Reading: Determine Effect of Each Fault for Pneumatic Force-balance System
Inst Tools > Blog > Practical Questions > Determine Effect of Each Fault for Pneumatic Force-balance System
Determine the final effect of each fault for this pneumatic force-balance system. Be sure to explain the fault effects.
Last updated: September 26, 2020 2:42 pm
Practical Questions
1 Min Read
Determine the final effect of each fault for this pneumatic force-balance system:
Pneumatic Amplifying Relay
  • Clogged nozzle
  • Clogged restriction
  • Clogged tube at supply port of amplifying relay
  • Broken leaf spring inside amplifying relay
  • Major hole or tear in the diaphragm inside the amplifying relay
Be sure to explain the final effects of each of these faults!
Answer:
  • Clogged nozzle: output pressure saturates high
  • Clogged restriction: output pressure saturates low
  • Clogged tube at supply port of amplifying relay: output pressure saturates low
  • Broken leaf spring inside amplifying relay: output pressure may saturate high or possibly oscillate
  • Major hole or tear in diaphragm inside amplifying relay: The system responds very little to the applied force.
Interest to add any further points? Share your answers with us through the below comments section.
  • Motion-Balance Instrument
  • PLC Pneumatic Circuit
  • Types of Allen Bradley PLC
  • Pneumatic P&ID Diagrams
  • Pneumatic Instrumentation
Credits: Tony R. Kuphaldt
Calculate Amount of Weight Indicated by the Scale
Thermocouple Measurement and Reference Junction Temperatures
PLC Practice Questions
Practical Process Control System Questions & Answers – 12
Calculation of Hydrostatic Pressure
Baffle Nozzle Question
Solenoid Valves Questions & Answers – 1
Measure the Temperature of the RTD
Programmable Logic Controller (PLC) Questions and Answers – 3
Simple Pressure Repeater
Which Instrument is Faulty? Transmitter, Recorder, or Controller
Calculate the appropriate millivoltage values of a Thermocouple
Find Thermocouple Ouput Voltage
Pneumatic Transmitter
Pneumatic Level Transmitter Calibration Table
Calculate Hydraulic Pressure of a Drum
Calculate Hydraulic Pressure of a Process Vessel
Allen-Bradley MicroLogix PLC Wiring
Programmable Logic Controller (PLC) Questions and Answers – 8
Heat Exchanger Differential Pressure Transmitter
steam heat exchanger
Practical Process Control System Questions & Answers – 9
Purpose of Stop in a Pressure Measuring Instrument
Level-Measuring-Instruments-Velocities-of-Propagation
Level Measuring Instruments Velocities of Propagation
Purge Type Level Transmitter
Purge Type Level Transmitter Questions
Quiz on Alternators, Motors, and Transformers
200+ Quiz on Alternators, Motors, and Transformers
Career Opportunities and Scope in Industrial Automation
Phase Watcher Multiphase Flow Meter (MPFM) Procedure
ControlLogix 5580 Controllers
Rockwell PLCs for Large Scale Applications
Erratic H2 Flow Rotameter
Vortex Flow GIF
Working Principle of Vortex Flow Meter
Applications of Variable Frequency Drive (VFD)
Measure Duty Cycle using Multimeter
How to Measure Duty Cycle using Multimeter
