In this blog, you will find the 600 latest digital image processing projects for beginners and engineering students. These DIP projects are useful for BTech and MTech students.
Digital Image Processing Projects
| S.NO. | DIP Projects |
| 1 | Co-Segmentation in Robust Video Object |
| 2 | Binary Hashing Learning and Deep Convolutional Neural Networks for Image Retrieval |
| 3 | Underwater Image Enhancement Beyond Benchmark Datasets |
| 4 | Wavelet and Directed Diffusion Enhanced BM3D Algorithm for Improved Image Denoising |
| 5 | Reconstructing Color Correction Algorithms for Enhanced Image Stitching |
| 6 | Single Image Haze and Noise Removal with Accurate Transmission Estimation |
| 7 | Unstructured Handwritten Document Named Entity Recognition |
| 8 | Multi-View Videos for Robust Face Recognition |
| 9 | Visual Saliency Detection for Robotic Vision Systems |
| 10 | Practically Lossless Affine Image Transformation |
| 11 | Large Scale Image Classification with Multi-Level Discriminative Dictionary Learning |
| 12 | Affine Non-Local Means Image Denoising |
| 13 | Single Image Defogging for Visual Maritime Surveillance Based on Illumination Decomposition |
| 14 | Saliency Detection for Stereoscopic Images Based on Depth Confidence Analysis and Multiple Cues Fusion |
| 15 | Edge-Preserving Image Smoothing Benchmark |
| 16 | Image Rotation via Double Line Algorithm |
| 17 | Hierarchical Confidence-Based Matching for Efficient Depth Reconstruction |
| 18 | Aspect Ratio Similarity for Image Retargeting Quality Assessment |
| 19 | Convolutional Sparse Coding for Image Super-Resolution |
| 20 | Bayesian Polytrees with Deep Learned Features for Multi-Class Cell Segmentation |
| 21 | Content-Based Image Retrieval with a k-Nearest Neighbor Multilabel Ranking Algorithm |
| 22 | Retinal Image Segmentation for Blood Vessels and Optic Disc |
| 23 | Deep Coupled ISTA Network for Multi-Modal Super-Resolution |
| 24 | Lung Cancer Survival Prediction from Pathological Images and Genetic Integration |
| 25 | Perceptual Quality Assessment for Multi-Exposure Image Fusion |
| 26 | Cross-Disease Attention Network (CANet) for Joint Diabetic Retinopathy and Macular Edema Grading |
| 27 | Iris Code Utilization for Gender Classification in Recognition Systems |
| 28 | Novel Image Hashing for Tamper Detection and Self-Recovery |
| 29 | Directional Gradient Prior for Fast and Effective Video Rain Streak Removal with FastDeRain |
| 30 | Patch-Based Near-Optimal Denoising Technique for Images |
| 31 | Group-Based Image Inpainting in MRF Framework with Patch Refinement |
| 32 | Privileged Information Learning in Multi-View Discriminative Image Re-Ranking |
| 33 | Crack Detection with Hierarchical Convolutional Features using DeepCrack Learning |
| 34 | Efficient Robust Conditional Random Fields for Image Processing |
| 35 | Deep Learning Based Image Colorization |
| 36 | Saliency Detection with a Unified Spectral-Domain Approach |
| 37 | Objective Image Quality Assessment with a Perceptually Weighted Rank Correlation Indicator |
| 38 | Video Action Recognition via Semi-Supervised Image-To-Video Adaptation |
| 39 | Multiresolution Convolutional Neural Networks for Moiré Photo Restoration |
| 40 | Feature Covariance Matrices Action Recognition from Video |
| 41 | Multi-Scale Deep Residual Learning-Based Single Image Haze Removal via Image Decomposition |
| 42 | Parallel Block Sequential Closed-Form Matting with Fan-Shaped Partitions |
| 43 | Real-Time Edge Detection for Automated Traffic Control Systems |
| 44 | LCSCNet: Image Super-Resolution with Linear Compressing-Based Skip-Connecting Network |
| 45 | Improved Structure Consistency in Multispectral and Multimodal Image Registration |
| 46 | Objective Quality Assessment for Multi-Exposure Multi-Focus Image Fusion |
| 47 | Accelerated Restoration without Boundary Artifacts in Edge-Preserving Image |
| 48 | Stochastic Blind Motion Deblurring Method |
| 49 | Spatially Constrained Robust Image Segmentation Model |
| 50 | Generalized Logarithmic Image Processing Based on Gigavision Sensor Model |
| 51 | Dual Enhancement for ECG Signal Quality During Arrhythmia |
| 52 | Depth Reconstruction From Sparse Samples: Algorithm and Sampling Techniques |
| 53 | Dual-Transfer Technique for Face Sketch-Photo Synthesis |
| 54 | BM3D Frames Application in Variational Image Deblurring |
| 55 | Influence Quantities Sensitivity Analysis on Signal-to-Noise Ratio in Face Recognition Systems |
| 56 | Iterative Block Tensor Singular Value Thresholding for Low Rank Component Extraction in Image Data |
| 57 | Image Denoising with Translation Invariant Directional Framelet Transform and Gabor Filters |
| 58 | Enhanced Image Quality with PDEs and Nonconservative Advection Flow Fields |
| 59 | Enhancing Visual Quality of Grayscale Images Using Size-Invariant Visual Cryptography with Analysis-by-Synthesis Methodology |
| 60 | Transform-Domain Downward Conversion for Block-Based Image Compression Enhancement |
| 61 | Multi-Scale Blind De noising Technique |
| 62 | Human Climbing Fences Detection in Transformer Substations with Fast Recognition |
| 63 | Segmentation Driven Image Registration for 4D DCE-MRI Kidney Recordings |
| 64 | Multiple Linear Mappings Learning for Efficient Single Image Super-Resolution |
| 65 | Assessing DIBR-Synthesized Image Quality with Local and Global Measures |
| 66 | Feature Learning for Noise Reduction in Low Light Images |
| 67 | Learning Image Downscaling for Upscaling with Content Adaptive Resampler |
| 68 | Binary Shape Reconstruction from Blurred Images Using Hankel-Structured Low-Rank Matrix Recovery |
| 69 | Conditional Random Field Approach for Brain Tumor Detection and Segmentation |
| 70 | Enhancing JPEG Images in Poor Lighting with Joint Dequantization and Contrast Enhancement |
| 71 | Nonlocal Patch Tensor Sparse Representation for Hyperspectral Image Super-Resolution |
| 72 | Nonparametric Bayesian Dictionary Learning for Noisy and Incomplete Image Analysis |
| 73 | All-Pass Based Parametric Image Registration |
| 74 | Depth Restoration from RGB-D Data with Joint Adaptive Regularization and Thresholding on Manifolds |
| 75 | Robust Blind Image Watermarking Using Discrete Wavelet Transform in Blocks |
| 76 | Overlapping Cervical Cell Segmentation in Pap Smear Images |
