Reading: Difference Between AA and AAA Batteries
Inst Tools > Blog > Electrical Basics > Difference Between AA and AAA Batteries
In this post, we will learn the difference between AA and AAA batteries. AA battery is larger in size as compared to AAA battery.
Last updated: November 13, 2022 7:17 pm
Electrical Basics
3 Min Read
BatteryWhat is an AA Battery?What is an AAA Battery?Difference between AA and AAA Batteries
Batteries are a very important part of our life. Almost every electronic device nowadays has a battery installed to run it. When you work with batteries, there are two common names that come – AA and AAA. It does not mean anything, but it’s just a symbol for size and features.
Battery
In this post, we will see the difference between two of the most commonly used types of batteries.
AA battery is the one with medium or large size. Its name is mentioned in the battery when you purchase; so there is no need to get confused. It is also used in combination with other AA batteries to power a relatively larger voltage-rating device.
AA battery is made of alkaline, lithium, or Ni-MH. AA battery has a typical dimension of 14.5 * 50.5 mm. AA battery typically provides a voltage of 1.5 V – 3.7 V.
AA battery maximum capacity is up to 3500 mAh. Some of them are rechargeable and some are not. They are also known as dry cells because they have a balanced amount of moisture to allow current to pass through.
AAA battery is the one with small size. Its name is mentioned in the battery when you purchase; so there is no need to get confused.
AAA battery is also used in combination with other AAA batteries to power a relatively larger voltage-rating device. It is made of alkaline, lithium, or carbon zinc.
AAA battery has a typical dimension of 10.5 * 44.5 mm. AAA battery typically provides a voltage of 1.5 V – 3.7 V. AAA battery maximum capacity is up to 1200 mAh.
The following are the main points that explain the comparison between AA and AAA batteries.
  1. AA battery is larger in size as compared to AAA battery.
  2. The storage capacity of AA batteries (up to 3500 mAh) is larger than AAA batteries (up to 1200 mAh).
  3. Due to the size, AA batteries are used in larger devices like toys, radios, calculators, thermometers, flashlights, and other big devices; whereas AAA batteries are mostly used in clocks, remote controls of AC, TV, and other smaller devices.
  4. Triple-A batteries, however, tend to lose some of their voltage capacity after a while. A double-A battery, on the other hand, will take much longer to lose its voltage capacity making it more long-lasting.
  5. AAA battery is cheaper than an AA battery, due to its smaller size and capacity.
In this way, we understood the difference between AA and AAA batteries.
What Happens When a Pump Runs Dry? How to Avoid it?
Electrical Power Grid Automation
What is Electrical Busbar? Types, Advantages, Disadvantages
Cathodic Protection – Sacrificial Anodic and Impressed Current
Difference between KW and KVA
Partial Discharge in Power Lines and its Detection through Sensors
What is a Megger? Principle, Advantages, Disadvantages, Applications
Distributed Temperature Sensors (DTS) in Power Lines
Formula of AMP, KW, KVA, HP for AC and DC Voltages
Types of Stepper Motors
Automatic Transfer Switch – Electrical Circuit, Operation, Video
What is a Protective Relay? Principle, Advantages, Applications
Ground Rod
What is a Ground Rod?
Why CT Secondary Should Never Be Kept Open?
Semiconductor Fuse
What is a Semiconductor Fuse?
Electric Motor Winding Temperature Sensors
What is an HRC Fuse
What is an HRC Fuse? – Material, Types, Advantages
Advantages of Star and Delta Systems
What is Switchgear and Electrical Substation?
Difference Between MPCB and MCCB
Classification of Solenoid Valves
Water Fountain Control Logic
Water Fountain Control Logic – PLC Exercises and Solutions
RTD Construction
Introduction to RTDs
Final Year Engineering Projects
Final Year Engineering Projects for ECE, EEE and EIE Students
Fire and Gas System
Types of Fire and Gas Detectors
Draw the Symbols for Liquid Level Measuring Instruments
Permanent magnet moving coil instruments (PMMC)
Permanent Magnet Moving Coil Instruments (PMMC)
Auto Transformer Schematic
Classification of Transformers
