Reading: Bode Plots MCQ
Inst Tools > Blog > Multiple Choice Questions > Bode Plots MCQ
Bode Plots MCQ
7 Min Read
Bode Plots MCQ
1. Assertion (A): Relative stability of the system reduces due to the presence of transportation lag.
Reason (R): Transportation lag can be conveniently handled by Bode plot.
a) Both A and R are true but R is correct explanation of A
b) Both A and R are true but R is correct explanation of A
c) A is true but R is false
d) A is false but R is true
Answer: b
Explanation: Transportation lag can be conveniently handled on Bode plot as well without the need to make any approximation.
2. Assertion (A): The phase angle plot in Bode diagram is not affected by the variation in the gain of the system.
Reason(R): The variation in the gain of the system has no effect on the phase margin of the system.
Answer: c
Explanation: The variation in the gain of the system has effect on the phase margin but phase plot is not affected.
3. A system has poles at 0.01 Hz, 1 Hz and 80Hz, zeroes at 5Hz, 100Hz and 200Hz. The approximate phase of the system response at 20 Hz is :
a) -90°
b) 0°
c) 90°
d) -180°
Answer: a
Explanation: Pole at 0.01 Hz gives -180° phase. Zero at 5Hz gives 90° phase therefore at 20Hz -90° phase shift is provided.
4. The constant M-circle represented by the equation x^2+2.25x+y^2=-1.25 has the value of M equal to:
a) 1
b) 2
c) 3
d) 4
Answer: c
Explanation: Comparing with the M circle equation we have the value of M =3.
5. What is the value of M for the constant M circle represented by the equation 8x2+18x+8y2+9=0?
a) 0.5
b) 2
c) 3
d) 8
Answer: c
6. The constant N loci represented by the equation x^2+x+y^2=0 is for the value of phase angle equal to:
a) -45°
b) 0°
c) 45°
d) 90°
Answer: d
Explanation: Centre = (-0.5, 0)
Centre of N circle is (-1/2, 1/2N)
N =tanα
α =90°.
7. All the constant N-circles in G planes cross the real axis at the fixed points. Which are these points?
a) -1 and origin
b) Origin and +1
c) -0.5 and 0.5
d) -1 and +1
Answer: a
Explanation: Centre of N circle is (-1/2, 1/2N)
N =tanα
Constant –N circles always pass through (-1, 0) and (0, 0).
8. Consider the following statements:
Nichol’s chart gives information about.
i. Closed loop frequency response.
ii. The value of the peak magnitude of the closed loop frequency response Mp.
iii. The frequency at which Mp occurs.
Which of the above statements are correct?
a) 2 and 3
b) 1 and 2
c) 1 and 3
d) 1,2 and 3
Answer: d
Explanation: Nichol’s chart gives information about closed loop frequency response, value of the peak magnitude of the closed loop frequency response Mp and the frequency at which Mp occurs.
9. Which one of the following statements is correct? Nichol’s chart is useful for the detailed study analysis of:
a) Closed loop frequency response
b) Open loop frequency response
c) Close loop and open loop frequency responses
d) None of the above
Answer: a
Explanation: Nichol’s chart is useful for the detailed study analysis of closed loop frequency response.
10. In a bode magnitude plot, which one of the following slopes would be exhibited at high frequencies by a 4th order all-pole system?
a) -80dB/decade
b) -40 dB/decade
c) 40 dB/decade
d) 80 dB/decade
Answer: a
Explanation: A 4th order all pole system means that the system must be having no zero or s-term in numerator and s4 terms in denominator. One pole exhibits -20dB/decade slope, so 4 pole exhibits a slope of -80 dB /decade.
11. Frequency range of bode magnitude and phases are decided by :
a) The lowest and higher important frequencies of dominant factors of the OLTF
b) The lowest and highest important frequencies of all the factors of the open loop transfer function
c) Resonant frequencies of the second factors
Answer: d
Explanation: T. F. = Kp (1+Tds)
There is only one zero which will give slope of +20dB/decade.
12. OLTF contains one zero in right half of s-plane then
a) Open loop system is unstable
b) Close loop system is unstable
c) Close loop system is unstable for higher gain
d) Close loop system is stable
Answer: c
Explanation: OLTF contains one zero in right half of s-plane then Close loop system is unstable for higher gain.
13. The critical value of gain for a system is 40 and gain margin is 6dB. The system is operating at a gain of:
a) 20
b) 40
c) 80
d) 120
Answer: a
Explanation: Gm (dB) = 20log⁡GM
GM =2
As we know, GM =K (marginal)/K (desired)
K desired =40/2 =20.
14. Nichol’s chart is useful for the detailed study and analysis of:
d) open loop and Close loop frequency responses
Answer: a
Explanation: Nichol’s chart is useful for the detailed study and analysis of closed loop frequency response.
15. The roots of the characteristic equation of the second order system in which real and imaginary part represents the :
a) Damped frequency and damping
b) Damping and damped frequency
c) Natural frequency and damping ratio
d) Damping ratio and natural frequency
Answer: b
Explanation: Real part represents the damping and imaginary part damped frequency
Time Response of Second Order Systems – I
Difference Equations
Top 100 Power Plant Engineering Objective Questions & Answers
The Z-Transfer Function
Silica Analyzer Questions & Answers
Instrumentation Diagrams Multiple Choice Questions
Combination Electrode Questions & Answers
Effect of Adding a Zero to a System
Continuous Wave NMR Spectroscopy Questions & Answers
Root Locus in Control Systems
Ion Analyzer Questions & Answers
Spectral Method of Analysis Questions & Answers
Design Considerations for Higher Order Systems
NO2 Analyzer Questions & Answers
Linearizing Effect & Regenerative Feedback MCQ
Control Systems Stability and Algebraic Criteria
Routh-Hurwitz Stability Criterion
Stability in Frequency Domain
The Design Problem
Optimal Control Systems
The State Regulator Problem
Quadrupole Mass Spectrometer
Magnetic Wind Instruments Questions & Answers
Advances in Control System
Neural Networks
Necessary Conditions for Stability & Non-Linear Systems
V1000 Family Programming Simulator Tool
Simple Pressure Repeater
Ball Float Steam Trap
Calculate-current-4-20ma-from-process-varibale-pv
Calculate Current (4-20ma) from Process variable PV
Insulation of Thermowell
Facts on Thermowell Insulation Thickness
Jackshaft Belt Drive
Poorly Engineered, built & often Failing Plant Air Compressor Drives
Radiation based Level Sensor Principle
Replace Failed Motors Quickly and Easily