| 77 | Polyview Fusion Strategy for Enhanced Video-Denoising Algorithms |
| 78 | Enhanced Matrix Completion with Non-Convex Low-Rank Approximation |
| 79 | Wavelet-Based Parallel Filtered Back-Projection for Tiled-Block Image Reconstruction |
| 80 | Multi-Scale Binary Descriptor for Spatio-Temporal Analysis |
| 81 | Deep Variational Structure-Texture Image Decomposition |
| 82 | 3D Reconstruction with Accurate Multiple View Patch-Based Stereo |
| 83 | Multi-Task Pose-Invariant Face Recognition |
| 84 | Variational Bayesian Blind Color Deconvolution for Histopathological Images |
| 85 | Scalable Image-Based Localization with Prioritized Cascade Search and Fast One-Many RANSAC |
| 86 | Hierarchical Video Moving Object Detection Using Modeling and Alternating Optimization |
| 87 | Separable Reversible Data Hiding Technique for Encrypted Images |
| 88 | Largest Matching Area Approach for Image Denoising |
| 89 | Optimizing Tone Mapped Image Quality Index for High Dynamic Range Image Compression |
| 90 | Automated Detection and Classification of Microscopic Organisms in Water Samples |
| 91 | Modified Level Set Approach for Polarimetric SAR Image Segmentation |
| 92 | A Color Model-Based Algorithm for Background Modeling and Foreground Detection |
| 93 | Retinal OCT Images 3D Registration Using Feature-Based Methodology (OCTRexpert) |
| 94 | Supplementary Material for Image Enhancement with PDEs and Nonconservative Advection Flow Fields |
| 95 | Theory of Occlusion-Resilient Depth Perception in Binocular Light-Field Imaging |
| 96 | Maximum Likelihood Depth Field Estimation from Epipolar Plane Images |
| 97 | Reversible Data Hiding in Histogram-Shifting-Based Methods |
| 98 | One-Shot MRI Segmentation of Craniomaxillofacial Bony Structures via Generative Adversarial Learning |
| 99 | Content-Aware Enhancement of Filamentous Structures in Images |
| 100 | Multi-Exposure Fusion for High Dynamic Range Image Synthesis |
| 101 | Blind Image Quality Assessment Based on Multichannel Feature Fusion and Label Transfer |
| 102 | Tracking Cell Membranes in Living Brain Tissue Using Differential Interference Contrast Microscopy |
| 103 | Hybrid Graph Laplacian Regularization: A Unified Framework for Image Denoising |
| 104 | Processing Chain for Shadow Detection and Reconstruction in VHR Images |
| 105 | Automated Lesion Detection in Retinal Images Using Deep Learning |
| 106 | Fractal Analysis in Reduced Reference Image Quality Assessment |
| 107 | Large Scale Predictive Dictionaries |
| 108 | Continuous Depth Map Reconstruction from Light Fields |
| 109 | Active Appearance Models with Feature-Based Lucas–Kanade Method |
| 110 | Real-World Image Denoising via Non-Local Blind Pixel-Level Method (NLH) |
| 111 | Spatial-Angular Separable Convolution for Efficient Light Field Spatial Super-Resolution with Deep Learning |
| 112 | Quadtree Structured Image Approximation for Denoising and Interpolation |
| 113 | Enhanced Denoising Technique Using Dual Tree Complex Wavelet Transform |
| 114 | Convolutional Neural Network-Based Face Frontalization Using Appearance Flow |
| 115 | Egocentric Activity Recognition via Multitask Clustering |
| 116 | Deep Neural Networks for End-to-End Blind Image Quality Assessment |
| 117 | Root-Polynomial Regression for Color Correction |
| 118 | mDixon-based Synthetic CT Generation with Transfer Fuzzy Clustering and Active Learning-Based Classification |
| 119 | Fast Multi-Exposure Image Fusion with Deep Guided Learning |
| 120 | Nonconvex-Sparsity and Nonlocal-Smoothness in Blind Hyperspectral Unmixing |
| 121 | Energy Based Model for Image Edge Histogram Specification |
| 122 | Efficient Image Retrieval Through Deep Ranking |
| 123 | Fast Adaptive Bilateral Filtering Technique |
| 124 | NO Driven Image Quality Assessment Applications |
| 125 | Structure from Motion with Deep Learning for 3D Reconstruction |
| 126 | Low-Rank Matrix Completion Driven Light Field Inpainting Propagation |
| 127 | A Survey on Low-Resolution Face Recognition Techniques |
| 128 | Texture Discrimination and Retrieval with Wavelet Modeling Using Finite Mixtures of Generalized Gaussian Distributions |
| 129 | Speckle Noise Reduction in Remote Sensing Images using Generalized Bayesian Model Selection |
| 130 | Features Classification Forest for Robust Blind Watermarking Techniques |
| 131 | Benchmarking Beyond Single-Image Dehazing |
| 132 | RGB Space PDE-Based Image Enhancement |
| 133 | Score Reliability Based Weighting Technique for Score-Level Fusion in Multi-Biometric Systems |
| 134 | Phase-Based Binarization for Ancient Document Images |
| 135 | Learning to Predict Weather Patterns from Satellite Images |
| 136 | Complex Environment Robust Fingertip Detection |
| 137 | Blind Stereoscopic Image Quality Assessor Using Segmented Stacked Autoencoders |
| 138 | Graph-Based Image Segmentation for Object Recognition |
| 139 | Residual Learning for Salient Object Detection |
| 140 | SIFT Marked Graph Feature Vector Based Copy-Paste Detection |
| 141 | Image Rectification for Various Camera Types Mounted on a Vehicle |
| 142 | Progress Detection in Object Transfer |
| 143 | Deep Reconstruction of 3D Neuronal Structure in Tangled Neuronal Images |
| 144 | Encrypted Image Filtering and Transform Coding with Walsh-Hadamard Transform |
| 145 | Semantic Neighbor Graph Hashing for Efficient Multimodal Retrieval |
| 146 | Hyperspectral Image Classification via Stochastic HHSVMs |
| 147 | Image Denoising with Statistical Nearest Neighbors |
| 148 | Satellite Image Dual Resolution Enhancement |
| 149 | Effective Foreground Detection with Block-Based Background Modeling |
| 150 | Kinetic Modeling of Hyperpolarized Carbon-13 Pyruvate Metabolism in Human Brain |
| 151 | Image Co-Saliency Detection and Co-Segmentation with Progressive Joint Optimization |
| 152 | Novel Enhancement Algorithm for Noisy Retinex Images |
| 153 | Multi-Label Dictionary Learning for Image Annotation |
| 154 | Wireless Capsule Endoscopy Image Analysis for Automatic Hookworm Detection |
| 155 | Robust and Adaptive Edge Detection Based on Edge Proportion Statistics |
| 156 | Bayesian Foraging Strategy for Attentive Monitoring of Multiple Video Streams |
| 157 | Robust Face Recognition from Multi-View Videos |
