Reading: Draw a Ladder Logic to switch ON-OFF a Bulb using a Toggle Switch ?
Inst Tools > Blog > PLC Tutorials > Draw a Ladder Logic to switch ON-OFF a Bulb using a Toggle Switch ?
Last updated: March 4, 2021 3:27 pm
1 Min Read
In the ladder logic diagram we can see there is an input contact (N-O) “I0.0” which is a toggle switch in the physical connections to the plc. There is also an output coil addressed as “Q0.0” which can be a Motor, Bulb or any signaling device in the physical connection.
Ladder Logic
Draw a ladder logic to switch ON-OFF a bulb using a toggle switch
Now, as soon as toggle switch is pressed the NO contact of I0.0 becomes NC and the corresponding rung logic goes true. As a result output coil Q0.0 gets energized and the bulb will ON.
On the other hand, if we want to switch OFF the bulb, the toggle switch is again pressed and I0.0 again becomes an NO contact and rung goes false ,which in turn switches OFF the bulb.
PLC Multiple Choice Questions
Basics of Fail-safe Circuit
PLC Timers Program
Important Question on PLC
What is Seal-in Circuit ?
Getting to Know the LED Indications on GE Make PLC
How to Control VFD with PLC using Ladder Logic
System and Local Time in PLC
Schneider PLC Example Program for Star-Delta System
Automatic Curtain Control – PLC Programming Solution
PLC Programming for Train Detection and Gate Operation
Problem on PLC, HMI, VFD, and Motor Circuit
Tia Portal – OB30 Cyclic Interrupt Organization Block
How to Use an SQL Server with Indusoft Web Studio?
Difference between Signal Cables and Control Cables
PLC Motor Logic with START, STOP, TEST Push buttons
Raw Counts to Engineering Units : Conversion Formula
OFF Delay Timer using PLC
Siemens PLC Device and Network
Difference Between PLCSIM and PLCSIM Advanced? – Siemens PLC
Tanks Draining Control in PLC using Functional Block Diagram
PLC Program three-phase electric motor
Identify the Problem in the PLC Program
How to Choose a PLC
How to Choose a PLC for New Project? – Criteria for Selection of PLC
Anti-static Wrist Straps
DCS Marshalling Cabinet Checks
PLC, DCS, and ESD Marshalling Cabinet Checks
PLC Program for Washing Machine
Library of PlantPAx Process Objects
Questions and Answers on Motors and Generators
HT Motor Problem appears after Disassembly and Reassembly
Basic Pneumatic System
Pneumatic Handbook
Allen Bradley RSLogix 500 PLC Programming
PID-Controller-Simulator-graph
PID Controller Tunning Parameters Simulator
Total Organic Carbon Analyzers Questions and Answers
TIA Portal MOVE Instruction
MOVE Instruction in PLC – What You Need to Know?
