Reading: DP Flow Transmitter Re-Ranging Calculation
Inst Tools > Blog > Flow Measurement > DP Flow Transmitter Re-Ranging Calculation
DP Flow Transmitter Re-Ranging Calculation is used to find the DP Flow transmitter revised flow with Existing DP, Existing Flow & New DP.
Last updated: October 31, 2023 10:51 am
Flow Measurement Instrumentation Tools
16 Comments
2 Min Read
DP Flow Transmitter Re-Range: This tool is used to calculate the DP Flow transmitter revised flow with the following inputs: Existing DP, Existing Flow, and revised DP.
This tool is primarily used for orifice-based flow meters. Also useful for flow transmitters that work on Differential Pressure applications.
Generally, we calibrate our transmitter as per the datasheet of the orifice. But sometimes the measured DP of the transmitter will be out of range or more than the maximum scale of DP, so we have to re-range the DP flow transmitter.
For these applications, we use the below-mentioned formula to calculate the maximum flow of the transmitter.
This calculation tool is used to calculate the revised flow range of a DP Flow transmitter.
The formula for calculating the DP Flow Transmitter Re-Range value.
DP Flow Transmitter Re-Ranging calculation Formula
Where,
Existing DP    = DP value as per orifice datasheet
Existing Flow  =  Flow value as per orifice datasheet
Revised DP    =  Actual DP value in the field
Revised Flow  =  Calculated transmitter flow max range.
Note:
1. The Existing DP and revised DP must be in the same units like bar, mbar, mmh20, etc.
2. The Existing Flow and revised Flow must be in the same units like m3/hr, t/hr, etc.
Also See: Instrumentation Calculator
  • What is a Pitot Tube?
  • Pitot Tube Working Principle
  • Different Types of Flow Elements
  • Annubar Flow Meter Principle
  • Types of Flow Meters
Design Considerations of Orifice Plate
Flow Meter Calibration
Oval Gear Flow Meters – Principle, Advantages, Animation
What is Water Cut Meter?
Piston Flow Meters Working Principle with Animation
Mass Flow Calculations
16 Comments
  • Jitin D says:
    April 21, 2015 at 11:04 am
    I am instrument guy and i am very rarely found tools related to instrumentation. I am very happy to see these type of tools. Please update more with complex calculations like density measurement, Interface measurement, USM flow calculations etc.
  • Rambai says:
    April 26, 2015 at 6:31 pm
    I Just loved your site dude :love:
  • rahim says:
    November 29, 2015 at 7:32 pm
    Hi. We have a flowmeters with instrument range 0 to 500 mbar and calib. Range 0 to 250 mbar for normal flow =10000kg/h but we need 10311 kg/h so we have to recalibrate it .please help me how i do it .i mean 0~250mbar should change to 0~? Many thanks
    • rahim1356 says:
      December 1, 2015 at 5:08 am
      You should just change your scale !
      Reading dp flow ,so long as your devices within the capability of the pressure device , everything is ok.
      For mentioned ranges above is your remedy but for large differences you need to know your device limitation.
  • ravi singh says:
    November 30, 2015 at 12:05 pm
    dear sir
    i have one orifice plate concentric type and id is 25 mm.but i do not calculate Dp range please guide in LRV & URV range. how to calculate……….
  • rahim1356 says:
    December 1, 2015 at 5:02 am
    Be careful this is for 4~20 ma not for fieldbus .
    • S Bharadwaj Reddy says:
      December 1, 2015 at 6:52 am
      Dear Rahim, Thank you for the suggestions.
    • Hadi says:
      November 20, 2017 at 5:00 am
      What’s the right way to re-range DP fieldbus “FF” transmitter?
  • Raju says:
    December 23, 2015 at 5:32 am
    Sir,
    I Need Suggestion on Flow. Orifice D/P To Connected DP Transmitter With Sq.root Op.
    Indicator also Need Sq.root Input or Linier In put.
    Pls Explain sir.
    Regards
    Raju
  • GANDHI says:
    May 16, 2016 at 5:41 am
    What is the minimum static working pressure
  • Suresh badiger says:
    January 1, 2017 at 1:22 pm
    Sir I’m instrumentation Engg I have do transmitter in condensate water line as per data sheet 1500 mmwc I puted urv range in transmitter but I’m not getting full flow as per pump discharge 110 m/3 hr only I’m getting 49 m3/hr so please suggest
  • jdp says:
    June 3, 2019 at 11:39 am
    if we re range the value… does the square root graph also change ?
  • Saddam hussain says:
    March 5, 2020 at 8:04 pm
    Respected sir,
    Pls give me solution. How to we calculate nm3/hr flow for different case. Like air, gas. Please give one note with example.
  • Le Huy Dat says:
    July 16, 2021 at 11:16 pm
    you can to chang for calibration range from 0 to 265 MPA with enering range from 0 to 10311.
  • Cyrus says:
    June 19, 2022 at 8:02 pm
    Good day to all.
    I hope any one can help me elighten about Flow Transmitters. Why is it Flow transmitter has 2 ranges? Example process variable range from 0 to 2500 mmH2O and the other range (engineering range) is 0 to 160 t/h.
  • GP says:
    August 21, 2024 at 4:32 pm
    We are plaining in-house calibration flow meters. would you please give me simple technique. How to set up and calibration step by step.
Target Flow Meter – Working Principle, Advantages, Disadvantages
All About Variable Area Flow Meters
Convert Linear mA to Square root mA
Calculate Flow Transmitter Output Current
What is a Paddle Wheel Flow Meter?
Turbine Flow Meter Installation Procedure
Orifice Plate Tapping – Orifice Plate Taps
Ultrasonic Doppler Flow Meter Advantages and Disadvantages
Classification of Flow Measurement Techniques
Differential Pressure and Pressure Loss
What is Differential Pressure and Pressure Loss?
Multiphase Flow Meter Calibration Procedure
Hot wire Anemometer Principle
Hot Wire Anemometer Principle and Types
Pressure and Temperature Compensation for Flow Transmitter
flow-meter-accuracy-calculation
Impact of Flow Meter Accuracy
DP-Level-Measurement-Calculation-Below-Tapping-Point-Open-Tank
Differential Pressure (DP) Level transmitter Installed Below Tapping Point
Pressure Gauge Selection
HVDC transmission compared to HVAC transmission
Comparison of HVDC transmission and HVAC transmission
Electro Magnetic Flow Meter Animation
Power Systems MCQ Series 19
Types of Wireless Technologies in Industrial Automation
Capacitor Principle
Capacitor
Two Wire Sensors Animation
Two Wire Sensor Working Principle and Animation
Control valve sizing
Basics of Control Valve Sizing