| 158 | Graph-Based Regularization for Geometry-Consistent Light Field Super-Resolution |
| 159 | Coupled Decomposition for Large Image Matching |
| 160 | Hierarchical Feature Learning for Video Tracking |
| 161 | Biomimetic Uncorrelated Locality Discriminant Projection for Feature Extraction in Face Recognition |
| 162 | Luminance Adaptation Based Retinex Image Enhancement |
| 163 | Reducing DRAM Image Data Access Energy Consumption in Video Processing |
| 164 | Progressive Recovery Based Reversible Data Hiding in Encrypted Images |
| 165 | Saliency Prediction on Stereoscopic Videos for Attention-Driven Assessment |
| 166 | 3D Adversarial Pyramid Anisotropic Convolutional Network for Prostate Segmentation in MR Images (3D APA-Net) |
| 167 | Chrominance Feature-Based Image Retrieval in HMMD Color Space |
| 168 | Elderly Home Care: Abnormal Human Activity Recognition System Based on R-Transform and Kernel Discriminant Technique |
| 169 | Depth Map Reconstruction for Underwater Kinect Camera Using Inpainting and Local Image Mode Filtering |
| 170 | Enhancing Single Image Super-Resolution with Multi-Directional Feature Prediction and Non-Local Total Variation |
| 171 | Satellite Image Time Series Analysis for Earth Observation |
| 172 | Atmospheric Illumination Prior Network (AIPNet) for Single Image Dehazing |
| 173 | Ultrasound Imaging Enhancement Techniques |
| 174 | Soft-Edge Assisted Network for Single Image Super-Resolution |
| 175 | Motion Blur, Illumination, and Pose Invariant Face Recognition |
| 176 | Unsupervised Domain Adaptation for Visual Correspondences in Electron Microscopy Images |
| 177 | Texture Enhanced Gradient Histogram Estimation and Preservation for Image Denoising |
| 178 | Indexing Ensembles of Exemplar-SVMs with Rejecting Taxonomies |
| 179 | Knee Flexion Modeling from Multi-Pose MRI with Constrained Statistical Modelling |
| 180 | Deep Learning Enhanced Mobile Photography |
| 181 | Artificial Neural Networks for View-Invariant Action Recognition |
| 182 | Deep Reconstruction of Compressed Sensing MRI Data |
| 183 | Super-Resolution Approach for Hyperspectral Imagery with a MAP-Based Framework |
| 184 | Low-Rank Quaternion Approximation for Color Image Processing |
| 185 | Improving Radiologists’ Breast Cancer Screening Performance with Deep Neural Networks |
| 186 | Monogenic Scale Space for Target Recognition in SAR Image Classification |
| 187 | Accelerating Non-Cartesian MRI Reconstruction with k-Space Preconditioning |
| 188 | Synthesis Distortion Estimation in 3D Video with an Analytical Model |
| 189 | Multi-Label Image Classification with Deep Convolutional Neural Networks |
| 190 | Skin Detection Using Multi-Layer Graph-Based Multi-Seed Propagation |
| 191 | Land Cover Automatic Reconstruction from Historical Aerial Images |
| 192 | Locality Sensitive Deep Learning for Nuclei Detection and Classification in Routine Colon Cancer Histology Images |
| 193 | Automated Retinal Artery Vein Separation Using Graph Search Metaheuristic Approach |
| 194 | Dark Channel Priority-Based Contrast Enhancement for Configurable Haze Removal |
| 195 | Common Objects Detection in Agnostic Class Images |
| 196 | Fuzzy C-Means and Difference Image for Retinal Vessel Detection |
| 197 | Deep Reconstruction of Least Significant Bits for Bit-Depth Expansion |
| 198 | Unsupervised Rotation Factorization in Restricted Boltzmann Machines |
| 199 | Speckled SAR Images Restoration with Separated Component Analysis |
| 200 | Single Image Reflection Removal with Convolutional Neural Networks |
| 201 | Adaptive Colorspaces Linear Combination for Color Image Coding |
| 202 | Sequence-to-Sequence Similarity-Based Filter for Image Denoising |
| 203 | Acceleration of Richardson Lucy Algorithm for 3D Microscopy Image Restoration Using Scaled Heavy Ball |
| 204 | Speeding Up Image Restoration with GMM-Based Patch Priors |
| 205 | Cluster-Based Learning Framework for Automatic Depth Extraction from 2D Images |
| 206 | Empirical Bayesian Reconstruction of Distributed Sources for Electromagnetic Brain Imaging |
| 207 | Accelerating Filtering for Fast High-Dimensional Bilateral and Nonlocal Means |
| 208 | Morphological Component Analysis for Textural Difference Enhancement |
| 209 | Signal and Image Comparison Using Gaussian Blurring-Invariant Approach |
| 210 | Stability of Adaptive Features in Background Modeling for Complex Scenes |
| 211 | Real-Time Video Stabilization Using Optical Flow and Deep Learning |
| 212 | Semi-Linearized Proximal Alternating Minimization for Discrete Mumford–Shah Model |
| 213 | Learning Relative Atmospheric Visibility from Images with CNN-RNN |
| 214 | MRI Image Tumor Detection via Efficient Segmentation Methods |
| 215 | Shadow Invariant Representations of Hyperspectral Images with a Physics-Based Deep Learning Approach |
| 216 | Deep MR Brain Image Super-Resolution Using Spatio-Structural Priors |
| 217 | Linear Combination Based Atrial Electrical Activity Detection in ECG |
| 218 | New Digital Face Makeup Method |
| 219 | Deep-Learning Approximation for Efficient Image Quality Evaluation |
| 220 | LBP Edge-Mapped Descriptor Using MGM Interest Points for Face Recognition |
| 221 | Adaptive Radiometric Correction Using Deep Learning for Satellite Image Enhancement |
| 222 | Bilateral Filter and Non-Local Means Acceleration via Monte-Carlo Methods |
| 223 | Visibility Enhancement for Scale-Free Single Image Deraining with Recurrent Wavelet Learning |
| 224 | Independent Registration and Rectification for Camera Shutter |
| 225 | Multi-Constraint Feature Matching and Cross Label Propagation for RGBD Image Co-Saliency Detection |
| 226 | Augmented Lagrangian Method for Image Reconstruction in Magnetic Particle Imaging |
| 227 | Linear Full Reference Image Quality Prediction with a Detail-Based Method |
| 228 | Single Image De-Raining Using Confidence Measures |
| 229 | New Feature Descriptor for Content-Based Image Retrieval: Local Tetra Patterns |
| 230 | Deep Learning Based Stereoscopic Image Quality Assessment |
| 231 | Spectral Variability in Hyperspectral Unmixing with a Data-Driven Multiscale Model |
| 232 | Non-Small Cell Lung Cancer Survival Prediction from Tumor Heterogeneity and Overall Survival Association |
