Reading: Analog Measurement using Ladder Logic
Inst Tools > Blog > PLC Tutorials > Analog Measurement using Ladder Logic
Last updated: March 4, 2021 3:18 pm
3 Min Read
This article explains the analog measurement in control system using ladder logic.
Register and Memory :-PLC Ladder Programming
If measured value of revolution is 400 RPM/min, Calculate the equivalent voltage.
Calculate Speed in ladder logic
Here we need to measure both values. For physical quantity generally we use transducer. And here consider the range of transducer 0 to 10 V DC and the speed range can be calculated from 200 RPM/min to 1000 RPM/min.
So we will use standard conversion methods for it.
Here 0 V = 200 RPM/min
10 V DC = 1000 RPM/min
Then 10 V / 1000 V = 0.01 V/RPM/min
Now measured RPM is 400 RPM/min
so 400 RPM – 200 RPM x 0.01 RPM/min = 2 V.
  • Register A :- Actual voltage
  • Register B :- Max RPM
  • Register C :- Division value
  • Register D :- Measured RPM
  • Register E :- Min value of RPM
  • Register F :- Calculated measured voltage
NETWORK 1 :-
Division block Ladder Logic
Division block is used for RPM conversion. Here we have calculated the RPM per voltage.
NETWORK 2 :-
SUB and MUL in Ladder Logic
RPM scale is starting from 200 to 1000 so start range value (200) is subtracted from the actual measured value (it is 400 RPM/min). And final value will be multiplied with the division (network 1).
Note:- Above application may be different from the actual application. This example is only for explanation and educational purpose only. We can implement this logic in other PLC also. This is the simple analog measurement using ladder logic, we can use this concept in other examples also.
All parameters and graphical representations considered in this example are for explanation purposes only, parameters or representation may be different in actual applications. Also all interlocks are not considered in the application.
Author: Bhavesh
Light Control using PLC
Up Counter PLC Program
Ladder Logic for Sensor Scaling
Single Push button using Logic
OFF Delay Timer using PLC
SAVE and BR Memory Instructions in Siemens PLC Programming
PLC Ladder Logic for Tanks Filling as per Priority
How to Filter Digital and Analog Inputs in a PLC?
Motor ON OFF Logic in PLC
Conveyor Sorting Machine PLC Program with Calculation Function
  • Satish says:
    August 27, 2019 at 1:48 am
    Omron cp 1e input output electrical waring
Playground Swing Logic Exercise Program in PLC
Basic Concepts of the Safety Relay
PLC Multiple Choice Questions
Automatic Box Filling System using PLC Programming
Difference Between FC and FB in Tia Portal
What is the OPC Server?
PLC Ladder Logic Questions and Answers
Relay Wiring
SCADA in Cloud
Cloud-Based SCADA Projects – Try Free Demo Account
Control Algorithms in PLC Programming
Communication between Intouch Scada and Allen Bradley PLC
Communication between InTouch Scada and Allen Bradley PLC
Forward reverse motor control diagram with timer
Timer during Motor Direction Change PLC Program
SFC Language in PLC Programming
How to Control VFD with PLC using Ladder Logic
PLC Handbook
PLC Handbook
Inductor Principle
Inductor
Sensors and Transducers Test
Power MOSFET Symbols
Power MOSFET – Symbol, Types, Working, Characteristics, Advantages
Instrumentation Engineering Quiz
Instrumentation Engineering Quiz – Set 2
Push button Motor PLC Logic
Unmanaged Switch
Managed Switch vs Unmanaged Switch
Instrument Percent of Span Error
Types of Flow Meters MCQ - Instrumentation and Control
Types of Flow Meters MCQ – Instrumentation and Control
