Reading: Characteristics of Photo diode
Inst Tools > Blog > Electronic Devices & Circuits > Characteristics of Photo diode
Last updated: September 27, 2016 3:13 pm
1 Min Read
There  are  two  important  characteristics  of  photo- diode.
(i)   Reverse current-Illumination curve.
The below Fig shows the graph between reverse current (IR) and illumination (E) of a photo-diode.  The reverse current is shown on the vertical axis and is measured in μA. The illumination is indicated on the horizontal axis and is measured in mW/cm2. Note that graph is a straight line passing through the origin.
∴   IR    =  mE
where   m  =  slope of the straight line
The quantity m is called the sensitivity of the photo-diode.
Reverse Current Characteristics of Photo diode
(ii)  Reverse voltage-Reverse current curve.
The below Fig. shows the graph between reverse cur- rent (IR) and reverse voltage (VR) for various illumination levels.   It is clear that for a given reverse-biased voltage VR, the reverse current IR increases as the illumination (E) on the pn junction of photo-diode is increased.
Reverse Voltage Characteristics of Photo diode
Zener Diode Breakdown Characteristics
Cathode Ray Tube Deflection System
Basic DC Power Supply Circuit
PMMC Temperature Compensation
Troubleshooting a Biased Transistor
Peak Inverse Voltage of Center Tap Rectifier
Current Divider Rule
Circuit Elements and Types of Circuits
Transistor Cut off, Saturation & Active Regions
Voltage Divider Rule
Testing a Transistor with a Digital Multimeter
Power MOSFET Safe Operating Area
Diode Limiters/Clippers Operation
Comparison of MOSFET and BJT
Dependent Current Source
Electron Gun of CRT
Electron Gun of Cathode Ray Tube
Transistor Amplifier Working Principle
What is a Memristor
What is a Memristor? Principle, Advantages, Applications
Schottky Diode Vs PN junction Diode
Difference between Schottky Diode and PN junction Diode
Methods of Transistor Biasing
Zener Diode Limiter Working
Zener Diode Limiter
diode-clamper-circuit
Full Wave Voltage Doubler using Diodes
Thermocouples
Thermocouples
Level Sensors MCQ
Level Sensors MCQ – Industrial Instrumentation
Select Right Type of Controller
How to Select the Right Type of Controller
How Does a Touch Sensor Work
How Does a Touch Sensor Work?
Feedback Accelerometer System Objective Questions
safety gas analyzer
Safety Gas Analyzers
Vacuum Tubes Multiple Choice Questions and Answers
Control Systems Stability and Algebraic Criteria
Routh-Hurwitz Stability Criterion