| 233 | Reinforcement Learning for Adaptive Image Compression |
| 234 | Depth Perception to Overall Experience in Blind Stereoscopic Video Quality Assessment |
| 235 | Adaptive Pixel Pair Matching for Novel Data Embedding Methods |
| 236 | Accelerometer-Based Hand Gesture Recognition with Neural Network and Similarity Matching |
| 237 | Real-Time Gated Fusion for Deformable Object Tracking |
| 238 | Extreme Sparse Learning for Robust Facial Emotion Recognition |
| 239 | Template-Free Local Symmetry Detection with Wavelets |
| 240 | Gcs De color for Contrast Preserving Gradient Correlation Similarity De colorization |
| 241 | Simultaneous Tracking and Recognition in Wide-Area Scenes Using Hierarchical Graphical Models |
| 242 | CNN Visualizing Discriminative Regions with Unraveling Fixations Approach |
| 243 | Steganalysis of Least Significant Bit Replacement in Grayscale Natural Images |
| 244 | Audio-Visual Keyword Spotting with Adaptive Decision Fusion Based Lip Descriptor |
| 245 | Structural Smoothness and Reweighted Low-Rank Matrix Analysis for Image Denoising |
| 246 | Adaptive Scale Selection in Edge-Based Defocus Blur Estimation |
| 247 | Texture Classification via Sorted Consecutive Local Binary Pattern |
| 248 | Multi-Layer Lightness Statistics for Naturalness Preserved Image Enhancement |
| 249 | Robust Group-Sparse Representation Variational Method for Face Recognition Applications |
| 250 | Real-Time Secure Text Transmission Using Video Cryptography |
| 251 | Diffusion Mechanisms Security Analysis for Image Encryption |
| 252 | Morphology-Based Noise Reduction with Structural Variation and Thresholding in Bitonic Filter |
| 253 | Cross-Domain Image Disentanglement and Classification via Multi-Domain Representation |
| 254 | Transductive Learning Approach for Depth Super-Resolution |
| 255 | Image Equalization and Contrast Enhancement Using Gaussian Mixture Modeling |
| 256 | Semantic Label Embedding Dictionary Representation for SLED Multi-label Image Annotation |
| 257 | Reversible Watermarking Scheme Using Rie Transformation |
| 258 | Explicit Coherence Regularization in Continuous Random Walk Model for Image Segmentation |
| 259 | Blind Image Deblurring Combining Inertial Measurements with Distance Transform |
| 260 | Restoration of Old Documentary Films Using Deep Learning and Frame Interpolation |
| 261 | Salient Object Detection in the Wild with Inner and Inter Label Propagation |
| 262 | Image Restoration with Rank Residual Constraint: Rank Approximation vs. Rank Estimation |
| 263 | Gaussian Mixture Model Based High Accuracy Retinal Layer Segmentation in Optical Coherence Tomography |
| 264 | Enhancing Salient Object Detection with a Focal Boundary Approach |
| 265 | Histogram-Based Operations for Efficient Scalable Median Filtering |
| 266 | Unsupervised Image Super-Resolution with Multi-Cycle-in-Cycle Generative Adversarial Networks |
| 267 | Robust Semantic Template Matching with Superpixel Region Binary Descriptor |
| 268 | Fuzzy Classification and Contextual Region Growing Based Combined Approach for Image Segmentation |
| 269 | Detecting Image Forgery using Hybrid LSTM and Encoder-Decoder Architecture |
| 270 | Deep Learning Reconstruction Framework for Incomplete Data in Differential Phase-Contrast Computed Tomography |
| 271 | Local Metric for Defocus Blur Detection Based on CNN Feature Learning |
| 272 | Generative Adversarial Networks for Image-to-Image Translation |
| 273 | Shape-Based Normalized Cuts for Biomedical Segmentation Using Spectral Relaxation |
| 274 | Deep Visual Saliency in Stereoscopic Image Enhancement |
| 275 | Deep Spatial and Temporal Network for Robust Visual Object Tracking |
| 276 | Automated Multiscale Morphometry from Second Harmonic Generation Microscopy with Tensor-Based Processing |
| 277 | Visual Cryptography for General Access Structures with Image Size Invariance |
| 278 | Cloud Image Compression Region-Based Prediction |
| 279 | Total-Variation-Based Wavelet Domain Inpainting via Primal–Dual Method |
| 280 | Multi-Channel and Multi-Model-Based Auto Encoding Prior for Grayscale Image Restoration |
| 281 | Morphological Component Analysis for Noise Reduction in Medical Imaging |
| 282 | Indian Vehicle Number Plate Detection System |
| 283 | Video Impairment Detection and Mapping Techniques |
| 284 | Discovery of Visual Co-Occurrence Patterns in Context-Aware Environments |
| 285 | Robust Object Tracking with Inverse Sparse Group Lasso Model |
| 286 | Weighted `0 Shearlet-Based Method for Efficient Sparse Optimization in Image Deblurring |
| 287 | Locally Adaptive Saliency Map Fusion for Co-Saliency Detection in Images |
| 288 | Biological Vision Inspired Image Enhancement Framework for Low Visibility Conditions |
| 289 | Deeply Supervised Networks for Automated Breast Ultrasound Cancer Detection |
| 290 | Overall Enhancement Procedure in Wavelet-Based Single Image Super-Resolution |
| 291 | Hybrid Multiview Stereo Algorithm for Urban Scene Modeling |
| 292 | Human Detection Using Quadratic Classification on Subspace of Extended Histogram of Gradients |
| 293 | Deep Generative Prediction for Image Quality Assessment |
| 294 | Sequential Energy Minimization for Joint Demosaicing and Denoising |
| 295 | Square Sampling Lattice Pixel Binning for High Dynamic Range Color Image Sensor |
| 296 | Compressive Bilateral Filtering Technique |
| 297 | Gradient Profile Sharpness Based Single Image Super-Resolution |
| 298 | Deep Learning-Based Just Noticeable Distortion Prediction Model for Image Compression |
| 299 | Beyond Classical Receptive Field: IEEE Publication Principles Violation Notice for Tone Mapping |
| 300 | Methodology for Dividing and Counting Generic Objects in Images |
| 301 | Deep Learning for Joint Image Demosaicing and Denoising |
| 302 | Bayesian Regularization Approximation with Local Kernels and Proximal Operators |
| 303 | Hierarchical Super-Resolution-Based Inpainting |
| 304 | No-Reference Tensor Oriented Image Quality Evaluation for Light Field Images |
| 305 | Joint Color-Guided Internal and External Regularization for Depth Map Super-Resolution |
| 306 | Optimal Out-Of-Core Image-Set Processing Streaming Architecture (ISP) for Parallel Heterogeneous Systems |
| 307 | Superpixel-Based Similarity Index (SPSIM) for Full-Reference Image Quality Assessment |
