Reading: Applications of Variable Frequency Drive (VFD)
Inst Tools > Blog > Electrical Basics > Applications of Variable Frequency Drive (VFD)
In this post, we will have a look at some general industries and applications of VFD. The VFD is called a Variable Frequency Drive.
Last updated: October 25, 2022 10:29 am
Electrical Basics
In this article, we will learn the various applications of VFD (Variable Frequency Drive).
Applications of Variable Frequency DriveAutomotive IndustryFood and Beverage IndustryChemical IndustryTextile IndustryPaper IndustryWood IndustryMetallurgy Industry
The AC drive has been around only since the 1970s. The growing popularity of AC drives is due chiefly to their ability to provide adjustable speed control with standard NEMA B design squirrel cage motors.
Other names for AC drives are variable frequency drive (VFD) and variable speed drive (VSD), but we’ll just call them AC drives.
How do AC drives work
A variable frequency drive (VFD) is a type of motor controller that drives an electric motor by varying the frequency and voltage of its power supply.
The VFD also has the capacity to control the ramp-up and ramp-down of the motor during start or stop, respectively.
In this post, we will have a look at some general target industries and applications where the VFD is used.
Applications of VFD
Some of the industries are mentioned below where we use variable frequency drives.
Automotive Industry
The VFDs are used for the following machines.
  1. Conveyors
  2. Tool Changers
  3. Transfer Lines
  4. Boring / Cutting Machines
  5. Feeders
  6. Pressers
  7. Welders
  8. Shears
  9. Parts Positioning
  10. Hoists
  11. Pumps
  12. Ventilating Fans
  13. Grinders
  14. Deburring Equipment
  15. Wind Tunnels
Following is the equipment that we use VFD in the food industry.
  1. Conveyors
  2. Filling Machines
  3. Capping Machines
  4. Labeling
  5. Wrapping
  6. Pumps
  7. Cutting Process
  8. Fans
  9. Transporters for Freezing Tunnels
  10. Screw Pumps
  11. Crunchers
  12. Mixers
  13. Dough Machines
  14. Agitators
Chemical Industry
Here is the list of equipment used with AC drives in the chemical industry.
  1. Centrifugal Pumps
  2. Fans
  3. Dosing and Metering Pumps
  4. Granulators
  5. Mixers
  6. Container Handling
  7. Agitators
  8. Packaging Machines
  9. Dosing Conveyors
  10. Crunchers
Textile Industry
The following are the machines used in the textile industry with variable speed drives.
  1. Bobbin Winder
  2. Texturing Machines
  3. Gear Pumps
  4. Mixers
  5. Extruder
  6. Twister and Doubler
  7. Drawing Roller
  8. Washers
  9. Conveyors
  10. Beam Wrappers
  11. Carding Machines
  12. Presser Frames
  13. Knitters
  14. Weaver’s Loom
  15. Dryers
  16. Picking Machines
  17. Flocking Machines
  18. Printing Machines
  19. Scrappers
  20. Bag Handling Machines
  21. Screw Pumps
  22. Sewing Machines
  23. Cutting Machines
  24. Washing Machines
  25. Dry Cleaning
  26. Ironer
  27. Transporters
Paper Industry
A short list of machines used with VFDs in the paper industry.
  1. Feeders
  2. Crushers
  3. Centrifugal Pumps
  4. Dryers
  5. Winding / Unwinding Rollers
  6. Coating Machines
  7. Conveyors
  8. Cutting Machines
  9. Unwinding Machines
  10. Glue Pumps
  11. Packaging Machines
  12. Cutting Machines
  13. Ink Pumps
  14. Printing Press
  15. Assembling Machine
  16. Folders
Wood Industry
Some more list of equipment in the wood industry used with the drives.
  1. Saws
  2. Ventilating Fans
  3. Pumps
  4. Chip Conveyors
  5. Transfer Cars
  6. Grinders
  7. Saws
  8. Conveyors
  9. Washers
  10. Oven Conveyors
  11. Material Conveyors
Metallurgy Industry
The applications of VFDs in the metallurgy industry are mentioned below.
  1. Injectors
  2. Crushers
  3. Conveyors
  4. Pumps
  5. Fans
  6. Wire Drawing Machines
  7. Steel Rolling Machines
  8. Press and Cutting Machines
  9. Plastic Covering Machines
  10. Metal Finishing Treatment
  11. Stitch Seam Welding Machines
In this way, we understand some general applications of VFDs in industries.
  • Types of Motor Loads
  • AC Motor Fundamentals
  • What is a Submersible Pump?
  • What is a Lightning Arrester?
  • What is a Power Transformer?
Proper Sizing of Conductors
Top 100 Power Systems Projects – Electrical Engineering
Testing of Thermal Protection Relay for Motors
Partial Discharge in Power Lines and its Detection through Sensors
What is an Overhead Cable? Types of Overhead Conductors
Electrical Motor Terms and Concepts
What is an Armoured Cable? Classification of Cables
Types of Motor Enclosures
What is an ELV System? – Extra Low Voltage
How to Size a Cable for Industrial AC Motors?
Types of Relays used in an Air Circuit Breaker (ACB)
What is an Inductor? – Types of Inductors
Importance of Neutral Wire
Auto Changeover Switch
What is an Auto Changeover Switch?
Difference between Stepper Motor and Servo Motor
How to Test a Motor using Megger
How to Test a Motor using Megger?
What is a Power Transformer? – Components and Types
Motors Inrush Currents
Motor Inrush Current Measurements
Why is HV Testing important in Electrical Panels?
Electrical Equipment Selection in Hazardous Area
Alternator Objective Questions and Answers
125+ Alternator Objective Questions and Answers
Loop Current Step Response (LCSR) Test for RTD
Response Time Test of RTD and Thermocouple
Flip Flops Objective Questions – Part 1
PLC Programming for Automated Curtain Control
Automatic Curtain Control – PLC Programming Solution
Real-time and historical SCADA Trends
What are Trends in SCADA?
Liquid management using PLC programming
PLC Programming for Loss in Weight Liquid Systems
Single-Phase Half Wave AC-DC Converter Quiz
Top Embedded Systems Projects for Engineers and Students
200 Top Embedded Systems Projects for Engineers and Students
