Reading: ESD System Insights: Signals for Emergency Valve Shutdown Explained
Inst Tools > Blog > Control Systems > ESD System Insights: Signals for Emergency Valve Shutdown Explained
Signals are used to trigger the ESD system as per the process logic to actuate the emergency valve shutdown in hazardous situations.
Last updated: November 30, 2023 2:34 pm
Control Systems Safety Instrumented System (SIS)
For the emergency closure of Emergency Shutdown valves (ESD) in oil and gas plants or power plants, several specific types of signals are commonly used.
Emergency Valve ShutdownPressure SignalsFlow Rate SignalsTemperature SignalsFire and Gas Detection SignalsManual Activation SignalsControl System InputsSafety Instrumented Systems (SIS) InputsRemote Activation SignalsEmergency Stop SignalsConclusion
These signals are used to trigger the ESD system as per the process logic to actuate the ESD valves in emergency situations. Some of them are discussed below.
ESD System Insights
Pressure Signals
These are among the most common signals used for ESD activation. A significant deviation from normal operational pressure either too high or too low can trigger the ESD system.
Pressure transmitters are used to monitor the process pressure.
Flow Rate Signals
Abnormal flow rates, which could indicate a leak or an unintended release of materials, can also be used to activate ESD systems.
The flow sensors provide real-time data on the flow rate of gases or liquids in the pipeline.
Temperature Signals
When the process temperature is unable to be controlled by the basic process control system such as a DCS then the ESD may initiate the trip if the temperature reaches beyond controlled limits.
The presence of flammable gases or the outbreak of a fire is detected by fire and gas detectors. When the fire and gas system detects any fire or gas leaks then it sends signals to the ESD system to initiate shutdown procedures.
These are provided by manual push buttons or switches that can be used by personnel to trigger the ESD system in case of observed dangers that might not be detected by automated sensors or when the operators want to initiate emergency shutdown.
Signals from Distributed Control Systems (DCS) or Supervisory Control and Data Acquisition (SCADA) systems can be used to activate the ESD system.
These signals will be generated based on the analysis of various process parameters and applied logic. Sometimes manual operation can be performed by the operators.
The SIS system has independent inputs and outputs with separate logic. This is designed to prevent hazardous conditions and can trigger ESD valve closure as per our requirement.
These signals allow for ESD activation from different locations such as individual control rooms, operator consoles, hardwired consoles, and graphics. These provide an additional layer of safety, especially in situations where access to the site is hazardous or restricted.
These signals can come from emergency stop buttons located throughout the industry, allowing for immediate shutdown in case of an emergency.
Conclusion
The ESD system is typically configured to respond to these signals by immediately initiating a series of actions, including the closure of valves, to halt the flow of hazardous materials, shut down processes, or isolate sections of the plant.
This multi-signal approach enhances the reliability and responsiveness of the ESD system, ensuring a swift reaction to various potential emergency scenarios.
  • What is HIPPS System?
  • Emergency Block Valves
  • SIS Common Cause Failure
  • SIS Verification & Validation
  • Testing and Repair Deferral
Chemical Reactor Temperature Control System
Control Room Design Guidelines
Basics of Trips, Interlocks, Permissives & Sequences
Zener Diode Barrier Principle
Vendor View of Supplying Industrial Process Control & Safety Systems
Understanding Safety Integrity Level IEC 61511
SIS Software Simulation – Safety Instrumented System
14 Basic Control Systems Questions for Interview Preparation
Yokogawa DCS System Maintenance Procedures
Loop Calibrator to Simulate a 4-20 mA Signal
What is a Transducer ?
Interview Questions on PID Controllers
Speed Control of Ship Electrical Motor Propulsion
Compare DCS, PLC, RTU
Difference between DCS, PLC, and RTU ?
Why 24 Volts DC Power Supply
Why 24 Volts DC Power Supply is used? – Industrial Automation Systems
how-to-avoid-bad-grounds
How to Avoid Bad Grounds ?
Instrumentation and Control (I&C) Design
Safety PLC System
Instrumentation During the Detail Design Phase
PID Simulator
PID Simulator Download
Emergency Shutdown Valve
Emergency Shutdown Valve : Advantages
Industrial Automation Controls used in HVAC
Vac Residue Tank Electrical Heating Element
Poor Electrical Heating Element Lives – Problem Solved
What is a Bourdon tube
Bourdon Tube Pressure Gauge Advantages and Disadvantages
What is a Tactile Sensor? Principle, Advantages, and Applications
Variable-speed motor controls
Variable Motor Speed Control
PTC NTC Thermistors Comparation
Thermistor Working Principle
Difference between Soft Starter and VFD