| 308 | Dynamic Scene Deblurring with Depth Guided Model |
| 309 | Heterogeneous Face Recognition with Mutual Component Convolutional Neural Networks |
| 310 | Super-Resolution of Depth Maps Based on Hierarchical Feature Residual Learning |
| 311 | Scene Text Removal and Inpainting in Urban Environments |
| 312 | Phase Asymmetry Ultrasound Despeckling with Fractional Anisotropic Diffusion and Total Variation |
| 313 | Histogram of Oriented Gradients for Hand Gesture Recognition |
| 314 | Multistage Generative Adversarial Network for Fabric Defect Detection |
| 315 | High-Order Pooling and Encoding Gaussians Over a Dictionary for Advanced Image Analysis |
| 316 | Blind Deblurring of Natural Stochastic Textures Using Anisotropic Fractal Model and Phase Retrieval Algorithm |
| 317 | Sparse Orthonormal Transforms for Image Approximation and Compression |
| 318 | Residual Learning of Deep CNN for Image Denoising Beyond a Gaussian Denoiser |
| 319 | Shadow Detection of Man-Made Buildings in High-Resolution Panchromatic Satellite Images |
| 320 | Multiply-Distorted Image Quality Assessment in Gradient Domain |
| 321 | Low-Rank Matrix Decomposition Assistance in Super-Resolution Internal and External Learnings |
| 322 | Cross Wavelet Transform for ECG Pattern Analysis and Classification |
| 323 | Neighbor Embedding Methods for Image Prediction |
| 324 | Color Local Texture Features Application in Color Face Recognition |
| 325 | Targeted Databases for Adaptive Image Denoising |
| 326 | Multimodal Fusion for Improved 3D Object Recognition |
| 327 | Patch-Based Image Restoration Using Inpainting and Denoising Techniques |
| 328 | Iterative Back-Projection with Enhanced Noise Resistance |
| 329 | Fixed Pattern Noise Robust Removal on Multi-Focus Images |
| 330 | 3D Facial Reconstruction from 2D Images Using Deep Learning |
| 331 | Image Restoration Combining Low-Rank Patch Regularization and Global Structure Sparsity |
| 332 | Single Photograph Graph-Based Blind Image Deblurring |
| 333 | Pixel wise Image Saliency Aggregation with Coherence and Appearance Contrast Measures |
| 334 | Aurora Image Retrieval with Polar Embedding Technique |
| 335 | Rate-Distortion Optimized Decomposition of Multiview Imagery into Diffuse and Specular Components |
| 336 | Hyperspectral Image Classification with Semi-Supervised Deep Learning Using Pseudo Labels |
| 337 | Convolutional Neural Networks for Deformable Image Registration with Progressive Training |
| 338 | Moving Object Detection in Complex Scenes with Spatiotemporal Structured-Sparse RPCA |
| 339 | Real-Time Detection of Neonatal Clonic Seizures with Low-Complexity Image Processing |
| 340 | Adaptive Matching Framework for Compact Feature Descriptor in Face Recognition |
| 341 | Edge-Preserved Image Resizing Using Deep Learning |
| 342 | Video Frame Prediction and Interpolation with Deep Learning |
| 343 | Reproducible Kernel Hilbert Space and Heaviside Function-Based Variational Pansharpening Approach |
| 344 | 3D Layout Extraction from Single Images Using Global Structures |
| 345 | Background Subtraction with Low-Rank and Structured Sparse Decomposition |
| 346 | Video-Based Image Analysis with Morphological Contrast Enhancement |
| 347 | Interactive Image Retrieval with Semisupervised Biased Maximum Margin Analysis |
| 348 | Automatic Registration of Images with Inconsistent Content through Line-Support Region Segmentation |
| 349 | Embedding Quality from Noisy Image Labels with Deep Learning |
| 350 | Angular Pattern for Shape Retrieval |
| 351 | Deep Learning from Boundaries to Higher-Level Tasks with Crisp Boundaries |
| 352 | Biomedical Images Contrast-Independent Curvilinear Structure Detection |
| 353 | Real-Time Panorama Construction from Unmanned Aerial Vehicle Imagery |
| 354 | Direction-Aware Optimization Approach for 3D Tree Modeling |
| 355 | Pseudo Depth Salient Object Detection in RGB-D Images |
| 356 | Trace Transform Functionals for One Class Classification in Mammograms |
| 357 | Secret Fragment Visible Mosaic Images by Nearly Reversible Color Transformations for Secure Image Transmission |
| 358 | Image Quality Assessment Using Deep Belief Networks |
| 359 | Automated Semantic Segmentation in Urban Scenes for Autonomous Driving |
| 360 | Hierarchical Centroid Shape Descriptor for Automatic Brain Tumor Tissue Detection in MRI Images |
| 361 | Reverse Attention-Based Residual Network for Salient Object Detection |
| 362 | State-of-the-Art Automatic License Plate Recognition Review |
| 363 | Fast Alternating Minimization for Robust Multichannel Blind Deconvolution |
| 364 | Nonparametric Joint Shape and Feature Priors for Dendritic Spine Segmentation |
| 365 | Generalizing the Dark Channel Prior for Enhanced Single Image Restoration |
| 366 | Optimized Vector Bilateral Filter for Multispectral Image Denoising |
| 367 | Binocular Responses for No-Reference 3D Image Quality Assessment |
| 368 | Single Sample Face Recognition Techniques |
| 369 | Collaborative Support-Agnostic Recovery for Image Denoising |
| 370 | Wavelet Domain Interpolation with Edge Extraction for Super Resolution Image Generation |
| 371 | Digital Privacy and Security: Palm Print as a Smartphone Biometric |
| 372 | Deep Feature Transfer Learning for Medical Image Diagnosis |
| 373 | Iterative Triclass Thresholding Technique in Image Segmentation |
| 374 | Tumor ROI Estimation in Ultrasound Images via Radon Barcodes |
| 375 | High Dynamic Range Imaging Operator with Deep Tone Mapping |
| 376 | Her2Net: Deep Semantic Segmentation and Classification Framework in Breast Cancer Evaluation |
| 377 | Supervised Polarimetric SAR Image Classification Using Tensor Local Discriminant Embedding |
| 378 | Multi-Scale Nonlocal Contrast Enhancement with Fractional Order Variational Framework for Retinex |
| 379 | Multiple Light Sources Adaptation in Color Constancy |
| 380 | Perception-Based Image Processing in a Unified Color Space |
| 381 | Pore-Scale Facial Features for High-Resolution Verification |
| 382 | Geometrical Interpretation of Robust PCA Based on Incoherence |
| 383 | Similarity Domain Wiener Filter for Single Image Super-Resolution |
| 384 | Triangular Facet Approximation for Local-Adaptive Image Alignment |
