Reading: Difference Between ETP, STP, and WTP – Treatment Plants for Water
Inst Tools > Blog > Process > Difference Between ETP, STP, and WTP – Treatment Plants for Water
Three types of treatment plants for water - effluent treatment plant (ETP), sewage treatment plant (STP), and water treatment plant (WTP).
Last updated: September 28, 2022 4:10 pm
Process
In this post, we will see the difference between WTP, ETP, and STP plants.
Treatment Plants for WaterEffluent Treatment Plant (ETP)Sewage Treatment Plant (STP)Water Treatment Plant (WTP)
Water treatment plants are used to convert bad wastewater into drinkable or usable water. The quality of the water coming out of these plants need to be maintained for proper human use.
Such plants are used in almost every industry; as quality water demand is a must for the personnel to use or machines to operate.
Physical and chemical properties of the water change when contaminants, substances are added to it and then, the water becomes harmful for use. So, it is essential to treat them before use.
Basically, there are three types of treatment plants for water – water treatment plant (WTP), effluent treatment plant (ETP), and sewage treatment plant (STP). All of them have the sole purpose of treating wastewater.
In this post, we will understand their working and learn some basic differences between them.
Effluent is wastewater coming from industrial and factory output. It contains harmful chemicals, toxic and non-toxic material in it.
Every industry must have an effluent treatment plant before disposing of the wastewater into drains. It is against pollution board norms to directly discharge water into the drain without filtering it.
These plants will not only save the industries from polluting the environment; but also allow them to use the final filtered water for their use.
These plants use operations like screening, sedimentation, clarification, centrifuging, evaporation with drying methods, etc. to treat wastewater.
Also, chemicals are added through coagulation, precipitation to break down solid and chemical waste. The final output may not be 100% usable, but it is enough to drain it in disposal waste and also, use it to some content for other processes.
Sewage is the wastewater coming from household, domestic and commercial outputs. They contain excreta of humans, animals, rainwater, debris from sewers in them.
It contains more solid waste due to the presence of such material in it and is more harmful to human use.
These plants use operations like screening, sedimentation, scrapping, aerobic biology, fixed-film or suspended growth treatment, air blowers, etc. to treat wastewater.
In simpler terms, consider a water filter in your home kitchen. The water coming inside the filter can be raw, from a bore well or normal contaminated one in small quantities.
To use it for drinking or other purposes, that filter will process and give the final pure water for use. The same mechanism is used in water treatment plants.
So, compared to ETP and STP plants, they don’t have much rough water in their input for filtration; but their task is to produce 100% usable water for drinking and other purposes.
These plants involve processes like ultra-filtration, use of various filters (softener, activated carbon, multi-graded), RO, ultraviolet lamp usage, electro deionization to treat the incoming wastewater and produce pure output for use.
The main component in all of them is RO (Reverse Osmosis). WTP plant will be ineffective without this process. It is this output that provides 95%-99% of pure water through its membranes and leaves the rest of the dissolved salt in the reject line for drainage.
In this way, we saw some basic differences between the three treatment plants.
  • Heat Exchangers
  • Filters in Compressors
  • Desuperheater Design
  • Control Loop Testing
  • Ball Float Steam Trap
What are Positive Displacement Pumps and their Types?
Backwashing
What is EDI in a Water Treatment Plant? – Electro deionization
Precoat Filters
Strainers
Concept of Desuperheater
Inhouse Moisture separator for Pneumatic Systems
Cartridge Filters
Process Control Fundamentals
Bellows Steam Trap
143 Process Control Terms and Glossary – Questions Answers
What is Pump Redundancy?
What is a Y Strainer ?
CO2 Stripper Collapsed Internals Revamp
Process Air Compressor Overhauls Eliminated
Process Air Compressor too Frequent & too Lengthy Overhauls Eliminated
Hazards of Compressed Air
Pressurizer
Pressurizer
Flame Arrester Principle
CO2 Absorber Graphics in DCS
CO2 Absorber Corroded Wall Thickness & Weld Building
Pressure Reducing and Desuperheating Station (PRDS)
Pressure Reducing and DeSuperheating Station (PRDS)
Parking Garage Indicator PLC Automation
Parking Garage Indicator: PLC Automation System
PID-Controller-Simulator-graph
PID Controller Tunning Parameters Simulator
Temperature Sensors Interview Questions
Loop Diagram
15 Loop Diagram Questions
Transistor Failure Rate Calculation
Time of Flight Mass Spectrometer
Valve Positioner Torn apart
Pipeline Shakes Torn apart Valve Positioners
Different RTD Types
Difference between PT100, PT1000, Nickel RTD and Balco RTD
