Reading: Band Gap for Semiconductor Materials
Inst Tools > Blog > Electronic Devices & Circuits > Band Gap for Semiconductor Materials
Last updated: October 5, 2016 1:28 pm
2 Min Read
The valence shell of an atom represents a band of energy levels and that the valence electrons are confined to that band. When an electron acquires enough additional energy, it can leave the valence shell, become a free electron, and exist in what is known as the conduction band.
The difference in energy between the valence band and the conduction band is called an energy gap or band gap. This is the amount of energy that a valence electron must have in order to jump from the valence band to the conduction band. Once in the conduction band, the electron is free to move throughout the material and is not tied to any given atom.
The below figure shows energy diagrams for insulators, semiconductors, and conductors. The energy gap or band gap is the difference between two energy levels and is “not allowed” in quantum theory. It is a region in insulators and semiconductors where no electron states exist. Although an electron may not exist in this region, it can “jump” across it under certain conditions. For insulators, the gap can be crossed only when breakdown conditions occur—as when a very high voltage is applied across the material.
The band gap is illustrated in Figure 1–(a) for insulators. In semiconductors the band gap is smaller, allowing an electron in the valence band to jump into the conduction band if it absorbs a photon. The band gap depends on the semiconductor material. This is illustrated in Figure 1–(b). In conductors, the conduction band and valence band overlap, so there is no gap, as shown in Figure 1–(c). This means that electrons in the valence band move freely into the conduction band, so there are always electrons available as free electrons.
energy-diagrams-for-insulator-semiconductor-and-conductor
Basic Electronics Questions & Answers
Amplifiers Questions & Answers
Basics of Voltage Regulators
pi filter Operation
Transistor Emitter Bias
Half Wave Rectifier Principle
Schottky Diode Working Principle
What is a Filter Circuit ?
Freewheeling Diode Working Principle
Summary Of Transistor Bias Circuits
Capacitor Filter Working Principle
Operation of Zener Diode Voltage Regulator
Working of NPN Transistor
How a PN Junction Formed in a Diode
Transistor as Amplifier
Cathode Ray Tube Deflection System
Transistor-cut-off-saturation-active-regions
Transistor Cut off, Saturation & Active Regions
Button 3C of the Matrix Keypad is pressed
How the Matrix Keypad works with a Micro controller?
Full Wave Bridge Rectifier Operation
Classification of Bridge Circuits
Ideal Diode Characteristics
diode-basic-structure-symbol
Forward Bias & Reverse Bias of a Diode
Diaphragm Pump
What is a Diaphragm Pump?
Do’s and Don'ts in PLC
#18 PLC Best Practices – Store PLC Hard Stop Events from Faults
How transformer works?
Strain Gauge Pressure Sensor Principle
7 Investments for Single Mothers
PLC Program to Energize & De-energize the Outputs based on Events
PLC Energize or De-energize the Outputs based on Events
differential-pressure-transmitter-calibration-procedure
Differential Pressure Transmitter Calibration Procedure
