Reading: Difference Between Wattmeter and Energy Meter
Inst Tools > Blog > Electrical Basics > Difference Between Wattmeter and Energy Meter
In this article, we will learn the difference between wattmeter and energy meter in electrical engineering.
Last updated: May 17, 2023 1:20 pm
Electrical Basics
7 Min Read
Electrical power is always required to be measured in terms of power, current, voltage, or energy. These parameters help in understanding the behavior of electrical supply and can thus assist in proper engineering.
What is a Wattmeter?What is an Energy Meter?Difference Between Wattmeter and Energy Meter
There are many devices in electrical engineering for measurement purposes, but the ones we will discuss here are used mainly to measure power and energy.
In this article, we will learn about two of the most commonly used devices – wattmeter and energy meter; and understand the difference between them.
Electrical power is measured in Watts. The wattmeter has three major components – active power, reactive power and apparent power; the one which is used to measure the active electrical power (also known as true power or real power) present in a circuit is called a wattmeter. In simple terms, it will show you how much power is currently present in an electrical circuit, in Watts.
Power is derived by the formula – P=V*I*Power factor. Traditionally, if you connect the three meters in series – voltmeter, ammeter, and power factor meter, then you can get the value of power. But, instead of connecting three different meters, just use a single wattmeter. A wattmeter consists of a current coil and a pressure/voltage coil.
Refer to the below image for understanding. Let us first decode the short keys described – M stands for mains, L stands for load, C stands for common, V stands for voltage, CC stands for current coil, PC stands for pressure coil and VC stands for voltage coil. The current to be measured depends on the number of turns in the coil.
wattmeter consists of current coil and voltage coil
They must be numbered in such a way that they will provide low resistance and high inductance path, with the least voltage drop. This coil is always connected in series with the load.
The voltage to be measured depends on the resistance provided. It must be such that they provide high resistance and allow the least current to flow; thus showing voltage developed. It is connected in parallel with the load.
The load current through the current coil produces a magnetic field that is directly proportional to the current through the coil. This magnetic field can produce a torque in the pressure coil. A pointer is attached to the pressure coil and can move over a scale to show the power reading.
Electrical energy consumption is measured in kilowatt-hours. An energy meter is an equipment which is used to measure electrical power or energy consumed in a circuit by the load. In simple terms, it will show you how much power is currently consumed by the load in an electrical circuit, in kWh.
Electrical energy consumption is derived by the formula – Energy = Integral of power with respect to the derivative of time. Basically, when you want to find out how much energy has been consumed by the load in one hour, then you will require an energy meter to measure it.
Here, one unit of energy is equal to one kilowatt of power consumed in one hour. They measure power first (in an energy meter, it is properly calculated as instantaneous power), and then it is integrated over a period of time.
The most commonly used type of energy meter is the induction one. An electromechanical induction-type energy meter works on the principle of a rotating magnetic field, which is produced by an AC current flowing through two magnetic coils.
Between these coils, a rotating magnetic disc is located. The emf is induced in the disc through the rotating magnetic field and it starts rotating. The rotation is proportional to the power consumed by the load.
Some of the main differences between a wattmeter and an energy meter are mentioned below.
  1. Wattmeter will just show the total power present in the circuit, but the energy meter will show the total actual power consumed by a circuit.
  2. Wattmeter measures in watts, whereas energy meter measures in kWh.
  3. There are two types of wattmeter namely electrodynamometer type wattmeter (for both DC and AC power) and induction type wattmeter (for AC power measurement), whereas the types of energy meters are electromechanical induction type energy meter, electronic energy meter, and smart energy meter.
  4. The major parts of a wattmeter are the current coil, pressure coil, damping system, control mechanism, scale, and pointer; whereas the major parts of an energy meter are: the current coil, voltage coil, rotating aluminum disc, breaking system, and counting mechanism.
  5. Wattmeter is generally used to measure the power ratings of a device, whereas an energy meter is used to measure electricity consumed by various units.
  6. The Wattmeter works on the principle that the force acts on the current-carrying conductor when it is placed in an electromagnetic field. Whereas, the energy meter works on the principle of conversion of electrical energy into mechanical energy.
  • List of Electrical Drawings
  • Bus Coupler in Electrical Panel
  • Servo Motor versus DC Motor
  • PVC, XLPE, and Insulated Cables
  • Difference between AC and DC
Advantages of Valve Regulated Lead Acid (VRLA) Batteries
What is an ELV System? – Extra Low Voltage
Formula of AMP, KW, KVA, HP for AC and DC Voltages
MCB vs Fuse Questions and Answers
What is an Electrical Conduit? – Types – How to Choose?
Difference Between MPCB and MCCB
Why Do We Need to Connect Transformers in Parallel?
What is Electrical Slip Ring? Principle, Types, Advantages, Applications
What is a Magnetic Contactor? – Principle, Types, Advantages
Difference Between RCCB and MCCB
Difference Between Power Cable and Instrument Cable
Types of Relays used in an Air Circuit Breaker (ACB)
How does an Electric Motor Operate? – AC Motor Fundamentals
Difference between Current Transformer and Potential Transformer
Motor Control Center Purpose
Motor Control Center – Purpose, Classification, and Advantages
What are HP and LP Switches in HVAC
Motor Maintenance
Motor Maintenance, Troubles, Regular Checks, Performance
Armoured cable
What is an Armoured Cable? Classification of Cables
How do AC drives work
How do AC Drives Work? – Variable Frequency Drive (VFD)
Electrical Maintenance Engineer's Biggest Enemy
Electrical Components Overheating – Causes, Troubles, Prevent
pressure switch ladder-logic diagram
Draw the appropriate Pressure Switch Symbol ?
Fieldbus Flow Transmitter Configuration
Difference between Motion Controller and PLC
DC Machine
DC Machines Construction
Transmitter Range and Sensor Limits
Transmitter Minimum Span, Accuracy & Turndown
Electrical Ground Loop
How to Solve Electrical Ground Loop Problems?
What is a Feedback Control System
What is a Feedback Control System? Types & Advantages
Armature Quiz
