Reading: FF Function Blocks
Inst Tools > Blog > Communication > FF Function Blocks
FF Function Blocks
Last updated: March 28, 2018 5:23 am
Communication
3 Min Read
Data-processing modules within FF systems are known as function blocks. Sometimes these blocks serve merely to catalogue data, while in other instances the blocks execute specific algorithms useful for process measurement and control. These “blocks” are not physical entities, but rather abstract software objects – they exist only as bits of data and instructions in computer memory. However, the blocks are represented on FF computer configuration displays as rectangular objects with input ports on the left-hand side and output ports on the right-hand side. The construction of a working control system comprised of FF devices consists of linking the outputs of certain function blocks with the inputs of other function blocks via configuration software and computer-based tools. This usually takes the form of using a computer to draw connecting lines between the output and input ports of different function blocks.
Analog function blocks versus digital function blocks
Function-block programming in general strongly resembles the design philosophy of legacy analog based computer systems, where specific functions (addition, subtraction, multiplication, ratio, time integration, limiting, and others) were encapsulated in discrete operational amplifier circuits, and whole systems were built by connecting function blocks together in whatever patterns were desired to achieve a design goal. Here with Fieldbus programming, the function blocks are virtual (bits and data structures in digital memory) rather than real analog circuits, and the connections between blocks are merely pointer assignments in digital memory rather than actual “patch cable” connections between circuit boards.
An example contrasting analog circuit design with Fieldbus function-block design appears here, both systems selecting the greatest temperature signal to be the output. The system on the first figure side receives analog voltage signals from three temperature sensors, using a network of operational amplifiers, diodes, and resistors to select the greatest voltage signal to be the output. The system on the second figure side uses three Fieldbus transmitters to sense temperature, the greatest temperature signal selected by an algorithm (the ISEL function block) running in a Fieldbus device. The device running the ISEL function could be one of the three FF temperature transmitters, or another device on the segment:
High-select analog function block
Input function blocks
Instead of analog voltage signals sent by wire to special-function circuit modules, FOUNDATION Fieldbus uses digital messages sent over an H1 network segment to special-function software “blocks” running inside ordinary Fieldbus devices. The lines connecting different function blocks together in a FOUNDATION Fieldbus system show the sources and destinations of these digital messages. If two FF function blocks reside in different FF devices, the connecting lines represent publisher/subscriber communication assignments coordinated by the Link Active Scheduler (LAS) device.
HART Communication Tutorial Part 2
Difference Between Serial and Parallel Communication
HART Communication Tutorial Part 1
H1 FF Device Configuration and Commissioning
Different Fieldbus Network Topologies
Latest ProfiBus Questions and Answers
Basics for CAN Bus Protocol – Controller Area Network
Fiber Optic Cable Construction
Fiber Optic Sensors
Foundation Fieldbus Tutorials
Difference Between Modbus TCP IP and Profinet
Types of Wireless Technologies in Industrial Automation
Foundation Fieldbus Signal Conversion Formula
Profibus Listener Principle
Profibus Listener
HART Communication Tutorial 1
HART Communication Tutorial Part 4
Fiber Optic Patch Cord
What is a Fiber Optic Patch Cord? – Types, Explained
Multi-mode optical fiber
Multi-mode and Single-mode Optical Fibers
HART Multidrop Network
What is HART Protocol ?
Introduction to Fieldbus Function Blocks
RAID stands for Redundant Array of Independent Disks
Types of Cable Lengths in Ethernet Network
Guided wave radar Measurement Principle
Guided Wave Radar – Principle, Limitations, Installation
Industrial Instrumentation Questions & Answers
Opposite Acting Control Valves Application
PLC Ladder Logic for Opposite Acting Control Valves Application
Feedback Pneumatic Load cell Objective Questions
Biosensors Questions & Answers
Impulse Steam Trap
Impulse Steam Trap
PLC Instructions
Program Flow Control Instructions in PLC Programming
Why is IEC 60269 Important
Why is IEC 60269 Important? – Electrical Applications