| 385 | Connected Components Objects Feature for Content-Based Image Retrieval |
| 386 | Reflecting Lossless Features and Weighted Structural Loss for Enhanced Salient Object Detection |
| 387 | Multistructure Data Accelerated Hypothesis Generation |
| 388 | Emotion Detection with Fast and Robust Neutral Face Classification |
| 389 | Non-Linear Image Fusion Using Variational Osmosis |
| 390 | Cartoon and Texture Image Decomposition with Non-Local Dual-Domain Approach |
| 391 | Anomaly Detection in Retinal OCT Using Epistemic Uncertainty of Anatomy Segmentation |
| 392 | Scene-Adapted Gaussian-Mixture-Based Denoising for Convergent Image Fusion |
| 393 | Unbiased Distance Non-Local Adaptive Means with Wavelet Shrinkage Multipatch |
| 394 | Facial Expression Recognition with Attention Mechanism and Occlusion CNN |
| 395 | Multi-Atlas Registration Framework for Multimodal Pathological Images Using Conventional Monomodal Atlases |
| 396 | External and Internal Correlations Exploring for Image Denoising |
| 397 | Camera Shake Removal with Weighted Fourier Burst Accumulation |
| 398 | Imaging-Based Neurodegenerative Disease Classification Using Salient Brain Pattern Extraction |
| 399 | CASAIR: Content And Shape-Aware Image Retargeting |
| 400 | Dynamic Scenes Synthetic Video Sequence Generation |
| 401 | Transform for Low Distortion in Reversible Watermarking |
| 402 | Adaptive Filter and ICA for Noise Cancellation in Video Frame Analysis |
| 403 | JPEG/JPEG 2000 Decompression Using TGV and Shearlet Transform for Cartoon-Texture Approach |
| 404 | Stereoscopic Photo Authoring with Casual Approach |
| 405 | Digital Image Processing Classification of Dielectric Barrier Discharges |
| 406 | Binocular Receptive Field Properties Learning for Full-Reference Quality Assessment of Stereoscopic Images |
| 407 | Unified Semi-Supervised Subspace Clustering with Discriminative and Coherent Structure |
| 408 | Digital Holographic Image Cell Segmentation |
| 409 | Image Synthesis with Conditional Generative Adversarial Networks |
| 410 | Low Rank Embedding for Robust Image Feature Extraction |
| 411 | Quaternion Matrix Analysis for Color Image Vector Sparse Representation |
| 412 | Fine-Grained Retrieval with Hashing and Deep Saliency |
| 413 | Spatiotemporal VLAD Emphasizing Action Stages for Video Action Recognition |
| 414 | LIME: Low-Light Image Enhancement via Illumination Map Estimation |
| 415 | Robust Retinex Model for Structure-Revealing Low-Light Image Enhancement |
| 416 | Adaptive Gradient Field Sharpening Transform for Local Image Super-Resolution |
| 417 | Multi-Texture Model with Level Sets for Multi-Region SAR Image Segmentation |
| 418 | Denoised Image Quality Assessment Using Corrupted Reference Images |
| 419 | Semi-Supervised Learning for Image Dehazing |
| 420 | Hazy Image Decolorization and Color Contrast Restoration |
| 421 | Unified Quality Scale from Pairwise Comparisons and Ratings |
| 422 | Parallax Tolerant Light Field Stitching in Hand-Held Plenoptic Cameras |
| 423 | Encoding Mode Selection in HEVC with Noise Reduction Strategy |
| 424 | Deep Learning for Image De-raining and De-snowing |
| 425 | Blind Prediction of Natural Video Quality |
| 426 | Implicit Negative Sub-Categorization and Sink Diversion in Object Detection |
| 427 | Learning Fundamental Visual Concepts from Related Images and Text |
| 428 | Tensor Decomposition and PCA Joint Algorithm for Hyperspectral Image Denoising |
| 429 | Remote Sensing Image Retrieval with Three-Layered Graph-Based Learning Approach |
| 430 | Saliency Detection Using Absorbing Markov Chain with Learnt Transition Probability |
| 431 | Short-Term Windows Application in Video In painting for Object Removal |
| 432 | Multiple Blurry Measured Images Reconstruction to a Single Image |
| 433 | Gaussian-Mixture-Model-Based Spatial Neighborhood Relationships for Pixel Labeling |
| 434 | Gated-GAN: Adversarial Gated Networks for Multi-Collection Style Transfer |
| 435 | Random Walk with Restart for Spatiotemporal Saliency Detection in Video Sequences |
| 436 | Spectral-Spatial Classification for Hyperspectral Imaging with 3D Convolutional Neural Networks |
| 437 | Learning Receptive Fields and Quality Lookups for Blind Quality Assessment of Stereoscopic Images |
| 438 | Skin Color Incorporated for Improved Face Detection and Tracking |
| 439 | Full-Scale Injection Coefficients Regression for Enhanced Panchromatic Sharpening |
| 440 | Hybrid Network Based Face Detection with Viola-Jones |
| 441 | Online Kernel Slow Feature Analysis for Temporal Video Segmentation |
| 442 | Reversion Correction and Regularized Random Walk Ranking in Saliency Detection |
| 443 | Scene Prior and Reference Retrieval Driven Image Haze Removal |
| 444 | Anisotropic Filtering for Enhanced Image Detailing |
| 445 | Wavelet-Based Spectral-Spatial Transforms for CFA-Sampled Raw Camera Image Compression |
| 446 | Lossless Color Image Compression with Hierarchical Prediction and Context Adaptive Coding |
| 447 | Converged Propagations and Deep Prior Ensemble for Image Enhancement |
| 448 | Aerial Scene Classification Using a Densely-Connected ConvNet |
| 449 | Joint Denoising and Deblurring of Low-Light Color Images with RGB-NIR Imaging and Exposure Bracketing |
| 450 | Completely Blind Image Quality Evaluator Enriched with Features |
| 451 | Anchor Cascade for Efficient Face Detection |
| 452 | Single Image Haze Removal Using Deep Convolutional Networks |
| 453 | Frame Rate Up Conversion and HEVC Coding Integration Based on Rate-Distortion Optimization |
| 454 | Spatio-Temporal Matching for Human Pose Estimation in Video |
| 455 | Multilevel Patch-Based Context Analysis for Lung Nodule Classification |
| 456 | Nonlocal Tensor Representation for Color Demosaicking |
| 457 | Multilevel Rank Analysis in Intrinsic Feature Space for Structure-Sensitive Saliency Detection |
| 458 | Multi-Organ Nucleus Segmentation Challenge |
| 459 | Self-Recovery Fragile Watermarking Scheme Performance Analysis |
| 460 | Efficient License Plate Detection Approach |
| 461 | Impulse Noise Removal via Sparse and Low-Rank Decomposition of a Hankel Structured Matrix |
| 462 | Convolutional Neural Networks for Fingerprint Liveness Detection |
| 463 | Statistical Model for JPEG Noises and its Application in Quantization Step Estimation |
