Reading: Difference Between Contactor and Relay
Inst Tools > Blog > Electrical Basics > Difference Between Contactor and Relay
In this post, we will learn the difference between relay and contactor and understand the basic electrical engineering concepts.
Last updated: September 28, 2022 3:44 pm
Electrical Basics
6 Min Read
In this post, we will learn the difference between relay and contactor.
What is a Relay?What is a Contactor?Difference between Contactor and Relay
Well, most of us are familiar with relays and contactors. They both are devices used to switch on or off the power supply from its input to the output. This helps in controlling the electrical connections of a circuit.
Both work in a similar fashion, but there are differences too between them. In this post, we will see the difference between a contactor and a relay.
What is a Relay?
One of the most important components used in an electrical panel is a relay. A relay is a device that turns opens or closes its contacts based on the input voltage applied to it.
So, basically, it is a type of switch which is used in controlling electrical circuits. There is no need to manually turn on or off the contacts; the work is done by a relay automatically.
Relay Parts
As shown in the above figure, Relay has 5 contacts – positive and negative potential for power supply, Common, NO (Normally Open), and NC (Normally Closed).
When the input potential is not applied, then the voltage applied at common terminal contact will pass through NC terminal contact; because it is normally closed and it opens when the relay is energized. At that time, NO terminal contact will open.
When the input potential is applied, then the voltage applied at common terminal contact will pass through NO terminal contact; because it is normally open and it closes when the relay is energized. At that time, the NC terminal contact will open.
Relay Internal Parts
A contactor is a device that is used to control the supply of a three-phase power supply in an electrical circuit. Its role is to switch on or off the power supply supplied at its output.
As seen in the image below, the contactor generally has three connections – a three-phase power supply, a contact for energizing it, and a contact for giving feedback to the PLC or any other electrical interlock.
The image shown describes the generally used setup for connecting a contactor.
Let us understand the working of a contactor. When the contactor is energized (by supplying power to A1 and A2), it switches on the three-phase supply connected at its input terminals (L1, L2, L3) to its output terminal (T1, T2, T3).
The contactor then passes its running feedback back to the PLC through an auxiliary contact connected to it (NO and COM here).
Contactor
Here, A1 and A2 are its energizing contacts. There are DC and AC options available in it. NO/NC and COM are the auxiliary contacts that get energized depending on the switching of the contactor.
The L1, L2, and L3 are the input three-phase terminals. T1, T2, and T3 are the output three-phase terminals. L1 is switched to T1, L2 is switched to T2, and L3 is switched to T3 when the contactor is turned on.
The following are the main differences between electrical contactors and relays.
  • The very first difference is the load capacity. Contactors are designed to carry a higher current capacity than a relay. This is because contactors need to handle three phase supply as compared to a relay which is not designed for a three-phase supply.
  • Relays by default have two contacts – NO and NC. There is no option in disabling any of them; then it is no use of calling it a relay. But, contactors as discussed earlier have auxiliary contacts; which gives the option to either use NO or NC contacts, or not. It depends on the application you are using the contactor for.
  • Contactors are larger in size than relays.
  • Relays are usually rated for 250V AC, but contactors can be rated up to 1000V AC supply.
  • Relays do not have an arc suppression system built in, as compared to contactors which have an arc suppression system built-in for handling large current loads.
In this way, we understand the difference between relay and contactor.
  • Circuit Breaker Testing
  • Types of Electrical Loads
  • Dahlander Motors Principle
  • Servo Motor Control Drives
  • Industrial Storage Batteries
What is insulation? How to Choose the Insulation Material?
Why Three-phase Voltage is 440 Volts?
4-20mA Linear Conversion Calculation for VFD Drive (Formula)
What is Power Cable? Types of Power Cables
Cells and Batteries – Types, Applications, Explanation
  • Warren Turnbull says:
    February 17, 2023 at 10:04 am
    I have 70A relays and 10A contactors so the difference is not small current for relay and large current for contactors.
    The difference is the contact design, you described the relay perfectly, it pivots between N/O and N/C, and some relays only have N/C but it still pivots.
    A contactor has a contact that makes or breaks a circuit in two positions on the switch, ie a flat bar that joins two point together when closed and not touching either when open.
    Other statements that are incorrect are:
    Contactors have arc suppression, no they do not they can break inductive loads better because the opening becomes twice the size for the same distance moved as they open in two parts.
    Relays are smaller, many relays are much bigger than contactors
    Not all relays have a N/C contact, most automotive are 4 terminal, two for coil and two for N/O contact.
    Warren
Proper Sizing of Conductors
What is an Inductor? – Types of Inductors
Difference between Single-phase and Three-phase Power
Things to Know When Measuring Voltage
What is an Oil Separator in HVAC?
How to Read and Understand an Electrical Single Line Diagram?
Difference Between Flame Resistant and Flame Retardant Cables
Electrical Motor Jogging Operation
Electrical Link Box
What is a Link Box?
Induction Motor Operation
Induction Motor Over and Under Voltage Problems
Lithium-ion Battery Charging System
Lithium-ion Battery Charging Systems
Purpose of an Electrical Substation
What is a Substation? Purpose of an Electrical Substation
Why is Motor Control Required in Control Systems
Why is Motor Control Required in Control Systems?
What is a Bus Coupler in Electrical Panel
What is a Bus Coupler in Electrical Panel?
Common Materials used in Instrumentation Cables
Time Response Analysis
Design Considerations for Higher Order Systems
Compare DCS, PLC, RTU
Difference between DCS, PLC, and RTU ?
Split range control scheme
Overview of Split Range Control
Specific-Conductance-Calibration-Procedure
Types of AC Motors and DC Motors
Choke Valve Hydro Test Setup
Choke Valve Hydro Testing Procedure
SCADA backup too has been configured
FactoryTalk Studio and SQL Server for Data Logging
Instrumentation Functional Diagrams Principle
Instrumentation Functional diagrams
