Reading: Dissolved Oxygen Analyzer Questions and Answers
Inst Tools > Blog > Multiple Choice Questions > Dissolved Oxygen Analyzer Questions and Answers
Last updated: November 27, 2021 5:36 pm
1. Which of the following transducers must be used for dissolved oxygen analyser?
a) Potentiometric
b) Polarographic
c) Ion-selective electrode
d) Optical transducer
Answer: b
Explanation: Polarographic transducer must be used for dissolved oxygen analyser. Dissolved oxygen is the measure of ability of water to sustain aquatic life.
2. How does solubility of oxygen in water change with respect to temperature?
a) It decreases with increase in temperature
b) It increases with increase in temperature
c) It decreases with decrease in temperature
d) It does not depend on temperature
Answer: a
Explanation: Solubility of oxygen in water decreases with increase in temperature. Dissolved oxygen is the measure of ability of water to sustain aquatic life.
3. The water to be analysed flows into the condenser through which of the following components?
a) Filter
b) Semi-permeable membrane
c) Throttling device
d) Platinum filament
Answer: c
Explanation: The water to be analysed flows into the condenser through a throttling device. It is cooled in the condenser.
4. Which of the following is the function of the throttling device?
a) Filtering
b) Maintains pH of water
c) Purifies water
d) Maintains constant flow rate
Answer: d
Explanation: The function of the throttling device is to maintain a constant flow rate. The water then passes into the condenser.
5. Which of the following section plays a major role in maintaining the accuracy of the dissolved oxygen analyser?
a) Analysing section
b) Inlet section
c) Transmitting section
d) Condensing section
Answer: c
Explanation: Transmitting section plays a major role in maintaining the accuracy of the dissolved oxygen analyser. It is the section after the analysing section.
6. Which of the following bridges are used in dissolved oxygen analyser?
a) Kelvin’s bridge
b) Wheatstone bridge
c) Schering’s bridge
d) Anderson’s bridge
Answer: b
Explanation: Wheatstone bridge is used in dissolved oxygen analyser. Initially, the bridge is in balanced condition.
7. In dissolved oxygen analyser, the electrometer consists of which of the following solutions?
a) Calcium hydroxide solution
b) Magnesium hydroxide solution
c) Potassium hydroxide solution
d) Calcium oxide solution
Answer: c
Explanation: In dissolved oxygen analyser, the electrometer consists of potassium hydroxide solution. It produces hydrogen due to electrolysis process.
8. The dissolved oxygen analyser is based on which of the following meters?
a) Amperometer
b) Katharometer
c) pH meter
d) Voltmeter
Answer: b
Explanation: The dissolved oxygen analyser is based on katharometer. It works on the principle of thermal conductivity detector.
9. Oxygen content can be controlled by adding which of the following materials with water?
a) Acidic solution
b) Basic solution
c) Iodine
d) Hydrazine
Answer: d
Explanation: Oxygen content can be controlled by adding hydrazine with water. It is important to maintain dissolved oxygen content in boilers to reduce corrosion.
10. In dissolved oxygen analyser, normally more than one condenser is used.
a) True
b) False
Answer: a
Explanation: In dissolved oxygen analyser, normally more than one condenser is used. The condensers are present in the condenser section.
Total Reflection Spectrometer Questions & Answers
Effect of Adding a Zero to a System
Liquid Scintillation Counters Questions & Answers
pH Meters Questions & Answers
Inductively Coupled Plasma Mass Spectrometer
Feedback Control Loop Questions & Answers
Transfer Functions Objective Questions
Solution of State Equations
Pulse Height Analyzer Questions & Answers
Liquid Chromatograph- Mass Spectrometer
Encoder Multiple Choice Questions
Fourier Transform NMR Spectroscopy Questions & Answers
Continuous Wave NMR Spectroscopy Questions & Answers
Detection System of Liquid Chromatography Questions & Answers
Absorption Instrumentation Questions & Answers
PN Junction Questions & Answers
Measurement and Instrumentation Objective Questions – Part 5
Paramagnetic Oxygen Analyzers Questions & Answers
Stability in Frequency Domain
Cascade Compensation in Frequency Domain
Radiation Detectors Questions & Answers
Ion Analyzers Questions and Answers
Ammonia and Fluoride Electrode Questions & Answers
Digital Control Systems
The inverse z-transform & Response of Linear Discrete Systems
Ion Spectroscopy Questions & Answers
BP Refinery Explosion
Learnings from the BP Refinery Explosion at Texas City
Capacitive Field Effects on Conductors-4
Capacitive Coupling Effects
Controller Output Current Loop
DCS Controllers to Output Current Loops
PLC Automation Memory
What is NOR Flash Memory in PLC?
Single-Phase Full Wave AC-DC Converter Quiz
C-Bourdon Tube
C-Bourdon Tube Pressure Gauge Theory
de-energized-to-safe-mode
Advantages & Disadvantages of Different Vibration Sensors
