Reading: What is an Inductor? – Types of Inductors
Inst Tools > Blog > Electrical Basics > What is an Inductor? – Types of Inductors
The types of inductors depend on the material used for it’s core coil construction such as Iron core, Laminated core, and Toroidal core.
Last updated: May 24, 2023 10:49 am
Electrical Basics Electronic Basics
6 Min Read
Electrical circuits contain many tiny components which are very useful in driving and controlling them properly. Every component has its key role and it is impossible to run the whole circuit without them.
What is an Inductor?Types of InductorsIron core inductorAir core inductorLaminated core inductorToroidal core inductor
The most used components are resistors, capacitors, and inductors. An inductor is a very useful component in an electrical circuit. There are many types of inductors available for use in electronic circuits. In this post, we will learn the types of inductors.
An inductor is a component whose role is to store magnetic energy in it and convert it into electrical energy when required. They look like a coil and this structure is the reason for such performance of an inductor.
What is an Inductor
When current flows through a wire, it creates a magnetic field around it. But, in the case of the coil, the magnetic field is concentrated and tends to create hotspots around the coil junctions. These all magnetic fields tend to then create a single large magnetic field around the coil. This magnetic field is so large that it is enough to store the magnetic energy in it.
Now initially, when current starts to flow through the inductor, it provides a very large resistance to it. So, current will not flow through it or will flow in a minimum quantity. The current is flowing as it is and after a period of time, the current will start flowing through it after it has offered the resistance. The time till which it was not allowing current to flow was used by the inductor to store the magnetic field in it.
Inductor Working Principle - Electrical and Electronics Engineering
When the current supply is stopped, then the magnetic field which was stored is released immediately into the electrical field. This will allow current to flow through the line for a period of time even when the power supply has switched off. Once all the magnetic field has been discharged, the current will not flow through the circuit now.
So, the inductors are used to supply the same amount of current every time in a circuit; this means suppose there is a spike, then the inductor will absorb the extra current and when there is under current, then the inductor will release the stored energy in it. It is designed to pass only a certain fixed amount of current. In this way, it helps to control the electric spikes and fluctuations in a circuit.
Types of Inductors
The types of inductors depend on the material used for its core coil construction. Let us have a look at the types of inductors used in electrical circuits.
Types of Inductors
Iron core inductor
Iron or ferrite is a ferromagnetic material. One advantage of ferrous materials is that it offers a very high permeability (high magnetic field generation). This increases inductance properties in a great way, but one more major issue is that they suffer from energy losses at higher frequencies.
This is because, ferrous materials have a great amount of skin effect (as frequency increases, the current is unable to dig deeply into the conductor material); resulting in high resistance and losses.
Air core inductor
Air core inductor is the exact opposite of iron core inductors. They use air as the core material; sometimes plastic or ceramic too. They have low permeability and also, they suffer less at higher frequencies. But, due to low permeability, the inductance property is poor at normal frequencies.
As the name implies, a Laminated core inductor is a stack of laminated sheets as the core materials. Basically, when you stack something, the eddy current or energy losses if any tend to decrease because the loop area is small in this case. So, apart from good inductance, they help in minimizing the losses to a great extent.
The toroidal core inductor is the best type of inductor available for use. It is circular in shape. The circular shape allows for a very large area of magnetic field generation. Due to the abundant magnetic field, the inductance too is very good and also, they have less energy losses.
  • Importance of Neutral Wire
  • Induction Motor Problems
  • Cables between VFD & Motor
  • How to Test a Battery?
  • Electrical & Electronic Devices
Electric Motors Noises – Types, Possible Sources, Reasons
Difference between RCCB and RCBO
Electric Stress Control in Cables, Joints, and Terminations
Types of Electrical Loads
Lithium-ion Battery Charging Systems
Electrical Substation – Busbar Arrangements and Layouts
How to Operate a Group of Induction Motors using PLC Logic?
What is insulation? How to Choose the Insulation Material?
Safety Tips When Working With Electricity
Basics of Voltage Regulator
Electrical Energy Management System and SCADA in Power System
Electrical Wire Mesh
What is an Electrical Wire Mesh?
Power Outlet
How does Electrical Power Outlet Work?
Difference Between LED and LCD
Construction of Megger
What is a Megger? Principle, Advantages, Disadvantages, Applications
Gas-Insulated Transmission Line
What is Gas-Insulated Transmission Line? Principle Advantages
What is a Buchholz Relay
What is a Buchholz Relay? Working Principle
Electrical Terminology
How to Test Diodes Using Multimeter
Color detection PLC logic
Conveyor Sorting System with Color Detection PLC Logic
Convert Raw Counts to Engineering Units
Raw Counts to Engineering Units : Conversion Formula
Chromatographic Behaviour of Solutes Questions & Answers
IEC 60909 and IEC 61363 for Short Circuit
Level Sensor Pressure vessel mounting
Level Instruments Design Rules
Omron PLC paper cutting machine automation
Automatic Paper Cutting Machine Using CX-Programmer
Basic Pneumatic System
Pneumatic Handbook
