Reading: Difference Between Machine Learning and Artificial Intelligence?
Inst Tools > Blog > Common > Difference Between Machine Learning and Artificial Intelligence?
Learn the difference between machine learning and artificial intelligence in this blog post. Learn definition, real-world applications with examples.
Last updated: October 17, 2023 11:05 am
Common
7 Min Read
You may have recently seen how the ChatGPT tool is storming the market with its automatic answers and replies. The work of people has literally been made much easier as they are saving time in getting proper answers to any type of questions or queries. This has been made possible with the help of artificial intelligence. In industrial automation too, Industry 4.0 and IIOT are the next generation of programming.
What is Artificial Intelligence?What is Machine Learning?Difference Between Machine Learning and Artificial IntelligenceMachine Learning vs. Artificial Intelligence
There are a large number of tools in Industry 4.0 that make it possible to work. Two of the most widely used ones are artificial intelligence and machine learning. People often get confused about both of them, but it is important to understand the difference between both of them. In this post, we will see the difference between machine learning and artificial intelligence.
Artificial intelligence defines itself by its name. Human intelligence involves the mind of a person. However artificial intelligence does not involve the human mind; instead, it automatically derives intelligence from various data sources and uses them to do a task. For example, suppose a cup of tea has been placed in front of you. What you will do is pick it up by your hands, due to instructions from your mind. But machines using AI will automatically see this and pick it, without human intervention.
From this, you would have found that AI mimics human actions and completes the task. You do not need to write extra coding in it. Smart algorithms are developed inside which reduces the need to write codes and these algorithms automatically drive the machines to perform tasks. AI is not a completely different system; it is employed in the system. The system can be a computer for example. This means the computer will perform AI tasks. What a human does – listens, speaks, acts, and learns; the same thing is performed by AI.
AI comprises many parts in it, which makes it possible to run it smoothly. They are robotics, machine learning, deep learning, and natural language processing. AI thus works through all these inputs. It is not possible to function without any of them. It is through the combination of all these that AI is able to perform its task.
Machine Learning
As discussed in AI, machine learning is a part of it. Machine learning is a subprocess of AI, or shortly speaking, AI comprises machine learning in it. As the name implies, machine learning allows AI to learn and experience by collecting data. The data can be structured or semi-structured, which will give accurate predictions of the results that can be derived.
Machine learning works in AI systems along with other systems like robotics, deep learning, and natural language processing. AI integrates all these services to run the intelligence automatically. Machine learning uses complex algorithms that work in a shortcut way and just collect data and learn and experience it. This data is then passed to the AI system for further processing.
  1. The first and foremost difference is that AI is the master whereas machine learning is a part of it.
  2. AI aims to mimic human actions in detail, whereas machine learning aims to collect, learn, and experience data and pass it on to the AI for processing.
  3. Due to the definitions discussed, AI has a vast variety of applications than machine learning.
  4. AI takes structured, semi-structured, or unstructured data, whereas machine learning takes only structured and semi-structured data.
  5. AI does not aim for accuracy; it aims to complete the task with the maximum possible success rate. Machine learning aims for accuracy because it has to feed correct data to the AI.
  6. AI is a full decision-maker, whereas machine learning is an experience and learning maker.
  7. The three types of AI are narrow, general, and super. Machine learning has three types – supervised, unsupervised, and reinforcement.
Below is a table that details the differences between Machine Learning (ML) and Artificial Intelligence (AI).
CriteriaMachine LearningArtificial Intelligence
DefinitionA subset of AI that focuses on algorithms enabling computers to learn from data.A broad field of computer science aimed at creating systems that can perform tasks that would normally require human intelligence.
GoalTo enable machines to learn from data so that they can give accurate predictions or decisions.To create systems capable of performing tasks that require human-like cognitive functions such as learning, problem-solving, and decision-making.
LearningLearns from data; improves automatically as it is exposed to more data.May or may not learn from data; includes rule-based AI that doesn’t learn from data.
TypesSupervised, Unsupervised, Reinforcement Learning, etc.Reactive Machines, Limited Memory, Theory of Mind, Self-Aware AI, etc.
ScopeNarrow in scope; focuses on specific tasks.Broad in scope; can be specialized (Narrow AI) or generalized (General AI).
Hardware RequirementsGenerally requires less computational power compared to complex AI systems.May require specialized hardware and complex algorithms, especially for General AI.
Implementation ComplexityGenerally easier to implement.Can be extremely complex, involving advanced algorithms and computational power.
Real-world ApplicationsData mining, recommendation systems, natural language processing (NLP) to some extent.Robotics, speech recognition, problem-solving, natural language understanding.
DependencyML algorithms generally rely on a well-defined dataset to train on.AI can be rule-based and may not require data for learning.
Human InterventionOften requires human intervention for labeling data, feature extraction, etc.Aims to minimize human intervention as much as possible.
ExampleNetflix recommendation engineAutonomous vehicles
Do You Need a VPN on Your Home Computer?
Five Types of PCB Assembly that You Should Know
Beyond FR-4: Exploring Novel Materials for PCB Fabrication
Difference between Electron and Proton
What is a Viscometer? – Types, Applications, Advantages
What is Linear Electric Motor?
Optical Torsion Meter Principle
Practical Pneumatic Instruments
Modern Engineering Solutions for Rotary Equipment
What is a Spare Part? Classification, Cost, Critical Inventory
Difference between IP Address and MAC Address
Essential Safety Tips for Glass Workers
Jet Pump
What is a Jet Pump? – Principle, Types, Comparison
How are Data Centers Cooled
How are Data Centers Cooled?
Absorber in absorption chiller
What is an Absorption Chiller? – Working Principle
Instrument Skid
What is an Instrument Skid? – Example of Metering Skid
How To Choose A Surge Protector?
Classification of HVAC chillers
Classification of HVAC Chillers
What Do You Learn in Software Engineering
What Do You Learn in Software Engineering?
9 Best E-Book Apps for Students
Instrument Zero and Span Calibration
Download Modscan software
How to Use ModScan Software for Testing Modbus Communication?
magnetic-level-gauge-principle
Magnetic Level Gauge Working Principle Animation
Causes of PLC Stop Mode
Various Causes for PLC Going in Stop Mode
Instrumentation Impulse Lines
All About Instrumentation Impulse Lines
Midline output instruction
What is Midline Instruction in Siemens PLC?
Fire Alarm System Questions
Interview Questions on Fire Alarm System
Principle of ultrasonic testing
Ultrasonic Testing (UT) : Principle, Advantages, Disadvantages
