Reading: Displacer Type Density Transmitter Question
Inst Tools > Blog > Practical Questions > Displacer Type Density Transmitter Question
Last updated: June 6, 2018 9:49 am
Practical Questions
1 Min Read
Question :
A displacer-type density transmitter registers a displacer weight of 6.3 pounds with the cage completely full of sample liquid.
The displacer has a dry weight of 14 pounds, a density of 120 lb/ft3 , and is cylindrical in shape.
Calculate the density of the liquid in units of pounds per cubic foot.
Answer :
The liquid has a density of 66 pounds per cubic foot.
Identify Faults in PID Control Loop
How Manometer Measures Differential Pressure for Different Fluids?
Analytical Process Control Question
How Nuclear Radiation is used to Measure Coke Dust Level?
Identify Two Pressure Switches Logic
Solenoid Valves Questions & Answers – 1
Define Normal Status of a Process Switch ?
Programmable Logic Controller (PLC) Questions and Answers – 17
Transmitter Calibration Range of a Vessel Level
Paint Mixing System
Differential Pressure Transmitter with 5 Way Manifold Valve
Calculate Hydraulic System Fluid Pressure
Example PLC Program
Questions on Radar LT Loop Diagram
Sump Tank Level Transmitter
Problem with Sump Tank Level Transmitter
PSV lift pressure
Calculate PSV Lift Pressure
Identify Problem with Oily Water Filter Instrumentation
surface-mounted water pump
Surface-mounted Water Pump
Calculate Amount of Weight Indicated by the Scale
Calculate Hydrostatic Pressure of a vertical column of Acetic Acid
Practical Level Sensors Questions and Answers
Electronic Pressure Sensor with Bourdon Tube and LVDT
Digital Instrument Example
Digital Measuring Instruments – Types, Functions, Advantages, Disadvantages
PLC Commissioning and Testing
PLC Commissioning and Testing Procedure (Programmable Logic Controller)
Characteristics of Protective Relay
What is a Protective Relay? Principle, Advantages, Applications
deadweight tester principle
Pressure Standards
Control valve performance with constant pressure
Control Valve Performance with Constant Pressure
Thermocouple Law of Intermediate Metals
Thermocouples Law of Intermediate Metals
Override Control Functions
Comparator used in Siemens S7-1200 PLC.
Siemens PLC Comparator Logic
