not only fire hoses and fire extinguishers but also its connected fire branch equipment. The nozzle is a part of fire branch equipment.
A nozzle is generally a pipe of varying cross-sectional area, it can be used to direct or modify the flow of a fluid.
Nozzles are frequently used to control the rate of flow, speed, direction, mass, and shape of water or gas used for fire extinguishing.
  • Short Branch nozzle
  • Fog nozzle
  • Hand Control nozzle
  • Tripple purpose nozzle
  • Diffuser nozzle
  • Multipurpose (curtain) nozzle
  • Curtain nozzle
  • Revolving nozzle
The water flow rate will ultimately extinguish the potentially high energy fire in an industrial environment.
Short Branch
Fire Short Branch Pipe
The Short branch is still popular and commonly used in most fire brigades as the basic fire-fighting nozzle.
This can be fitted with a choice of nozzles that are suitable to flow and operational requirements.
Fog Nozzle
Fog Nozzle
Fog nozzle breaks stream into small droplets which spread in greater surface area, so heat absorption is high with this nozzle.
Fog nozzles ideal for fires that give out a large amount of heat, and hence require extensive cooling.
In the fog position, this branch creates very fine droplets i.e. “fog”, greatly increasing the surface area. Thus helping absorb maximum heat.
Hand Control Nozzle
Hand Control Fire Fighting Nozzle
The Hand Control nozzle is used by many government fire service departments and industrial Fire brigades for firefighting.
It has an On-Off facility at the same time a certain type of spray can be operated simultaneously with the jet application.
The Triple purpose nozzle gives the operator option of three functions.
It is a jet, spray, and shut-off. Because of the operation, and limited back-thrust, it is fast replacing the standard short branch in the industrial sector.
Diffuser Nozzle
diffuser nozzle for fire fighting
The Diffuser / Navy type nozzle, also known as Combination nozzle, is widely used in shipping, marine, and also in industrial applications.
Multi-purpose (curtain) Nozzle
The multipurpose nozzle is capable of giving jet spray and curtain, both functions.
The Multipurpose (curtain) nozzle is most popular throughout the world as the basic firefighting nozzle as it is low in weight has lower flow rates and a shut-off facility.
An additional curtain facility gives the fire fighting servicemen better protection from radiated heat.
 Curtain Nozzle
Curtain Nozzle
Curtain nozzles create a flat semicircular spray of water, useful for protecting the fire fighting personnel and equipment from the radiated heat of the fire, and intercepting the spread of fire.
It is safe from spark and smoke protection.
Curtain nozzles are available in various capacities, with portable and fixed options.
Revolving Nozzle
Revolving Nozzle
Image Courtesy: Redstone
As shown in the above figure, As shown in the below figure, the Revolving nozzle has nozzles located at three different angles.
Revolving Nozzle for Fire Fighting
Image Courtesy: Protecto Fire Safety Industries
1.ABC at circumference plane.
2.DEF at upper half pointing upward at 45 degrees to the vertical.
3.GHI shall be in the lower half pointing downwards at an angle of 45 degrees to the vertical.
Revolving Nozzles creates a three-dimensional spray, generating exceptional cooling.
This can be used for protecting fixed Roof Storage tanks where the vapor pressure maintained close to atmospheric pressure for fire prevention applications.
Indian Standard (BIS) IS 906 available in different capacities/ ranges and with coupling/flange connection.
  • Industrial Flame Detectors
  • Fire Water Spray Systems
  • Fire Fighting System
  • Infrared Gas Detector
  • What is Fire Alarm System?
Carbon Monoxide Gas Sensor Principle
What is an FACP? (Fire Alarm Control Panel)
How to identify location of Fire Detectors
Why LEL important in Gas Detection?
Chlorine Gas Hazards
Portable Gas Detectors Calibration Procedure
  • bwire david says:
    December 16, 2022 at 6:13 pm
    the explanation of how various nozzles works is very fine
Deluge Valve Operation
Fixed Gas Detectors vs. Portable Gas Detectors
Heat Detector Testing Procedure
Types of Fire and Gas Detectors
Gas Detection System Abbreviations
Basics of Gas Monitoring
What is Lower Explosive Limit & Upper Explosive Limit ?
What is Gas Leak Detection System ?
Fire Alarm System Commissioning Procedure
Manual Call Point Operating Principle
What is Manual Call Point (MCP) ?
Manual Call Point Testing Procedure
Which Gases Can a Multi-Gas Detector Detect
Which Gases Can a Multi-Gas Detector Detect?
Difference Between Passive and Active Fire Protection
Active and Passive Fire Protection
Spot Type Fixed Temperature Heat Detector Principle
Fixed Temperature Heat Detector Working Principle
Gas Detectors Bump Testing
What is Bump Testing ?
Gas Detection Definitions
Standard Gas Detection Definitions
level gauge
Basics of Sight Glass Level Gauge
U-tube Water Manometer
How much Pressure applied to U-tube Water Manometer?
Data Preparation for AI
Data Preparation for AI: For Successful Machine Learning
Mitsubishi PLC Counter Tutorial Using GX-Works2
Interview Questions and Answers
Electrical Machines Interview Questions and Answers
Laws of Boolean Algebra using Ladder Logic
Synchronous Motors Power and Torque Questions
Difference Between Cyclic and Acyclic Communication
