Reading: Difference between AC and DC Solenoid Valves
Inst Tools > Blog > Solenoid Valve > Difference between AC and DC Solenoid Valves
Let's learn the difference between the AC and DC powered solenoid valves used in industrial applications.
Last updated: September 28, 2022 2:38 pm
R Jagan Mohan Rao
Solenoid Valve
3 Comments
The purpose of the solenoid coil is to convert electrical energy into a linear motion.
PrincipleTypes of SolenoidAC Solenoid versus DC SolenoidOperational NoisePower RequirementsBuzzing NoiseThe Exciting CurrentOperating TimeService LifetimeDesired Attraction Force
Principle
A solenoid valve is an electrically controlled device. The valve consists of a copper wire wound around a hollow form, which is an electric coil with a movable ferromagnetic core also called a plunger located in its center.
In the rest position, the plunger closed off a small orifice. Upon passing a current through the coil, the lines of magnetic flux turn the plunger into an electromagnet.
The generated magnetic field exerts an upwards force on the plunger opening the orifice.
The following image describes the various parts of the solenoid valve.
Solenoid
Image Courtesy: Engineertech.org
Types of Solenoid
Solenoids valves are available with two types of power.
  • AC powered Solenoid
  • DC powered Solenoid
Operational Noise
  • If there is a clearance between the movable and stationary iron cores of an AC solenoid, the solenoid coil gets heated up and chances of even coil burn out.
  • In the case of DC solenoid, its exciting current remains constant regardless of the clearance of the movable and stationary iron cores. Therefore, a shock-absorbing material can be provided between the movable and stationary iron cores to minimize operation noises.
Power Requirements
  • AC driven solenoid valves are comparatively larger in size. Consume higher levels of power to produce a relatively slow action.
  • While DC operated solenoid valves use small, solid-state components to produce fast actions from compact devices.
  • AC solenoid valves require a strong peak current to open the valve. Once the valve is open, the current drops to the level which is just sufficient to hold the plunger in place to keep the valve open and running. This helps in reducing the overall power consumption.
  • DC solenoid valves require a constant stable flow of current for their operation resulting in high consumption of electricity as compared to the AC solenoid valves.
Buzzing Noise
  • DC solenoids do not generate the buzzing noise.
  • AC solenoids generate buzzing noise due to the pulsating attraction force. A buzzing noise indicates the plunger is not fully seated. If buzzing is allowed, it will result in overheating of the coil and eventually burn out.
  • The exciting current of an AC solenoid is varies depending on the stroke.
  • In the case of DC solenoid, the excitation current is decided by the coil DC resistance only and is constant regardless of the stroke. The heat generated by the resistance to the current flow of the coil winding is constant and weaker regardless of the plunger position.
Operating Time
  • The operating time of the DC solenoid is constant regardless of the frequency. This is because it is driven by DC.
  • The operating time of the AC solenoid not constant and varies with the frequency of operation, which will also affect the heat buildup in the coil.
Service Lifetime
The service life of the DC solenoid depends greatly on the amount of mechanical wear and tear between the movable iron core and the guide (pipe).
The sliding part or section of the guide is specially treated to extend its service life.
With DC solenoid, the attraction force identical to the actual load can be provided by changing the shapes of the mating section of the movable and stationary iron cores.
  • Solenoid Wiring to PLC
  • Solenoid Valve Manual Reset
  • Do’s and Don’ts in PLC
  • Control Valve Noise Test
  • Solenoid Valve Animation
Plant Shutdown Analysis: Valve Closed and SOV Coil Failure
How Pilot operated Solenoid Valve Works ?
SIS Solenoid Valves – Safety PLC
How to Find the Correct Solenoid Valve Size?
Solenoid Valve Problems and Solutions
What is a 3-way Solenoid Valve ?
3 Comments
  • Ajay Dumbere says:
    January 3, 2021 at 2:59 pm
    Dear Sir.
    Request to send details of solenoid valve,
    Thank you
    Regards
    Ajay Dumbere
  • 13-2-106 , flat no 203 Sai Nagar says:
    May 24, 2021 at 8:57 am
    Sir thanks very much we are get very valuable knowledge
    Thanks
  • Trường Giang says:
    September 20, 2021 at 6:52 pm
    thank you very much. i think i get some information that i can use when im working
DIN Valve Connectors – Definition, Types
Solenoid Valves Types, Principle & Animation
Difference Between Solenoid Valve and Motorized Valve
5 Port 2 Position Valve Working Principle
Direct Lift Diaphragm Solenoid Valve Principle
Solenoid Valves Terminology
Solenoid Valve Troubleshooting Tips
Solenoid Valves Selection Guidelines
3-way directional control valves
Directional Control Valves Working Principle
Online Testing of Solenoid Valve
Design and Accessories Required for Online Testing of Solenoid Valve
Solenoid-Valve-Manual-Reset-function
Solenoid Valve with Manual Reset Working Principle
3-way solenoid valves control instrument air pressure
Solenoid Valve’s Energized or De-energized State ?
2-way solenoid valve Normally Closed
What is a 2-way Solenoid Valve ?
Solenoid Valve Design
Electric Solenoid Actuators Principle
What is a Electric Solenoid Actuator ?
Two SOV Connections
Two Solenoid Valves Working Principle
Demultiplexers Objective Questions
pH Meters Questions & Answers
PTC NTC Thermistors Comparation
Thermistor Working Principle
Diaphragm Pump
What is a Diaphragm Pump?
AC Generator Operation
Types of AC Generators
5-valve manifold
Rotary Encoder
Rotary Encoder Interview Questions and Answers
DCS Alarm Summary Dashboard using Microsoft Power BI
