Reading: Chromatograph Sample Valves
Inst Tools > Blog > Analyzers > Chromatograph Sample Valves
Last updated: October 17, 2023 2:35 pm
Analyzers
Arguably, the component most critical to measurement accuracy in a gas chromatograph is the sample valve. Its purpose is to inject the exact same sample quantity into the column at the beginning of each cycle. If the sample quantity is not repeatable, the measured quantities exiting the column will change from cycle to cycle even if the sample composition does not change. I
f the valve’s cycle time is not repeatable, species separation efficiency will vary from cycle to cycle. If the sample valve leaks such that a small flow rate of sample continuously enters the column, the result will be an altered “baseline” signal at the detector (at best) and total corruption of the analysis (at worst). Many process chromatograph problems are caused by irregularities in the sample valve(s).
A photograph of the column (the coil of fine tubing about 6 inches in diameter, on the left) and sample valve (stainless-steel cylinder with several tubes entering and exiting, on the right) for a gas chromatograph appears here:
A common form of sample valve uses a rotating element to switch port connections between the sample gas stream, carrier gas stream, and column:
GC sample valves
Three slots connect three pairs of ports together. When the rotary valve actuates, the port connections switch, redirecting gas flows.
Connected to a sample stream, carrier stream, and column, the rotary sample valve operates in two different modes.
The first mode is a “loading” position where the sample stream flows through a short length of tubing (called a sample loop) and exits to a waste discharge port, while the carrier gas flows through the column to wash the last sample through.
The second mode is a “sampling” position where the volume of sample gas held in the sample loop tubing gets injected into the column by a flow of carrier gas behind it:
GC sample loop
The purpose of the sample loop tube is to act as a holding reservoir for a fixed volume of sample gas. When the sample valve switches to the sample position, the carrier gas will flush the contents of the sample loop toward the column. This valve configuration guarantees that the injected sample volume cannot vary even if the sample valve’s actuation is not precise.
The sample valve need only remain in the “sampling” position long enough to completely flush the sample loop tube, and the proper volume of injected sample gas is guaranteed. An analogy for the sample loop is that of a measuring cup held underneath a continuously-spilling stream of water: so long as the cup is held beneath the stream long enough to completely fill, it is guaranteed to deliver a fixed volume of water when removed from the stream and emptied.
Like a measuring cup, the sample loop need only be filled completely with sample gas to deliver a fixed and unerring volume of gas to the chromatograph column when switched from the ”loading” position to the “sampling” position.
While in the loading position, the stream of gas sampled from the process continuously fills the sample loop and then exits to a waste port. This may seem wasteful but in fact is quite essential for practical sampling operation. The volume of process gas injected into the chromatograph column during each cycle is so small (typically measured in units of microliters!) that a continuous flow of sample gas to waste is necessary to purge the impulse line connecting the analyzer to the process and thereby ensure a fresh sample, which in turn is necessary for the analyzer to obtain analyses of current conditions.
If it were not for the continuous flow of sample to waste, it would take a very long time for a sample of process gas to make its way through the long impulse tube to the analyzer to be sampled, resulting in grossly delayed measurements of process conditions!
Analyzer Sampling System
Also Read : GC Column Questions & Answers
Moisture and Dew Point Analyzer Problems and Troubleshooting Tips
Measurement of Carbon Dioxide in Flue Gas
Gas Analyzer Sampling System
How to Calibrate the Eddy Current Conductivity Meter?
Oxidation-Reduction Potential (ORP) Sensor Calibration Procedure
Basics of Total Organic Carbon (TOC) Analyzers
  • nisha says:
    November 12, 2024 at 4:33 pm
    Thank you for your Valuable Information of
    Sampling Valve
Difference Between Absolute and Relative Humidity
Mass Spectrometer Working Principle
How to Calibrate Oxygen Analyzer? – O2 Sensor Testing Procedure
Ionization chamber Principle
Sling Psychrometer Principle
Technologies for Oxygen Gas Measurement
Turbidity Analyzer Working Principle
Humidity Calculator
Humidity calculator
4-wire pH Transmitter Problem
gas chromatograph principle
Online Gas Chromatograph Principle
NDIR GAS ANALYSER WORKING PRINCIPLE ANIMATION
NDIR Gas Analyser Working Principle
Single-beam non-dispersive analyzer
Single-beam Non-dispersive Analyzer
sulfur dioxide analyzer
Fluorescence
Scintillation Counter Theory
Scintillation Counter Principle
span gas cylinders
Analyzer Sample Systems
RTD Standards list
RTD Standards
DPDT switch
Switch Types and Common Terminology
Control System
The need for automatic controls
IPSec
What is IPSec? – Internet Protocol Security
Pre-Startup Safety Review (PSSR)
reactor vessel
What Do You Learn in Software Engineering
What Do You Learn in Software Engineering?
Solve Pressure Control System Problems
