Reading: What is an Overhead Cable? Types of Overhead Conductors
Inst Tools > Blog > Electrical Basics > What is an Overhead Cable? Types of Overhead Conductors
In this post, we will learn the types of conductors used in overhead cables. An electrical wire has two parts – conductor and insulator.
Last updated: February 8, 2023 11:51 am
Electrical Basics
Overhead CableTypes of Overhead ConductorsAAC (All Aluminium Conductors)AAAC (All Aluminium Alloy Conductors)ACSR (All Aluminium Conductor Steel Reinforced)ACAR (Aluminium Conductor Alloy Reinforced)How to Choose the Overhead Conductor?
An electrical wire has two parts – conductor and insulator. The conductor is the inner material which allows to pass electricity, and an insulator is a material which blocks the passage of electricity through it. Both are required to make an electrical wire.
Overhead Cable
Now, you must have seen long lengths of electrical cables running through a power distribution and transmission grid. It is visible everywhere around us. These are the cables which bring the power to our home. They are called overhead cables.
The most common types of overhead conductors are listed below.
  • AAC (All Aluminium Conductors)
  • AAAC (All Aluminium Alloy Conductors)
  • ACSR (All Aluminium Conductor Steel Reinforced)
  • ACAR (Aluminium Conductor Alloy Reinforced)
As the name implies, the electrical conductor is purely made of aluminium. It can be seen as a stranded set of conductors, stacked one above the other.
Aluminium is a very good conductor of electricity and due to such a large amount of conductor material, AAC has the best conductivity of all. Also, it is highly corrosion-resistant.
All Aluminium Conductors (AAC)
Image Courtesy: NAN Cable
But, because of such a large presence of aluminium, its weight increases as compared to its medium strength and they start to bend out.
That is why these types of conductors are used for shorter distances and where the grid towers are nearby. Because, though it will run only for a short distance, it will provide an excellent current transfer.
As compared to the earlier one (AAC), this conductor is made of aluminium and alloys. The alloy can be magnesium and silicon. Even they are a stranded set of conductors.
But, due to a mixture of alloys, its strength increases and they tend to bend lower as compared to AAC conductors.
So, they can be used for longer distances. But, it has less conductivity and is also less resistant to corrosion as compared to AAC conductors. It has high tensile strength and also has fewer electrical losses.
The ACSR (All Aluminium Conductor Steel Reinforced) is the most used conductor. ASCR comprises aluminium-stranded coils which are mounted on a central core of galvanized steel (zinc-coated or aluminium coated).
As steel is thinner than aluminium, it provides very high corrosion resistance, high mechanical strength and less bending. This happens due to a perfect weight mixture.
The steel strands are added as mechanical reinforcements. This conductor too has very good conductivity. Due to all these properties, it is highly used in transmission and distribution grids at shorter or longer distances.
The ACAR (Aluminium Conductor Alloy Reinforced) is a lower version of ASCR. They too have aluminium-stranded coils; but instead of a central steel core, it has a central alloy core (magnesium or silicon).
Image Courtesy: APAR
ACAR properties are less attractive than ASCR, due to the use of alloys. But it is used more than AAC or AAAC.
Well, after understanding the types discussed, we will summarize some general factors which will help in choosing your required conductor.
Let us have a look at them:
  1. Conductivity
  2. Tensile Strength
  3. Cost
  4. Distance
  5. Corrosion Resistance
  6. Weight
  7. Thermal Stability and other environmental factors
In this way, we understand the most generally used types of overhead conductors.
  • Why is IGBT used in VFD?
  • Importance of Neutral Wire
  • Induction Motor Problems
  • Cables between VFD & Motor
  • What is a Current Transformer?
One Nation One Grid One Frequency – Electrical Engineering
How to Read the Nameplate of a Motor?
Difference Between Permittivity and Permeability
How to Check the Continuity of Protective Conductors?
Difference Between UL489 and UL1077
Motor Forward and Reverse Direction Control using Limit Switches
Difference Between Overcurrent and Overload
Automatic Transfer Switch (ATS) Using Classic Control Circuit
Electrical Drawings
Difference between UPS and Stabilizer?
Stepper Motor Working Principle
What is Vacuum Circuit Breaker?
Electrical Cabinet Air Conditioner
Electrical Cabinet Air Conditioner – Enclosure Cooling, Maintenance
Variable-speed motor controls
Variable Motor Speed Control
Top 100 Electrical Machines Projects for Electrical Engineers
Wave Trap in Power Line carrier Communication
What is a Wave Trap? – Power Line Carrier Communication
Volume Damper
What is a Damper? Types of Dampers in HVAC
Electrical Link Box
What is a Link Box?
Relay Parts
NO vs NC Contact
Difference between Fixed Area and Variable Area FlowMeters
Difference between Fixed Area & Variable Area FlowMeters
Free Online Control Valves Course
Free Control Valves Course
Allen-Bradley PLC Circuit
Programmable Logic Controller (PLC) Questions and Answers – 12
Two out of Three Logic Analogy
Calculate Hydraulic Pressure of a Drum
Calculate Hydraulic Pressure of a Process Vessel
custom metal fabrication
Custom Metal Fabrication Techniques for Quality Machined Parts
Artificial Intelligence Projects
Artificial Intelligence Projects List and Ideas for Students
Thermocouple Temperature Range
Thermocouple Properties, Temperature Ranges, Element Construction
