Reading: Electrical Wiring Terminology
Inst Tools > Blog > Electrical Theory > Electrical Wiring Terminology
Last updated: October 3, 2018 10:06 am
Electrical Theory
1 Min Read
To understand electrical wiring schemes used in power distribution systems, you must be familiar with the following terms.
Ampacity – the current in amperes that a conductor can carry continuously under the conditions of use without exceeding its temperature rating.
Bond – the permanent joining of metallic parts or circuits assuring electrical continuity and capacity to safely conduct any current likely to be imposed.
Conductor – any wire, cable, or substance capable of carrying an electrical current.
Ground – a conducting connection, whether intentional or accidental, between a circuit or piece of equipment and the earth, or some body serving as earth; a place of zero electrical potential.
Ground voltage – the voltage between any given conductor and any point at ground potential.
Leg – a current-carrying conductor intended to deliver power to or from a load normally at an electrical potential other than ground.
Neutral – a current-carrying conductor normally tied to ground so that the electrical potential is zero.
Phase voltage – the greatest root mean square (effective) difference of potential between any two legs of the circuit.
Three Phase AC Generators
Applying Kirchhoff’s Voltage Law
Calculate Power in Series RL Circuit
Losses in AC Generator
Three Phase Wattmeter
Ammeter
Moving Iron Vane Meter Movement
AC Induction Motor Slip
AC Generator Parts
AC Motor Theory
Ohm Meter
Methods of Producing Voltage (Electricity)
Capacitance and Capacitive Reactance
Voltage and Current Phase Relationships in an Inductive Circuit
Calculate Power in Parallel RCL Circuit
Types of Capacitors
Types of Capacitors
Transformer Tap changer
Transformer Mutual Induction
Voltage Drop in a Series Circuit
Series Resistance
3-Wire, Three-Phase Delta Wiring System
Inductor Principle
Inductance and Inductive Reactance
Single Line Diagram
Single Line Diagram
Armature Current in a DC Motor
DC Motor Torque
PLC Ladder Logic Example
Valve Non-rising Stems
Valve Functions and Basic Parts of Valve
PLC Programming for Level Switches
PLC Programming using Level Switches
ACSR (All Aluminium Conductor Steel Reinforced)
What is an Overhead Cable? Types of Overhead Conductors
Level Gauge Working Animation
Sight Glass Level Measurement Principle
Bellows-Type Steam Trap
Bellows Steam Trap
wedge Flow meter
What is a Segmental Wedge Flow Meter?
Bellow Principle
Bellows