| 464 | Polyphase Down-Sampling for Multiple Description Image Coding |
| 465 | Imagehawk: Content-Based Image Retrieval System |
| 466 | Graph-Based Artery Vein Classification in Retinal Images |
| 467 | RGB-T Salient Object Detection by Fusing Multi-Level CNN Features |
| 468 | Dynamic Routing Residue Recurrent Network for Video Rain Removal (D3R-Net) |
| 469 | Hyper-spectral Image Denoising Using Low-Rank Matrix Factorization |
| 470 | Variable Exponent Based Adaptive Perona-Malik Model for Image Denoising |
| 471 | Adaptive Digital Image Watermarking with PSO, DWT, and XFCM |
| 472 | Adaptive Gamma Correction with Weighting Distribution for Efficient Contrast Enhancement |
| 473 | Pulmonary Fissure Detection in CT Images with Derivative of Stick Filter |
| 474 | Improved Multiplicative Spread Spectrum Scheme for Data Hiding |
| 475 | Saturation-Based Single Image Dehazing Transmission Map Estimation |
| 476 | Dilated Convolutions for Single Image Super-Resolution (DCSR) |
| 477 | Adaptive Pulse Wave Imaging for Automated Spatial Vessel Wall Inhomogeneity Detection |
| 478 | MRF-Based Multi-Feature Fusion for Remote Sensing Image Classification |
| 479 | Privileged Modality Distillation for Intracoronary Imaging Vessel Border Detection |
| 480 | Automatic Video Object Extraction with Visual and Motion Saliency |
| 481 | Saliency Detection with Adaptive Metric Learning |
| 482 | Visual Saliency Learning for Fixation Prediction Model |
| 483 | Reinforcement Learning-Based Hierarchical Searching for Tracking and Verification |
| 484 | Random Geometric Prior Forest for Object Segmentation in Multiclass Scenes |
| 485 | Fast Fog and Haze Removal Method |
| 486 | No-Reference Sharpness Assessment in Autoregressive Parameter Space |
| 487 | Missing MRI Pulse Sequences Synthesis Using Multi-Modal Generative Adversarial Network |
| 488 | Smooth Patch Ordering in Image Processing |
| 489 | CNN-Based Joint Hand Detection and Rotation Estimation |
| 490 | Multi-Exposure Images for Learning Deep Single Image Contrast Enhancers |
| 491 | Visually Tracking Dense Cell Populations with Dynamic-Shape-Prior Guided Snake Model |
| 492 | Super-Resolution Reconstruction of Satellite Imagery |
| 493 | Adaptive Background Modeling for Dynamic Scenes in Surveillance Video |
| 494 | Semantic Prior Analysis for Salient Object Detection |
| 495 | Rectification for Different Types of Cameras Attached to a Vehicle |
| 496 | Fractional Boundaries Enhancement for Multi-View Object Extraction |
| 497 | Data Fusion for Human Action Recognition with Depth, Skeleton, and Inertial Sensors |
| 498 | Compressive Color Pattern Detection with Partial Orthogonal Circulant Sensing Matrix |
| 499 | Comparative Study of Various Image Fusion Techniques |
| 500 | Deep Neural Networks for Real-Time Natural Scene Text Recognition |
| 501 | CPA-SLAM: Consistent Plane-Model Alignment for Direct RGB-D SLAM |
| 502 | Eye Localization with Rotation Invariance Using Novel Method |
| 503 | Adaptive Edge-Preserving Smoothing Regularization for Robust Single-Image Super-Resolution |
| 504 | Extreme Value Theorem Based Classification of Volumetric Images Using Multi-Instance Learning |
| 505 | Enhancing Low-Resolution Face Recognition in the Wild with Selective Knowledge Distillation |
| 506 | 3D Face Morphing with Depth Parameters for Head Pose Estimation from 2D Images |
| 507 | Smartphone Footprint Prototype with Computational Imaging Techniques for Finger Vein Biometric |
| 508 | Synthesis of Cascaded Face Sketches in Various Illuminations |
| 509 | DWT Based Medical Image Fusion with Maximum Local Extreme |
| 510 | Unsupervised Pixel Pairwise-Based Markov Random Field Model for Multimodal Change Detection |
| 511 | Sub-Level Average Energy Silhouette Images for Human Activity Recognition |
| 512 | Stereo-Based Pedestrian Detection with Feature-Based ROI Generation |
| 513 | Parametric Contours with Free Endpoints for Image Segmentation |
| 514 | Low Light Video Enhancement Using Deep Neural Networks |
| 515 | Reversible Color to Grayscale Conversion Framework with Embedded Watermarking |
| 516 | Real-Time Deep Learning for Medical Imaging Analysis |
| 517 | Perceptual Distinguishability Predictor for JND-Noise-Contaminated Images |
| 518 | Colors, Shapes, and Motions Integration for Active Contour-Based Visual Tracking |
| 519 | No Reference Image Quality Assessment Metric for 3D Synthesized Views (Niqsv) |
| 520 | Deep Retinal Image Segmentation Under Geometric Priors with Regularization |
| 521 | Temporal Correlation and Low-Rank Matrix Completion for Video De raining and Desnowing |
| 522 | Estimating Smoke Density using a Wave-Shaped Deep Neural Network |
| 523 | Multi-Layer Graph Structure and Random Walks for Multi-Attributed Graph Matching |
| 524 | Compressed Sensing Based Secret Image Sharing Scheme |
| 525 | Intelligent Image Resizing Using Seam Carving and Deep Learning |
| 526 | MLP Neural Network Classifier for Medical Image Segmentation |
| 527 | Online Subspace Learning from Gradient Orientations for Robust Image Alignment |
| 528 | DERF: Distinctive Efficient Robust Features from P Ganglion Cells Biological Modeling |
| 529 | Supervised Temporal t-SNE for Human Action Recognition in Silhouette Analysis |
| 530 | Intelligent Surveillance System Based on Deep Learning Object Detection |
| 531 | Retinal Vascular Network Topology Reconstruction and Artery Vein Classification via Dominant Set Clustering |
| 532 | Spatial and Angular Resolution Enhancement of Light Fields with Convolutional Neural Networks |
| 533 | High-Quality Pan-sharpening using Bayesian Methods |
| 534 | Multiband Image Processing for Hyper connections and Hierarchical Representations |
| 535 | One-Shot Multispectral Imaging System Using a Single Image Sensor |
| 536 | LBP-Based Defocus Blur Segmentation |
| 537 | Skin Tumor Segmentation in 3D Ultrasound Images Using Multi-Grid Phase Fields |
| 538 | Weighted Guided Image Filtering Technique |
| 539 | Raw High Frame Rate Video Denoising and Super-Resolving with Joint Non-Gaussian Approach |
| 540 | DenseFuse: Dense Fusion Approach for Infrared and Visible Image Integration |
| 541 | Segmented Cancer Care Coordination via a Smartphone App Framework |
