Reading: Difference Between Common Cathode and Common Anode 7 Segment LED Display?
Inst Tools > Blog > Electronic Basics > Difference Between Common Cathode and Common Anode 7 Segment LED Display?
In this post, we will learn the difference between the common cathode and common anode 7 segment LED displays.
Last updated: October 17, 2023 1:56 pm
Electronic Basics
In this post, we will learn the difference between the common cathode and common anode 7-segment LED displays.
7 Segment LED DisplayTypes of 7 Segment LED DisplaysCommon Anode 7 Segment LED DisplayCommon Cathode 7 Segment LED DisplayDifference between them
7 segment LED displays are one of the most widely used displays in various sectors. Be it a timetable on the railway platform, digital watch, displays in automobiles, washing machine displays, etc. Many of the products use these types of numeric displays.
Seven Segment LED Display
A 7 segment display consists of 7 light-emitting diodes or LED’s. When these diodes are forward biased by an external voltage, the emission of photons occurs from them.
This produces light from them. The color of the light depends on the type of semiconductor material used to produce the diodes.
The 7 diodes are energized through programming written inside the chip. Due to its design, all the numbers from 0 to 9 can be shown on that.
To show a particular number, the corresponding LEDs arranged in the matrix are energized to brighten that part and show the number.
Below is the figure describing it. As you can see, there are 7 lines (means 7 diodes) arranged in such a way that when lit up, the corresponding number will be shown.
7 Segment LED
Now, refer to the below image. As discussed earlier regarding powering the diodes, this type of display can be categorized into two types –
  1. common cathode and
  2. common anode.
In common anode type, the common voltage of +5V is applied to all the diodes.
Depending upon the logic, the corresponding 0V is given which power-ups the diode and light is emitted from it.
It is important to use a resistor in series with supply voltage; otherwise, the circuit can be damaged due to over-current.
In the common cathode type, the common voltage of 0V is applied to all the diodes.
Depending upon the logic, the corresponding +5V is given which power-ups the diode, and light is emitted from it. It is important to use a resistor in series with supply voltage; otherwise, the circuit can be damaged due to over-current.
So, in the CA display, LED glows when we apply a negative potential to the selected diode; and in the CC display, LED glows when we apply a positive potential to the selected diode. So, if you want to display 2, simply energize the LED’s – a, b, g, d, e.
Out of both, the common anode is the mostly used ones as logic circuits can sink more current than they source.
The amount of light emitted depends on the forward current applied. Higher the current, the more the light. But, a resistor needs to be used for protecting against higher current out of range. These 7 segment displays are driven by specialized chips like CMOS 4511, TTL 7447, etc.
  • Seven Segment Display Working Principle
  • How a Transistor Switch Works
  • Foundation Fieldbus Segment Design
  • How to Connect Proximity Switch?
  • How does a Multi-Color LED Works?
Factors Affecting Inductance
What is a Non-Linear Device? Example – Advantages
Testing a Transistor with a Digital Multimeter
How to Test a Diode using Multimeter
How are Silicon Chips Disposed?
How to Test Diodes Using Multimeter
  • daniel rossouw says:
    July 4, 2023 at 5:47 pm
    thank you for the short summery i will go and study your notes and see if it will help me in the future for i am only starting to learn this field of work
What is a Fuse ?
How to Measure Duty Cycle using Multimeter
NO vs NC Contact
How to do Continuity Testing using Multimeter
How to Measure AC Voltage using Multimeter
What is a Clamp Meter?
What is Contactor ?
Basics of Voltage Regulator
Open Diode in a Full-Wave Rectifier
Power Supply Circuit Fault Analysis
Types of Potentiometers
Types of Potentiometers – What is a Potentiometer? – Applications
Clamp Meter
Things to Know When Measuring Current
Difference Between Electrical and Electronic Devices
Transistor as Switch Working Animation
resistor-color-coding-example
IEC labelling for Resistors Color Code
Measure Capacitance using Multimeter
How to Measure capacitance using Multimeter
Top 100 555 Timer Projects for Engineering Students
What is a Spool valve
What is a Spool Valve? – Types, Configurations, Applications
ungrounded-or-isolated-neutral-system-disadvantages
Ungrounded or Isolated Neutral System Disadvantages
Solve Pressure Control System Problems
Fire and Gas system Audible and Visual Alarms
Differential Pressure Transmitter Wet Leg Compensation
Differential Pressure Transmitters Compensated Leg Systems
PLC Hoist Crane Programming
Solenoid Valve Functional Testing
WirelessHART Device Terminals
WirelessHART Network Gateway Device
