Reading: How Capacitive Pressure Sensor Works ?
Inst Tools > Blog > Pressure Measurement > How Capacitive Pressure Sensor Works ?
Last updated: June 1, 2019 11:25 am
2 Min Read
The Capacitive pressure sensor operates on the principle that, if the sensing diaphragm between two capacitor plates is deformed by a differential pressure, an imbalance of capacitance will occur between itself and the two plates.
This imbalance is detected in a capacitance bridge circuit and converted to a D.C. output current of 4 to 20 mA.
This is shown in Figure, where the movement of a flexible diaphragm relative to a fixed plate is sensed by the capacitance change. A secondary isolating diaphragm is used to protect the sensing diaphragm.
Capacitance Pressure Sensor Works
Another type of capacitor uses concentric hollow metal cylinders. The capacitance of this type just like the flat-plate type is proportional to the area.
This principle can be applied to differential pressure measurement, as shown in Figure. The pressure acting on the isolating diaphragms set up similar pressures in the silicone oil filling the space between them.
A net force proportional to the difference between the two pressures acts upon the metal sensing diaphragm and deflects it to one side or the other, depending on which input pressure is the greater.
Each plate forms a capacitor with the sensing diaphragm, which is connected electrically to the metallic body transducer.
Pressure Sensor Capacitance Type
The sensing diaphragm and capacitor thus form a differential variable separation capacitor. When the two input pressure are equal, the diaphragm is positioned centrally and the capacitances are equal.
A difference in the two input pressures causes displacement of the sensing diaphragm and is sensed as a difference between the two capacitances.
This change in capacitance is measured using a bridge circuit to measure the equivalent pressure signal.
Articles You May Like :
Pressure Gauge Water Traps
Tank Gauging Technologies
Capacitive Level Measurement
Fieldbus Transmitter Calibration
Vortex Flow Meter Principle
Differential Pressure Sensor for Filtration Monitoring
Basics of Pressure Measurement
Gage and Absolute Pressure Transmitters Principle
Advantages of Pneumatic Systems in the Automotive Industry
What is a Submersible Pressure Transmitter? Principle, Advantages
Pressure Transmitter Calibration Procedure
Pressure Transmitter Applications
Types of Manometers
Impulse Line – Purpose & Tapping Point Location
Electronic Pressure Sensors Principle
Information on the Pressure Gauge Dial
Pressure Gauge Pulsation Damping
What is Sensor Trim and Output Trim in Smart Transmitter?
Commissioning Differential Pressure Transmitter in Boiler Steam Drum
Pressure Sensor Specifications
pressure-gauge-animation
Bourdon Tube Pressure Gauge Working Principle Animation
DeadWeight Tester
DeadWeight Tester Questions
How to Measure Pressure in Inches of Water Column
Pressure Transmitter Troubleshooting Tips
piping for a Different pressure flow transmitter
Impulse Piping standards for Field instruments
bourdon-tube-pressure-gauge-working-animation
Working Principle of Pressure Gauge
Types of Control Valves Noise
PID Setup
PID in Studio 5000
Electrician Tools
Electrician Tools MCQ Questions
Switch or Transmitter
Analyzer chopper wheel
NDIR Analyzer Filter Cells
Smart Transmitter Calibration Tutorial
Smart Transmitter Calibration Tutorial Part 1
Automation in laboratory
Automating Lab Data Reconciliation: Key Steps to Success
Questions on Pneumatic Control Loop