| 542 | Structural Patch Decomposition for Robust Multi-Exposure Image Fusion |
| 543 | IDGCP: Pre-Haze Image Gamma Correction Method |
| 544 | Penalized Maximum-Likelihood Patlak Parametric Image Reconstruction for Lesion Detection in Dynamic PET |
| 545 | Compressive Blind Deconvolution Approach for Enhanced Ultrasound Image Reconstruction |
| 546 | Lower Bound Transmission Estimation in Single Image Dehazing Using Non-Linear Function |
| 547 | Hierarchical Approach for Rain or Snow Removal in Single Color Images |
| 548 | Grassmannian Graph for Affine Invariant Feature Matching |
| 549 | Single Tucker Decomposition Network Learning for Multiple Bits-per-Pixel Rates Lossy Image Compression |
| 550 | Saliency-Based Dictionary Learning Framework for Image Similarity (SDL) |
| 551 | Sparse Coding Benchmark when Group Sparsity Meets Rank Minimization |
| 552 | Diffusion-Based New Approach to Edge Detection |
| 553 | Local Frequency Analysis for Illumination Invariant Stereo Matching |
| 554 | Privacy Protection of Medical Data |
| 555 | Natural Image Linear Motion and Out-of-Focus Blur Estimation for Blind Restoration |
| 556 | Multi-Resolution Analysis for Raw Image Sensor Data Compression |
| 557 | Depth Image Super-Resolution with Deep Color Guided Coarse-to-Fine Convolutional Networks |
| 558 | Super-Resolution and Denoising of Medical Images with Novel Example-Based Methods |
| 559 | Parallel Attentive Correlation Tracking |
| 560 | Automated Segmentation of Brain Tumors Using Deep Convolutional Networks |
| 561 | Applications for Blur-Robust Face Recognition Descriptor |
| 562 | Correlating Subjective and Objective Ratings in Image Quality with Monotonic Regression |
| 563 | Scene Understanding and Labeling with Deep Learning for Smart Cities. |
| 564 | Homomorphic Encrypted Domain Discrete Wavelet Transform and Data Expansion Reduction |
| 565 | Sparse Representation for Brain Signal Processing: A Tutorial on Methods and Applications |
| 566 | Sparse Representation Based Fingerprint Compression |
| 567 | Nodal Sampling for SMOS Image Reconstruction |
| 568 | Shadow Detection in High-Resolution Panchromatic Satellite Images of Man-Made Buildings |
| 569 | Fusion for Underwater Image Enhancement with Color Balance |
| 570 | Morphological Reconstruction-Based Image Dehazing Algorithm |
| 571 | Hierarchical Unequal Merging for SAR Image Segmentation |
| 572 | Video Quality and Resolution Enhancement from Multiple Descriptions via Convex Optimization Framework |
| 573 | Diffusion-Based Compactness and Local Contrast for Salient Region Detection |
| 574 | Foveated Video Quality Assessment with Attention-Driven Approach |
| 575 | Real-World Noisy Image Denoising via External Prior Guided Internal Prior Learning |
| 576 | Threshold-Based Secret Sharing in An Image Watermarking Scheme |
| 577 | Automatic Fake Indian Currency Note Recognition |
| 578 | Double Orientation Histogram for Fast Representation in Local Image Descriptors |
| 579 | Performance Evaluation of Different Inpainting Algorithms for Remotely Sensed Images |
| 580 | Adaptive Residual Networks for High-Quality Image Restoration |
| 581 | Traffic Sign Detection and Recognition Techniques |
| 582 | Sparse Salient Regions Highlighting in Image Signature |
| 583 | Extended Depth of Field in Brightfield Microscopy Using Gaussian PSF Model |
| 584 | Retargeted Image Quality Assessment with Multiple-Level Feature-Based Measurement |
| 585 | NIQSV+: No-Reference Synthesized View Quality Assessment Metric |
| 586 | Automated Image Captioning with Convolutional and Recurrent Neural Networks |
| 587 | Security Verification with Spatial Fusion in Joint FED Watermarking System |
| 588 | Security X-Ray Image Detection Performance Prediction Based on Image Quality |
| 589 | Fine-Grained Image Classification with Object-Part Attention Model |
| 590 | Optical Coherence Tomography Images Segmentation with Deep Neural Network Regression |
| 591 | Multi-Scale Feature Detection for Scene Reconstruction with MSFD (Multi-Scale Segmentation-Based Feature Detection) |
| 592 | Vehicular Camera Based Automatic Detection of Red Light Running |
| 593 | Transfer Learning for Generalized Image Restoration Discriminative Approach |
| 594 | Automatic Cataract Classification Using Deep Neural Networks with Discrete State Transitions |
| 595 | Color Descriptor Based No-Reference Image Quality Assessment |
| 596 | Regression-Based Feature Map Quality Score Estimation |
| 597 | Graph-Regularized Locality-Constrained Joint Dictionary and Residual Learning for Face Sketch Synthesis |
| 598 | Automatic Dynamic Texture Segmentation Using Local Descriptors and Optical Flow |
| 599 | Sparse Coding Based Novel Keypoint Detector |
| 600 | One-View Occlusion Detection for Stereo Matching with Fully Connected CRF Model |
| 601 | Part Loss Deep Representation Learning for Person Re-Identification |
| 602 | Submodular Proposal Selection for Video Object Segmentation in Weakly Labeled Images |
| 603 | Active Curve Recovery of Region Boundary Patterns |
| 604 | Natural Image Demosaicing in Compressive Framework |
| 605 | Global Mammographic Image Feature Analysis for Predicting Malignant Case Likelihood |
| 606 | Continuous Adaptive Data Fusion and Model Relearning for Particle Filter Tracking with Multiple Features |
| 607 | Steering Kernel Weighted Guided Image Filtering |
| 608 | Non-Local Means Denoising with Novel Speed Up Strategies using Patch and Edge Patch Based Dictionaries |
| 609 | Superpixel Segmentation via Differential Evolutionary Optimization |
| 610 | ArtGAN: Conditional Synthesis Improvement for Natural Images and Artworks |
| 611 | Luminosity and Contrast Adjustment Based Color Retinal Image Enhancement |
| 612 | Advanced Spherical Motion Model and Local Padding for 360 Video Compression |
| 613 | Multi-Matting and Edge Model Based Robust Multi-Focus Image Fusion |
| 614 | Low Light Image Enhancement via Fractional-Order Variational Retinex Model |
| 615 | Variational Image Dehazing Based on Fusion |
| 616 | Hierarchical Metrics and Classification with Related and Unrelated Tasks |
- Latest Electrical Projects Ideas
- Power Systems Project Ideas
- Top Electrical Major Project Titles
- Automobile Engineering Projects
- Digital Signal Processing Projects
