Reading: Advantages of Star and Delta Systems
Inst Tools > Blog > Electrical Basics > Advantages of Star and Delta Systems
Last updated: September 19, 2016 1:41 am
Electrical Basics
2 Min Read
In a 3-phase system the alternators or generators may be star connected or delta connected. Likewise 3-phase loads may be star connected or delta connected. Some of the advantages of star and delta cconnected systems are listed below
Star Connection:
  • In a star connection, phase voltage Vph = VL/ (3)1/2. Since the induced emf in the primary winding of an alternator is directly proportional to the number of turns, a star connected alternator will require less number of turns than a delta connected alternator for the same voltage.
  • For the same line voltage, a star connected alternator requires less insulation than a delta connected alternator. Due to the above reasons three phase alternators are generally star connected.
  • In star connection, we get 3-phase and 4-wire system. This permits the use of two voltages (phase voltages as well as line voltages). Single phase loads can be connected between any one lie and neutral wire while the 3-phase loads can be put across the three lines. Such a flexibility is not available in delta connection
  • In star connection, the neutral point can be earthed. Such a measure offers many advantages. For example, in case of line to earth fault (L-G fault), the insulators have to bear 1/31/2 (57.7%) times the line voltage. Earthing of neutral also permits the use of protective devices (relays) to protect the system in the case of ground faults
Delta Connection:
  • This type of connection is most suitable for rotatory conveyers
  • Most of the three phase loads are delta connected than star connected. One reason for this, atleast for the case of unbalanced load, is the flexibility with which loads may be added or removed on a single phase. This is difficult to do with star connected 3-wire load
  • Most of the 3-phase induction motors are delta connected
Electrical Energy Management System and SCADA in Power System
Variable Frequency Drive (VFD) Working Principle
Difference Between Earth and Neutral
What is an Air Circuit Breaker? Working Principle & Applications
Difference Between Isolator and Circuit Breaker
Download Electrical Enclosure Book
Residual Current Circuit Breaker (RCCB)
What is Electrical Panel Door Earth Bonding? Explained
How to Test a Motor using Megger?
What is a Current Transformer?
How to Size a Cable for Industrial AC Motors?
Difference between AC and DC
Inverse Time Circuit Breaker
What are Inverse Time and Instantaneous Trip Circuit Breakers?
Types of Motor Enclosures
Difference between Soft Starter and VFD
Construction of Megger
What is a Megger? Principle, Advantages, Disadvantages, Applications
Wave Trap in Power Line carrier Communication
What is a Wave Trap? – Power Line Carrier Communication
Connection between PLC and Contactor
Semiconductor Fuse
What is a Semiconductor Fuse?
Electrical Feeder Automation in Smart Grid
Stability in Frequency Domain
Preliminary Considerations of Classical Design
Networking Interview Questions
Top 100 Networking Interview Questions & Answers
Sequencer Output in PLC
PLC Sequencer Instruction with Example
Sick Flow meters
Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
SCADA
Top 100+ SCADA Questions
Zener Diode Voltage Regulator Operation
Leave Operational Logic in the PLC
#3 PLC Best Practices – Leave Operational Logic in the PLC wherever feasible
Difference Between LDR and Photodiode
